Am setting up my DVD recorder and am unable to loose SET UP from display. I have switched off and returned to this same display
  • 2 more comments
  • william_webb Feb 11, 2009
    I should have given my DVD reference it is GUDVDR01MFHV
    Sorry should have said the DVD is Grundig and I have not altered any settings and have also tried the machine with no external wiring attatched but the position is the same, regards WW
    Yes very helful had tried this but not for 4 hours
    will be in touch, thanks again WW
    Master:
  • 474 Answers
To be clear, every time you turn on the DVD player, your getting the SETUP menu on the screen and it wont go away?
I would of course, read the manual, but if no help, Look for the menu button on the remote and see if pressing it will make it go away or at least atry navigating through and setting any settings.
This isnt usually required with DVD players, usually you can just accept the defualt settings and start playing a DVD.
Are you usiung a Cable T.V. universal remote at all? If so, some times they dont get programed right by the cable company or you have to press the right source button, I.E. DVD, T.V. CABLE,Satalite etc. depending on what device you are using or want to use.
If you have reason to suspect that the DVD player itdelf is faulty, take it back if its under warranty, if not, start testing on another Television and begine torubleshooting what the issue may be.
Of course, makes sure everything is connected properly. A/V cables should gor the the output of the DVD to the input in back of the T.V. orin front a/v if available and you just want wires hanging out the front of your t.v., thats up to you.
Make sure that the T.V. is also set up properly and that the menu your seeing is in fact the DVD player and not the T.V.'s set up menu.
Let us know and good luck
Posted on Feb 11, 2009
  • 130 Answers
Look for a button that says exit or find in set up menu good luck
  • rachel stephens Feb 11, 2009
    you may have to use the set up utility to get it off your screen or program channels sometimes putting dvd in will clear it but there is usually a reason(input) that is needed to finish hope this helps
    Sergeant:
  • 250 Answers
Just start holding down "Enter" and "1", then "Enter" and "2", "Enter" and "3" on the remote, then switch to the reverse sequence (3, 2, 1), and after a few cycles,  - the remote will start working and you  will be  able to cycle through the setup process.
also check out this   the a/v cables plugged into the front TV connectors, note that there are a/v connectors in the back of the TV, those ones being the audio/video IN connectors where you should have put them in the first place
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason to this problem is the video cable.
you might not have plugged the video cable
properly.Insert it properly.This will solve your
problem.
check it out..
thank u..
rate me..
    Genius:
  • 3,422 Answers
HI,
Please reset your unit by unplugging all the cords,even the power cord of the recorder and plug them back in again after 4 hours.Turn it on and let me know the result.
    Sergeant:
  • 326 Answers
Did you changed any settings from before as it was orignally.also remove all the external wires from its back and reconnect it.also give the model number and brand of dvd player for further help.
thanks.
    Master:
  • 848 Answers
Hi
provide more information about your problem...........
  • gopinath pasupathy Feb 11, 2009
    have you done any firmware update .......initially try reset - Just unplug the power cord leave the unit disconnected for 30 minutes and plug the power chord to the unit and it resets the unit ......
How do you set the clock
Hello
To set the clock to your SV-dvd 3E:
Your DVD-VCR contains a 24-hour clock and calendar used to:
Automatically stop programme recording
Preset your DVD-VCR to record a programme
automatically
You must set the date and time when:
You purchase the DVD-VCR
Do not forget to reset the time when you change
clocks from winter to summer time and vice versa
[1] Press SETUP on the remote control.
Result: The MAIN MENU is displayed
[2] Press the corresponding up/down button or Forward/Reverse buttons to select the
CLOCK SET option.
[3] Press the ENTER button to select this option.
Result: The CLOCK SET menu is displayed
[4] Press Reverse or Forward button to select the hour, minutes, day, month and year.
Result: The option selected flashes
[5] Press the Up/Down buttons to increase or decrease the value.
Result: The day of the week is displayed automatically
You can hold the Up/Down buttons down to scroll more
quickly through the values
[6] On completion, press RETURN twice to exit the menu
OK.
