Question about Porter Cable Tools & Hardware - Others
Porta Nailer does not drive nails. Its a manuel model. When you swing the hammer to drive a nail down, no nail comes out. Its probably a simple replacement part. Do you know what part can it be?
  • Kevin O'Leary May 11, 2010
    What portercable is it? a flooring nailer?
  • 52 Answers
Any word on type of nailer?
Posted on Mar 02, 2009
How to keep hardwood clean
their is products in the stores that dose just the thing : )
Oct 26, 2014 | RTO Porta Nails Porta Nailer 403 Porta...
Bostitch F28ww nail gun does not cycle. There is no air leak or any sound when I press the nose down and pull the trigger. It is like it has no air at all. I was using it, it fired 2 nails at the same...
It sounds like your drive pin is jammed in the barrel. Can you see that moving freely? One of the two nails it fired may have lost a piece and is jammed in the barrel between the drive pin and barrel.
If this is the problem, You'll need to take a sturdy "drift pin punch" and hammer to drive the drive pin back down into the nailer. (I use an old drive pin from a discarded nailer as a drift pin punch)
Once the piston and drive pin are free again, the nailer should work fine.
Oct 29, 2013 | Hitachi NR83A2 2" To 3 1/4" Full Head...
The ram on my porta nailer is not returning
Remove the ram cover, using an old blunted nail carefully drive the pin back to the up position. Disassemble the gun and inspect both the drive pin and the rails for metal burrs file them off if necessary.
Mar 22, 2012 | RTO Air Tools & Compressors
Porta Nailer Air leak ( gasket ? ) compression chamber
More likely an O-ring. When they spring a leak, you buy a kit that contains all the gaskets and O-rings and replace them all. An easy job. Hope this helps.
Apr 07, 2010 | RTO Porta Nails Porta Nailer 403 Porta...
16g wont shoot nails. bottom flat piece comes out
You broke the "hammer" you can open the housing and replace it, fairly simply. You can buy replacement parts at most large scale hardware or tool stores. The task takes about 10 min, and some simple hand tools.
Jan 03, 2010 | Campbell Hausfeld 2" 18GA Brad Nailer
The nails aren't going in far enough using a air cleat nailer
I just finished 800 square feet of oak flooring with this nailer. You might have to increase the psi at the gun and make sure it gets a good square firm hit to set the nail. You can swing and hit the thing pretty hard, I hit it hard to set warped boards in place. I used 120 psi for best results, I tried 90 psi but had more misfires. The nail head only needs to set in far enough so the head is touching the tongue and so the next board will fit. The nail won't be buried into the tongue like you might think. If the occasional nail protrudes from the board you can use a nail set to drive the nail the rest of the way in, but I found that most of the nails didn't want to set by hand. I either clipped off the head with side cutters and folded over the remaining tab or did my best to set the nail if it wasn't long enough to clip. If it bends over really ugly, just carve a little wood from the groove lands on the next board to clear the nail stub. Removing the nails is difficult, it's best to let them be rather than risk damaging the flooring. Also, don't let the gun get down to the last nail. Sometimes if you try to fire the last nail on a strip it will twist and damage the flooring. Always keep a few nails in the gun just to be safe. Hope this helps.
Nov 23, 2008 | Porter Cable 2" Flooring Cleat Nailer...
Nail Gun question
For every nail that a normal human with a hammer could hand drive on his best day, a pneumatic nailer would drive and set twelve! That is no exaggeration. Although there is no need to go this fast, a reasonable speed would allow you to be 400 to 800 percent more productive. Nailing large subfloors and roof decks is a breeze. Hours worth of work becomes minutes.
Aug 27, 2008 | Irwin 12" Bar Clamp Multi Position Jaw
Nail Guns comparison
Aug 27, 2008 | Arrow Elec Brad Nail Gun Kit
Tools & Hardware - Others Logo
240 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
