Question about Acer Computers & Internet
SATA Hard drive caddy not acknowledged
Hard drive: Samsung HD080HJ/P Caddy: USB 2.0 device O.S: Windows XP SP2 I have an external SATA hard drive caddy that is behaving strangely. It was working fine then inexplicably stopped after backing up some material from a laptop PC. It is in receipt of power and is still listed in the following: ''Safely remove hardware'' as a USB mass storage device ''Device manager / disc drives'' as working properly However, it is not listed as a disc drive in ''My Computer'' under ''disc drives with removable storage'', or anywhere else in the system. The main internal SATA drive is partitioned into 4 sections (C,D,E,F), and there is an additional seperate internal IDE drive (G) as well as the usual floppy (A) and DVD-ROM (H) and DVD-RW (I). Data keys pop up as (J), but no joy for the EXT caddy. Can anyone offer a suggestion. Best My product was not listed in your categories so was listed under: "Computer Hadrware/PC Desktops/Acer"
    Master:
  • 474 Answers
Yes, what it seems to me is that you have alot of devices connected and windows by default trie to give the same device the same letter every time you connect it. Well if something else takes its place and you try and connect it, it tried to give it that letter but cant and kind of sits in limbo in the device manager.
Try the following.
Right click " My Computer" and select " MANAGE"
Then when that opens, select the " Disk management" on the left side of the sectioned window.
On the right it should populate your drives including the one that you said isnt showing.
See what letter it is assigned. You can change the drive letter by selecting the drive on the right side, right click and change drive letter to somehting that you know isnt being used like " Z " .
Confirme, or O.K. it and then if all goes well, it should auto detect and it should show under my computer.
This often happens with windows when there is alot of similar devices connected. Windows can only handle up to 32 devices being connected at one time and soem times it holds onto a drive letter for another device and cant give it out to another. often devices such as External hard drives will also try to reclaim the same drive letter and will fight over it. Windows bassically just ignores it since it already gave out the letter to another device and you have to specify it another one.
Let me know if this works or if you need more help.
Posted on Feb 11, 2009
How can I retrieve my information from my verbatim hard drive 320gb? It isn't opening.
Take the drive out the caddy and plug it into a computer using a SATA to USB cable. If the drive doesn't spin up then it's a dead drive and you'll need to use a data recovery company
Jul 17, 2016 | Verbatim InSight 320GB USB 2.0 2.5...
How can I attach a Samsung hard disk HD080HJ/P to a Dell Optiplex 755 Core 2 Duo E4400 PC computer? There seems to be no master/slave settings on the hard drive.
Newer sata drives do not rely on the master/slave settings that old IDE drives used. Remove the old drive from the bad computer and plug it into an available slot in the new computer. Boot the new computer. Under My Computer/Computer the second drive will show up with the next letter available. Alternately you can buy an external hard drive dock that connects via usb and use that to transfer your files.
Dec 01, 2012 | Samsung (HD080HJ/P) 80 GB SATA Hard Drive
Getting data off HDD from Caddy ?
I have had similiar issues using caddies there seems to be many connecting parts that can fail or become old and dirty failing to make contact with the hard drive you could remove the hard drive and check these contacts make sure they are clean and making contact
or
You could just remove the hard drive from the caddy and connect it directly inside your computer as a normal hard drive
or
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
http://www.bing.com/images/search?q=SATA+Power+Splitter&qpvt=SATA+Power+Splitter&FORM=IGRE
Once connected to another computer to a usb port and power supply you should get a message found new hardware and it should install the drivers it should show on your computer or you might have to install it manually
click start click on computer to open you should see this drive
If you dont.
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a Yellow Question / Exclamation Mark? ! or a Red X
you will need to update/reinstall drivers
right click to reinstall drivers.
If you can see your usb drive but its not working
ports (com&lpt) right click update driver
Once you see this drive just click on it to open and copy all or any data you want and save it to another usb drive
or get one of these
http://www.ebay.com.au/itm/NEW-2-5-SATA-USB-2-0-external-HDD-enclosure-case-AU-/221010079433?pt=LH_DefaultDomain_15&hash=item33753a2ec9
NEW!2.5" SATA TO USB 2.0 external HDD enclosure case AU
Hope this helps.
