Question about Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive
Flashing LED light but not working
I accidentally inserted my lap top's ac/dc adapter into my external Toshiba hard drive and now it just flashes on and of continuously when i try switching it on. Please help
  • 2 more comments
  • lwanga447 Feb 13, 2009
    Oh no, i thought that inserting my laptops adapter would damage my hard drive but i hoped that the problem wasn't that.
    My lap top's adapter reads 19v 15a, and the external hard drive 12v 2a...
    What can i do to try and repare it, is the warrenty over now that i have done this? because it says on the paper that if i use a third party adapter i loose it, i inserted it for a few seconds,
    or doesn't it have a fuse for such cases, so that i change it?
  • lwanga447 Feb 14, 2009
    Ok thank you, i will try that.
  • Misterixas May 11, 2010
    Check if your laptop's ac/dc adapter's voltage differs from external hard drive's. If so, there's a possibility that you damaged your external HDD's power circuit.
  • 23 Answers
Unfortuntly, this caused the drives power source to be exceded and damage the drive or circut board. If you know someone that knows computer well, have them or yourself take the hard drive out and manually connect the driver to a computer and extract your data, if the drive is not damage that is, there is know way to know for sure until you try to connect to a PC directly. Or, purchas another USB external housing.
Posted on Feb 14, 2009
My toshiba l655powers on using the dc cable and battery, but will not display anything. I can hear it boot, but nothing shows. I have hooked it up to a tv using a hdmi cable, but it shows no signal.
Please use the VGA port (VGA external monitor), also please do these:
1. Unplug the AC adapter,
2. Remove the battery,
3. Remove the hard drive,
4. Press the power button and hold it for 15 seconds,
5. Plug in the AC adapter,
Restart the laptop.
If the problem persist,
Note: Do not insert the battery, and do not install the hard drive.
2. Reseat the memory (remove it and reinstall it),
3. Plug in the AC adapter,
Restart the laptop.
If those actions do not solve the problem, then your GPU/motherboard is dying.
Mar 09, 2014 | Toshiba Satellite Laptop L655S5150
Toshiba Qosmio G30 Flashing DC- In LED on power up and cannot start laptop
I found some G30 with defective memory and it cause boot up problem. You can try to remove one memory to test it. Testing the laptop with a good working memory is the best way.
Feb 06, 2014 | Toshiba Qosmio G30-166 Laptop AC Power...
When i plug my charger in to my satalite L655 and turn it on. An orange light flashes.
Hello, stoneyless
The orange flashing you are referring to means that your battery is currently out of power. I would recommend trying a friends laptop charger (same brand and model) to rule out the charger, if you know the borrowed charger is in working condition and your pc still doesn't power on then you may blame the battery. From that point i would send it in Toshiba for a replacement battery AND charger (if still under warrenty). if warrenty is no longer viable you would have no choice but to find a suitable replacement for either the charger or battery. OR you can buy the same Laptop and take out the battery and laptop cable and return the laptop with the faulty equipment.
Feb 15, 2011 | Toshiba Satellite(R) L655-S5115 Laptop...
DC in light flashes orange
You need to test the AC Adapter For Correct Power Flow-Through... Use A Multimeter (available at any Home Improvement Store)
If That Tests Good.....
You Will Need To Test The DC Jack (the port where your Charger Cord Plugs Into On The Laptop.....)
If An Incorrect Adapter Was Used, You Might Have Shorted Out The Motherboard..
Dec 01, 2009 | Toshiba Computers & Internet
Toshiba plug-in ac adapter LCDlight flashing and wont boot up
It may be that you need a new, (Or good condition used), motherboard. You may not.
The problem could be the DC Power Jack. The DC Power Jack is small, and the body is made of plastic. Sometimes there is a metal shell around the plastic body. (The jack is a rectangular shape, and is just a little larger, than the outside portion of that AC adapter plug!)
This is an example of a DC Power jack for a Toshiba Satellite a215-s5807,
http://www.notebookworks.net/ProductDetails.asp?ProductCode=NBW52-0133
As you know there is a metal pin in the center, and at the back of the round hole, there are flat metal contacts.
Let me explain the construction of a DC Power Jack, and how it's mounted to a motherboard. This all has relevance to the solution.
Your laptop uses DC electricity. (The AC adapter converts AC to DC. Your laptop battery, and a flashlight battery, are examples of stored DC electricity)
DC uses a Positive connection, and a Negative connection. The metal pin in the center is Positive. The flat metal strips at the back are Negative.
That laptop DC Power Jack has metal prongs, that come out of the plastic body. One prong, (Or pin), connects to the Positive metal round pin, in the center of the jack.
There may be one, or two prongs, (Or pins), that come out of the plastic body, and connect to the Negative side of the jack. (Flat metal strips)
These prongs go down through holes in the motherboard, and are soldered on.
With the AC adapter plugged in, an accidental bump on the plug itself, could break the body of the jack, or break solder joints that hold the jack to the motherboard.
AC adapter removed, and battery removed. Use a NON-metallic object, and see if you can make the center pin of the jack move. See if the entire jack itself seems to move.
A.If the center pin moves, you have a broken DC Power Jack.
B.If the entire jack moves, you have cracked solder joints. (Broken)
Replacement of the DC Power Jack for A.
Re-solder the solder joint/s for B.
Cost of replacing a jack at a reputable computer repair shop? $90 to $150
Cost of re-soldering solder joints? $50 to $90
Cost of replacing the motherboard?
$250 on up.
If you are a skilled person with the correct tools, it is feasible for you to replace the jack, or re-solder the solder joints.
It is also feasible that you yourself, could replace the motherboard.
Some laptops have a poor motherboard design, for where the DC Power Jack is mounted to the motherboard.
Crude explanation would be, that the main body of the motherboard is a 1 foot square. Then a 2 inch square comes out of the side of the main body.
The DC Power Jack is mounted to that 2 inch square. From accidental bumping, OR just normal usage of inserting, and removing the AC adapter plug, this 2 inch square can crack away from the main body.
This, of course would require a motherboard replacement.
Disassembly instructions for a Satellite A200 and A205 Series laptops. Very close to the A215 Series,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
(Don't forget to buy, and use a cheap ESD wrist strap, to prevent static shock to the delicate hardware components, inside your laptop. Average cost is $7)
Aug 04, 2009 | Computers & Internet
Did I just fry my WD External?
I've done something similiar and I know the feeling, but the good news is that you may not of done the damage you think. Here's what I suggest. Go to this link. Where they will explain the differences of the meanings of the flashing lights. There are so many variables, that it would be to difficult to figure out unless I was actually working on the disk itself. But the page is very easy to understand, and hopefully you'll find what I did, was all I need to do was to power down and up again.
Good Luck!
Mark
Jan 03, 2009 | Western Digital My Book Premium ES...
SimpleTech 320GB external hard drive power adapter
I have the same drive and it uses an Accurian AC/DC Adapter. It's output is 6.3V. Also the model number is XKD-C1500NHS66.3-12. I hope this helps.
Nov 09, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Packard Bell
Check out the following link:
http://support.packardbell.com/uk/item/index.php?i=topic_02437&pi=platform_storeandsave3500&dhepn=C050890000
It includes the following:
Beeping noise and flashing LED
dot.gif dot.gif Situation dot.gifWhen I turn on the Store & Save, it makes a beeping noise and the LED flashes continuously. dot.gif Details dot.gifThese symptoms indicate that the AC adapter is not providing enough power. dot.gif Solution dot.gifThe AC adapter will need to be replaced. I hope this helps, Bob
Mar 24, 2008 | Computers & Internet
Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive Logo
507 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
