Question about Ruud Central System Air Conditioner
Furnace runs on heat, air conditioner does not
I have a ruud ultra series central air unit and landlord does not have the owners manual. landlord thinks the cenral air unit should run on heat em saver setting but does not. we think the furnace is running off straight electricity since the central unit is not kicking on. when i turned the ac unit on as running in ac mode, the ac untit runs fine, but when i turn it back to heat, no matter what setting i put it on, the ac unit does come on. is this how it is supposed to be?
  • dwkcool May 11, 2010
    If this is a heatpump system the outside condinsing unit should be running when in heat mode for better heat and energy cost the em heat or aux heat should only be on when the unit can not keep up with the heat demand in the house so there is something wrong
  • Anonymous Mar 29, 2014
    Furnace on but ac unit running
  • 20 Answers
The only time the outdoor Ac unit runs when u set thermostat to heat is if u have a heat pump thermostat n system . If u do have a heat pump system n only your furnace runs n not the outdoor system it could b that the outdoor thermostat is not closed due to outside temp is below 35 deg. Or the outdoor thermostat is bad. This problem will need a qualified tech onsite to continue with the diagnostic
Posted on Oct 26, 2014
  • 56 Answers
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Posted on Feb 12, 2009
Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
Jul 08, 2010 | Ruud UAPA042 Air Conditioner
From the Isolator panel, how do I connect the condenser, and the blower?
MOST UNITS NOT HEAT PUMPS  WIRE UP WITH 2 WIRES TO CONDENSER RED WIRE AND WHITE . WHITE GOES TO COMMON C ON FURNACE AND RED TO Y TERMINAL OF FURNACE Y ALSO GOES TO Y ON TSTAT. BOTH YELLOW WIRES MUST MEET AT Y OF FURNACE.  WHITE FROM STAT TO W   GREEN FROM TSTAT TO G AT FURNACE IF YOU HAVE C ON TSTAT HOOK UP BROWN WIRE OR BLUE FROM COMMON TERMINAL WHERE YOU HOOKED UP CONDENSER WHITE WIRE AT FURNACE TO TSTAT , MOST THERMOSTATS DONT NEED C RUN FROM FURNACE. THE TWO WIRES GOING TO CONDENSER IS -  AND + TO ACTAVATE CONTACTOR IN OUTSIDE UNIT
Apr 19, 2010 | Ruud Central System Air Conditioner
My heat unit will not blow hot air unless we go outside and hit a button on the back bottom of the unit. Once we do that it will blow hot air for that cycle. when it is time for it to come on it is cold...
If it does not have a furnace or heating elements for heating, then it is a heat pump, which is rare for a central AC system, but makes sense of the fact that it blows warm air when you reset the pressure switch, which may indicates freon pressure charge problem if your AC system has a reverse valve and uses freon to for heating (heat Pump).
Do you get heating when outside unit runs? if you do, check freon pressure levels and top up to required pressures. The button you depress is a pressure reset switch ... that is if your AC system is a heat pump ... which, as pointed above, it is not common for central ACs.
Nov 07, 2009 | Ruud Central System Air Conditioner
Drain pan for central air
nope, you're sol - have to replace evaporator coil assembly - sorry for the bad news
Oct 05, 2009 | Ruud Central System Air Conditioner
Ruud heat pump outside fan won't run
Tell him to make tight connections.
Jun 23, 2009 | Ruud UBHC Air Conditioner
Fan on unit will not turn on in cooling mode
Check to see if the green thermostat wire is conneceted to the "G" terminals on the thermostat and on the furnace.
Apr 20, 2009 | Ruud Central System Air Conditioner
Fan comes on but unit does not heat or cool the air
You,ll need to open the furnace and observe the led lights on the comtrol board the is a chart attaced to cover. If it is in lock out mode the fan runs. To reset turn off at tstat.the turn the power on at the furnace, set tsat up, observe furnace. First you should hear a small fan then the glow of the ignitor then the opening of the gas valve and flames 10-30 seconds then the big fan.
Mar 27, 2009 | Ruud Central System Air Conditioner
Ruud 12 seer heat pump not heating
It sounds like the unit is tripping off from high pressure. Check you filter and indoor coil. You may have low air flow inside that is causing the refrigerant pressure to be to high.
Mar 22, 2009 | Ruud Central System Air Conditioner
Central air conditioner
check the filter also sounds like a low freon charge.
Jul 29, 2008 | Ruud UBHC Air Conditioner
Ruud Central System Air Conditioner Logo
509 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
