Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Homelite CSP 3314 Chainsaw
hi
i wonder if you can tell me the correct 2 stroke oil/petrol ratio for the Homelite 3314 chainsaw.
any assistance much appreciated.
thanks
  • knightpatrol Feb 11, 2009
    thanks very much friend, appreciated.
    Cliff
  • Anonymous Mar 23, 2014
    Which line goes to the out on oil/ gas line hookup on 240 homelite chainsaw
Starts no prob will not rev , just stalls when you try
Posted on Feb 14, 2010
  • 211 Answers
Hi
You need an oil of supperior quality for 2 stroke engines.For example an oil 1:50(with 1 liter oil you can mix 50 liters gas,20 milliliters oil for 1 liter gas)
best regards savumihai71
Posted on Feb 11, 2009
I need to know fule oil ratio for homelite super2 chainsaw
Generally small tool 2 stroke engines run on a ratio of 50:1
That's 100ml of oil in 5L of petrol
Apr 03, 2016 | Homelite Garden
What is the gas/oil ratio for this chainsaw? Is synthetic oil okay to use in it?
Generally 2 stroke engines work on a ratio of 50:1
100ml of 2 stroke oil in 5L of petrol.
Use good quality 2 stroke engine oil for the mixture, Stihl and Husqvarna both have high quality engine oils, designed for more efficient lubrication and emissions quality.
Mar 28, 2016 | Garden
What is the fuel oil ratio per litre for a husqvarna 535rxt strimmer
If it is 2 stroke, take petrol /fuel and mix it with preferably synthetic2 stroke oil.
Ratio is usually 10L petrol mixed with 200 ml or 2 stroke oil, that is the best result, used it on my chainsaw, strimmer, moped, working for years without a glitch.
Jul 20, 2015 | Husqvarna Garden
I brought a brand new homelite 33c-csp 3314 and my wife threw the manual out or i lost it ,how much chain and bar oil do you put in the oil part? i cant open pdfs cause somethings wrong with that thank...
Hi, basically you fill it up every time you fill up with two stroke fuel as it uses about 3/4 of a tank of bar oil to a tank of fuel. Regards Phil.
Aug 11, 2011 | Homelite Garden
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 | Garden
What fuel does the csp 3314 use? I bought this chainsaw second hand and i am unsure what fuel to put in it. Thanks in advance for any assistance Kelly
You need to mix 3.2 oz of 2 cycle oil to 1 gallon of gas. Some may disagree but a 40:1 ratio is better than a 50:1 mix. It gives more oil in the mix to keep the cylinder/piston lubricated. Any less and you will burn up the engine. With this new mixture you may need to get a professional to readjust the carburetor to this new mix.
Sep 25, 2009 | Homelite Garden
What is th petrol and oil ratio for a homelite petrol chainsaw 33c- csp 3314
Generally you're looking at a 50:1 ratio on most chainsaws and I wouldn't see any reason the homelite should be any different. Usually it's one 2.5oz container of the oil mixture to one gallon of gasoline but check the label to be sure.
Jul 30, 2009 | Homelite Garden
What is the oil-gas mix for a homelite superxl chainsaw? For 1 gal.
16:1 ratio for most 2-stroke oil brands. A service manual recommends tro check the ratio marked on the bottle if using Homelite brand 2-stroke oil. For other oils, 16 parts of gas to 1 part of oil.
For 1 gal of fuel, that is 270cc of oil required to meet the 16:1 ratio.
Please rate this solution on FixYa!
Jul 16, 2009 | Homelite Garden
Need to know the correct levels of oils in a chainsaw
Most McCulloch saws use a 40:1 oil ratio if using McCulloch branded 2-stroke oil. They state 20:1 for other oils, but this is probably overkill as most name branded 2-stroke oils these days are pretty good. I would probably go for a 30:1 or 35:1 mix to err on the side of caution. This will not affect performance, it may just mean you need to change spark plugs a little earlier than usual, but the cylinders will at least be well lubricated.
Please rate my response on FixYa.
Mar 24, 2009 | McCulloch Garden
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
3,070 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
