FixYa.com
Tags:
RIM BlackBerry  Pearl  8100
Problem in using Gmail Mobile in Blackberry Pearl...
By lawyer - usenet poster
The program started normally and asking me to login. Then after asking
me to grant right to get access to http, it started to logging me in
and showing the "Loading" on the top right corner as usual. After half
a minute, it prompt me with the following error:
"java.lang.NullPointerException: Cause Unknown"
Does anyone come across this problem with your Blackberry Pearl before?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 01, 2007
Helpful (85)
Perkins
Perkins - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Same problem...java.lang.Error: Cause Unknown and
java.lang.NoClassDefFoundError
I used to code java and this sounds like an istallation problem or some
type of class path problem. Not sure how to fix this on the
Blackberry. Need help!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 04, 2008
Thanks for Trying (70)
Rocky4631
Rank:Wiz Wiz
Rating: 79%, 38 votes
See if you can clear your java script with holding down the alt key and typing LGLG, clear java script and see if this resolves your issue.
Solution #4
posted on Apr 22, 2008
Not Rated (0)
JacquelineG
Rating: 78%, 4 votes
The java errors usually have to be fixed via software download/upgrade (4.3)
Solution #5
Not Rated (0)
pawa
pawa - usenet poster
Rating: 0%, 0 votes
I am having the same problem (i.e., "java.lang.NoClassDefFoundError")
anyone have a definitive fix for this?
Thanks!
Solution #6
Not Rated (0)
Rogers
Rogers - usenet poster
Rating: 0%, 0 votes
So, after installing Google's Mobile Services package I have had no
problems with this internal server error. The strange thing is that I
only installed Search & News, as I had already installed Gmail & Maps.
All the icons updated including Gmail & Maps, and I haven't had a
problem since. I'm able to refresh, reply, forward, etc - without any
errors. Strange, but it has worked for me for over a week now.
Regards,
~ Rob
Solution #7
Not Rated (0)
pandamama
pandamama - usenet poster
Rating: 0%, 0 votes
I have a java.lang issue as well on the same phone,
java.lang.RuntimeException: Unexpected server response: 500 Internal
Server Error
This comes up when I attempt to refresh the inbox, and also delete
messages.
Gmail team - any way to fix this?
Solution #8
Not Rated (0)
Putty
Putty - usenet poster
Rating: 0%, 0 votes
I have this exact same problem too - were you guy able to find a
solution? Please post it if there is a solution - thanks.
Solution #9
Not Rated (0)
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
I have the same problem. I don't know what to do...
Can you Help with these PDAs problems?
can't connect
after placing my sim card in my... Answer This...
Not identifying SIM Card
received a new BB Pearl 8100. I... Answer This...
Battery Problem
I have a new Blackberry pearl... Answer This...
when I ans my blackberry I...
incoming calls when I ans my... Answer This...
I HAVE BLACKBERRY 8800 O2
i dont have unlock code, can... Answer This...
Repair Service
Find PDA Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
