Question about Sony Digital Photo Printer DPP-EX7 Thermal
Paper tray removal
As the print cartridge is over, and so is the paper, I need to put a new pack of paper in the tray. However the tray does not come out for me to fill it. How do i get it out? Please help
I managed to do it on my own. It was just a bit tight and I was being too gentle thinking it would break. Finally I got fed up and just yanked it out.
Hurray.
Anooseth
Posted on Feb 14, 2009
Printing blank pages
Hi Wendy,
This is known issue with Canon printers. Try the steps below.
Instructions
    • 1
      Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
    • 2
      Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
      • 3
        Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
      • 4
        Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
      • 5
        Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
    Regards,
    Suhail
    May 20, 2012 | Canon PIXMA iP1600 Printer
    HP Photosmart C6100 All-in-One
    Just click below;
    Set Up the Printer Hardware
    Remove packing materials, check contents of the box, connect the power cord, set the menus, load paper, and install the print cartridges. s.gif » Product Specifications
    Minimum system requirements, connectivity, print cartridges, specifications for print, copy, paper, print margins, paper tray capacity, memory card, scan, physical size, power, and ... s.gif » Printing Instructions for 4 x 12 and 5 x 7 Inch Paper
    Generic printing instructions. s.gif » Creating Borderless Photo Prints with the HP All-in-One Software
    ... 4 by 6-inch photo paper with tab (snapshot paper) ... Remove the paper from the paper tray and load the snapshot paper. Insert tabbed paper with the perforated, tear-off ... Click Photo Prints . The HP Photo Prints window will appear. ..
    hope this may help;
    Regards,
    VOTIT
    Jul 31, 2008 | HP Photosmart C6100 All-In-One Printer
    Tell me please hp laserjet printer 2420 paper tray setting
    1. Remove the packing material from the printer.
      1. Remove the all orange tape from the outside of the printer.
    1. Load all paper trays.
      1. Pull the paper trays completely out of the printer.
    2. Press the blue tab on the rear paper length guide and adjust the rear guide so that the pointer matches the size of the paper to be loaded. c00318778.gif
    3. Move the side width guides outward to match the desired paper size. c00318779.gif
    4. Add the media to the paper trays, make sure that it is flat in the tray at all four corners. Keep the media below the height tabs on the sides and rear of the tray. Push down on the metal lift plate to lock it in place. c00318780.gif
    6. Install the print cartridge.
      1. Remove the print cartridge from the packaging.
    7. Rock the print cartridge back and forth several times to "mix" the toner. c00318783.gif
    8. Pull the sealing tape from the end of the print cartridge to remove the entire length of the tape. c00318784.gif
    12. Connect the LAN cable (optional). (HP LaserJet 2420n, 2420dn, 2430tn, and 2430dtn models only) c00318788.gif
    Jan 13, 2011 | HP LaserJet 2420 Printer
    Every page printed has a wrinkle pressed into the paper
    Its or moisture issue or wrong pressure between fixing roller and press roller.
    Jun 30, 2010 | Office Equipment & Supplies
    My printer is only printing half the picture, one half comes out great and the other half has nothing
    1. Remove the power cable from the printer.
    2. Remove the paper tray from the printer.
    3. Remove the paper from the paper tray.
    4. Verify that the paper you're using has KODAK XTRALIFE Paper
    5. Insert the paper tray into the printer.
    6. Open the color cartridge door, then remove the color cartridge.
    7. If the color cartridge ribbon is torn or damaged, replace it with a new cartridge.
    8. Install the color cartridge, and verify that it is fully engaged.
    9. Close the color cartridge door.
    10. Connect the power cable to the printer.
    11. Wait for the printer to initialize (the paper may eject automatically).
      NOTE: For the Photo Printer 500 and the G600 or G610 Printer Docks only, press the power button in addition to plugging in the power cable.
    The printer's lights turn on. And after a few seconds, most or all of the printer's lights turn off. The printer will make noises while cycling. If a paper is stuck in the printer, while the printer is making the noises, pull gently on the paper to try and remove it.
    If the problem persists cal 1800 2356325 > for a repair
    Oct 26, 2009 | Kodak EASYSHARE CD33 & Printer Dock Series...
    HP Photosmart 3200 All-In-One not printing yellow
    Step1
    If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
    Step
    Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
    Step
    If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
    Step
    If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
    Aug 20, 2008 | HP PhotoSmart InkJet Printer
    Print fragmented documnts
    Step1
    Step
    Step
    Step
    Aug 14, 2008 | OKI MICROLINE ML-395 Matrix Printer
    Light blinking
    Step1
    Step
    Step
    Step
    Jun 02, 2008 | Epson FX 1170 Matrix Printer
    Print out very light
    Step1
    Step
    Step
    Step
    Apr 17, 2008 | HP LaserJet P3005dn Printer
    Sony Digital Photo Printer DPP-EX7 Thermal Logo
    97 people viewed this question
    Top Sony Office Equipment & Supplies Experts
    shaun taylor
    Jaime Hernandez
    Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