Oct 10, 2011 | Samsung SV-DVD3E DVD Player/VCR
Dvd recorder
The following should give you access to a service menu containing controls for macro-vision and region coding. You can change the regional settings from there.
1. Set your player to Standby
2. Press Title, Clear and Power
Jul 05, 2008 | Sony RDR-VX525 DVD Recorder/VCR
We have a philiips dvd recorder, but unable to
switch tv to the input mode you have conected dvd to e.g ( AV or EXT ) if dvd is a recorder one have you put areal in back and tuned in dvd recorder
Nov 28, 2009 | Philips Televison & Video
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
Dvdr tray
You have one of the following problems:
  • The device freezes and does not react anymore to the remote control commands.
  • The DVD is stuck in the tray. Sometimes the message BLOCKED appears.
  • A feature is not available in the menu without any logical reason.
  • A feature of the device does not work (for example start install).
  • There is some problem with the device you cannot solve.
Reset the DVD recorder.
  1. Unplug the mains cord from the mains wall outlet.
  2. Press the POWER/ON button on the DVD recorder itself.
  3. While keeping the POWER/ON button pressed connect the main power cord to the wall outlet again. A message IS TV ON? or a demo message will appear in the display.
  4. Start the first installation process.
Notes:
    1. The settings of the DVD recorder will return to their default settings. Install the DVD recorder as if it came out of the box.
    2. The data on the hard disc will not be affected.
Apr 28, 2009 | Philips DVDR7260H DVD Recorder / HDD...
Can play video, but can't record
Have you tried to record your channels with the converter switch set to antenna?
In otherwords;
Step 1. With your converter switch set to converter mode select the Direct tv channel you wish to record.
Step 2. With your converter switch set to antenna press the record button on your DVD Recorder.
Step 3. Switch your converter switch to converter mode.
I hope that you find this solution helpful.
Feb 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Leaves blank TV screen when Return button operated
It sounds as though the unit is actually recording a DVD, but is getting no incoming signal to record. What is your recording source? Satellite and receiver? Antenna? Cable box? In the set-up menu, be sure you have chosen the proper input source; i.e., recording from where? You may be able to access that menu through the Function button on the remote, AFter setting that menu, be sure to press Return to restore the recorder to the ready mode. If you are using the RF input for recording, be sure that is selected as well, as opposed to L1 or L2. The input channel must match the output channel on your receiver, usually channel 3 or four. What is the model number?
Dec 02, 2008 | Sony RDR-GX300 DVD Recorder
Centrios DVD Recorder
Setting the clock
1. Press SETUP in no disc mode or full stop mode,MENU screen
appears on the TV screen.
2. Using v select SETUP MENU, then press ENTER or >,
BASIC SETUP is highlighted.
3. Using v to select “Set Clock ”, then press ENTER or >,
“Set Clock Setup ”screen appears.
4. Press</>/^/v repeatedly (or numeric buttons) to set the
date and time.
5. Press > to select “Done”or“Cancel ”, and then press ENTER ,
BASIC SETUP returns.
6. To exit, press SETUP.
7. Press POWER to turn off the unit, the clock appears on
the VFD display.
link to manual http://www.centrios.com/content/support.aspx?language=en-CA#
Mar 03, 2008 | Centrios EDW8020 DVD Recorder
Sylvania SRD4900 DVD/VCR combo problem
Hi I am Temperance MI and I see this mode in my shop often, does any onscreen menu come up when using the remote and
going into menu? If not maybe the remote is bad, common just
a loose battery lead, If you are able to go into menu, and set the
clock, but unable to set timer record, look closely at you recordable tape to make sure on the left bottom from corner the
the recording tab is in place, You can place scotch tape over this hole of existing tab to ensure it will go into record. Finally
if it wont go into record when you try to use OTR, you
make a problem with the record ready switch in the VCR section. Joe . East Electronics, Temperance MI
Jan 23, 2008 | Durabrand DUR7 Portable DVD Player
Turning on VCR for 2nd time recording
Have you fixed your problem?
If not, just try pressing the dvd/vcr button, so the vcr becomes the primary device. Now you can press setup and go back into the vcr menu.
Nov 11, 2007 | Toshiba SD-V394 DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
