Question about Lands Phones
My GE Dishwasher PDW8700N00BB has water standing in the pan over and above the normal 1 to 2 cups and I don't hear the same sound it used to make through the disposer when draining. Hose seems fine and no air lock to my knowledge.Just started product is just over a year old.
    Sergeant:
  • 250 Answers
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Posted on Feb 11, 2009
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason to this problem is the alarmer
that is present inside the dishwasher.That's
not a big worry,it wont affect your product in
any way.onlything is you wont get any such
sounds during the time of draining.Alarmer
could be a problem due to some fault like
wiring or any type of short circuit.If you would
like to replace it is your wish.This is not a big
worry.
check it out..
thank u..
    Master:
  • 474 Answers
Most likely there is food or debre stuck in the line preventing drainage.
To be sure, this is the sink/disposal we are talking about, or the actual dish washer?
Alot of time a dish washer will have its output water line connect directly into the disposal where it empties and goes down the disposals drain, the problem can occure when the line goes up hill to drain instead of downhill with gravity, causing dirty water to stay backed up and it begins to stink.
Also, a disposal is made to chop up debre that gets past the sinks little filter screen, not to poor entire meals down.
You may have large chunks of food clogging up the drain and backing up the water.
You may have to disassemble it to clean it out. Make sure when using the disposal that you run the water while its on, this allows for easier flow of food debre.
    Sergeant:
  • 326 Answers
draining the water out....
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Scrape away large pieces of food, bones, pits, toothpicks, etc. Burned on food should be loosened before loading. Empty liquids from glasses and cups. Foods such as mustard, mayonnaise, vinegar, lemon juice and tomato products may cause discoloration of stainless steel and plastics if allowed to sit for a long period of time. Unless the dishwasher is to be operated at once, it is best to rinse off these food soils. Load racks so that large items do not prevent the detergent dispenser from opening. If the dishwasher drains into a food disposer, be sure disposer is completely empty before starting the dishwasher.
disposals have a "plug" in the connection stub for the dishwasher drain hose. This plug MUST be removed or the dishwasher will not be able to drain into the disposal.
Not all water drains when complete
Go to your local hardware store or grocery store and get a product called CLR which stands for Calcium Lime and Rust remover. Pour a full cup into your dishwasher and let it stand for a couple of hours. Pour another cup in and run it through a normal wash cycle. If that doesn't fix it do it again. This stuff dissolves the built up lime just like it does in your coffee pot.
Feb 22, 2011 | GE Dishwashers
I have a Toastmaster bread and butter machine, model 1195. Need to know what size the bread pan is.... 1, 11/2 or 2 pounds, its not written anywhere on the appliance. Also, I need to replace the bread...
Bread pan Capacities
Here is how you determine the size of loaf you can bake in your machine. You need to determine the capacity of your pan. Fill your pan with water and measure the cups added so you know how many cups of water are in the pan when it is full to the very top. Here are the conversions:
1)If your pan holds less than 10 cups of water you can make: a 1 pound loaf
2)If your pan holds 10 cups of water you can make: a 1 pound loaf and a 1.5 pound loaf
3)If your pan holds 12 cups you can make: a 1 pound, 1.5 pound, and a 2.0 pound loaf
____________________________________________________________________
This is rare, but if you pan holds 14 cups or more you can make all the above plus a 2.5 pound loaf
FROM ANOTHER SITE:
To find your bread machine pan size:
Fill the bread pan with water and measure it out in cups
Less than 10 cups of water = 1 pound
11-13 cups of water = 1 1/2 pounds
More than 13 cups of water = 2 pounds
You don't need the bread pan cover unless you are making butter. If you are making bread you should always leave it off or it could melt from the heat of the baking cycle. The butter cycle doesn't use heat. Please rate this answer with testimonial/vote/rating etc Thanks!
Dec 28, 2010 | Toastmaster Kitchen Appliances - Others
Hinari homebaker model hb152 bread capacity what is bread capacity for model
FROM ANOTHER SITE:
Dec 26, 2010 | Kitchen Appliances - Others
Lost manual need to know if the trilium TR 500 breadman is a 1 lb or 1 1/2 lb machine and directions. lost the manual
FROM ANOTHER SITE:
Dec 17, 2010 | Breadman TR500 Bread Maker
What size bread will 41066 make
FROM ANOTHER SITE:
Dec 14, 2010 | West Bend 41077 Just For Dinner¿...
How many pounds does the trillium tr-500 bread baker make? 1 or 1 1/2 lbs?
Nov 27, 2010 | Breadman TR500 Bread Maker
Bought a used toastmaster bread maker model 1196. what size loaf does it make. is the dough paddle removable ? also need a manual siurce
The dough paddle is removable and should be removed shortly after baking by soaking in 3-4 inches of warm soapy water. If your paddle is stuck let me know. I don
Nov 21, 2010 | Toastmaster Kitchen Appliances - Others
My GE Adora dishwasher is not cleaning well and the detergent isn't completely disolving. What could be the problem?
Mine has been doing the same thing for about 2 months now.. I tried Finnish brand diswasher cleaner, but to no avail. Try this:
1) Empty your dishwasher, then take out the lower rack.
2) Start a regular cycle. Wait until you hear the jets turning, then open the door. Make sure there is enough water in the bottom - It should be just UNDER the heating element.
3) If your dishwasher is getting enough water, Reset your washer and allow it to drain.
4) Go to the store and get a gallon jug of white vinegar. Start your dishwasher on a regular cycle.
5) Once you hear the jets turning, Open the door and add FOUR CUPS (liquid measure) of white vinegar to the water in the bottom. Let the wash cycle complete.
6) When the wash cycle drains, the rinse cycle will fill. Once the rinse cycle starts, add ANOTHER FOUR CUPS of white vinegar to the first rinse cycle.
7) Allow the first rinse cycle to drain. Let the second rinse cycle complete normally.
I know this sounds too good to be true, but it REALLY DID work for me, this evening as a matter of fact! I also bought some hard water/soap film detergent additive from the store. It was kind of expensive, but I'm using it for a while just in case.
I hope this helps. Like I said, I couldnt believe it when my dishes came out clear again! Also, I turned OFF the heated dry cycle, and just opened the door and pulled out the racks when it was done.
Good Luck!
Mar 30, 2010 | GE Adora GHDA654LBG Dishwasher
Water & soap was coming out of the dishwaster. Replaced the seal around the door. Ran again on a pots & pan cycle to clean & it worked fine. Ran a normal cycle with dishes & soap &...
That sounds like the float switch is acting up. It is a mushroom looking device on the bottom that has a movable (up and down) plastic cup over the top. With the machine off, take the lower tray out and lift up on the cup--you should hear a faint 'click' when it nears the upper limit. It should also drop to the bottom when released. There may be food deposits that interfere with the proper movement of the cup. Are you using dish washer detergent only?
Aug 15, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
Lands Phones Logo
141 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