Nov 23, 2012 | Computers & Internet
My hardrive is less than a year old and it will not power on. I tried a different cable and outlet. What is the problem and can i fix it?
It may not be the hard drive it self, it may be the caddy the drive is in. The best way to check if it is the hard drive is try the hard drive in another caddy, or plug it in to the computer without it being in the caddy itself using the PSU and SATA or IDE cables.
May 07, 2011 | Iomega (H0815VCA) 2 TB USB 2.0 Hard Drive
Can I install a hard drive with out caddy or run the machine from an external drivve?
Yes, you can.
Connect your hard drive and installed the operating system and drivers,
That's it,Connect the hard driver whenever you want to boot from that Hard Drive.and change the BIOS to boot from that hard drive in Hard drive boot priority.
Why not you considered booting from a USB Pen Drive.It's most flexible than booting from an external Hard Drive.
Here are fews link on how to make a USB bootable Windows.
1.http://articles.techrepublic.com.com/5100-10878_11-6160062.html
2.http://www.downloadsquad.com/2009/08/27/make-a-bootable-usb-installer-for-windows-xp-vista-7-with-wint/
Dec 27, 2009 | Panasonic Toughbook CF-51 Notebook
I have an E1505 with no hard drive, no dvd drive. 2 questions: Is there a special "sled" or tray needed for a new drive, and do the connectors for any new hard drive line up and plug into the bay...
Answer for question 2 is yes, get into the BIOS and change the boot menu to include a ISB device if one is not enabled. I am unsure of the factory default, but once you are in the BIOS you can check that usb booting is enabled.
The hard drive of the E1505 use a "caddy" which consists of a smooth plate and a caddy head that screws to the hard drive and allows easy access to the drive by allowing you to pull it free of the side of the computer. Some people do not use the flat plate and just screw the caddy head atraight to the drive itself. I would recommend the whole caddy setup. Ebay sells them by the hundreds. Dell does not use an adapter on the hard drive to get it to connect with the motherboard. Your drive should be a SATA interface and that is what is on the motherboard as a connection. All you need is a "caddy" to be able to easily remove and secure the hard drive.
Oct 28, 2009 | Dell Inspiron E1505 Notebook
Not detect my 320gb hard drive why?
I presume this is using USB. Try plugging it directly into one of the USBs on the back of the computer. If it's in a hub it may not be getting enough power to spin up the dtive. etc.
Aug 22, 2009 | Maxtor Hard Drive
Hard drive dont load up properly
your hard drive is dead mate. sorry. they die form time to time.
buy yourself a new hard drive and an external hard drive caddy (a 3.5" one) make sure the caddy is the right connection for your old hard drive. either sata or ide.
then put the new hard drive into your pc to take the place of your old one, and load windows onto it.
next get your old hard drive into the usb haddy drive caddy/enclosure, connect it all up and see if you can use the ghost function on norton anti-virus secruity to bring back your old data.
hope this helps.
kev
Oct 02, 2008 | Acer Aspire T310 PC Desktop
Hard Disk upgrade
Figured this out...
1)  Flip laptop over, keep front of laptop closest to you and hinges away from you 2)  Remove cover with cylinder/harddrive icon (2 screws) 3)  Remove small single silver screw near the front (close to you) of the laptop in the center of the metal harddrive caddy (the caddy may hold one or two hard drives) 4)  Pull the plastic tab on the left toward the outside of the laptop... the whole caddy with harddrive(s) inside will shift to the left, disconnecting it from the motherboard and lining up the caddy for removal. 5)  Lift the entire bracket straight up
To remove the primary harddrive (the only one present in my model) you must remove the blue L-shaped circuit board from the caddy. 1)  Flip the caddy over 2)  Remove the three screws with slightly larger head diameters around the perimiter of the caddy 3)  Push/slide/jiggle the circuit board so the sata connectors release from the hard drive(s). 4)  Unscrew the hard drive from the caddy
Aug 25, 2008 | Acer Aspire 7720 Notebook
Computers & Internet Logo
133 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
