Question about Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
TV will not turn on unless unplugged and wait one hour then plug
This is a Nursing Home Patient, the TV is only 2 months old 19 '' Phillips Flat screen model number 19pfl3403D/F7 could it be going into a security lock mode ?? This patient may be pushing the buttons on the side to much ?? Thank you for any input.
  • casche419 Feb 11, 2009
    Thank you for your fast response. I plan to go to his room to try these suggestions, thanks.
    Social Service Dept.
    Master:
  • 474 Answers
Well, sounds like they may be changing the source from T.V. to HDMI or component/composit mode which is bassically for a C player or other connected source like a VHS or Xbox etc.
Allthough if this where the case, you should be able to use the remote to change the source back to the T.V. Antenna or cable if you have it.
WHen it goes blank or seems to be off, does anything you do turn it back on without having to unplugg it first?
If not, it could be bad, you will need to try hooking it up some where else for a while and test it without that person there and see if it the T.V. a bad outlet or the person is actually doing something.
If you think the T.V. is bad or faulty, at this early in its life, I would take it back under warranty before trying to fix it yourself.
Posted on Feb 11, 2009
Certain channels do not have sound but the picture is clear
Most of the time its not your TV its the TV stations signal. Unless you live like in a nursing home were there are a gang of cable boxes and there is an adjustment on the box it self. We have them in our faucilty.
Sep 09, 2012 | Dynex DX-LCD19-09 19 in. LCD TV
Hello-I have a 19" Philips flatscreen LCD television set model#19PFL3504D/F7. After attempting to upgrade current software via a USB flashdrive I reversed the disconnect instructions. I removed the...
connect a laptop to the set, using the usb port contact phillips on line download the old flash to the computer save the old flash download as a file and, to the usb flashdrive connected to your laptop reload the set either with the laptop or, the flashdrive unplug the set first then: remove the flash drive
Jul 17, 2010 | Philips 19PFL3504DF7 19 in. TV
The TV doesn't turn on most of the time.
When this happened to us the lamp had burned out so you might try replacing it. After several weeks of waiting for repairs we fixed it in a few minutes.
Feb 02, 2010 | Polaroid TDX-01930B 19 in. LCD HDTV
Tv doesn't turn on
Nothing you did wrong caused this problem. Most likely the power supply for the screen failed.
It's best to use the warranty for the TV to fix this problem. Because, parts and labor will cost more than the TV is worth. Here's a link to get you started on the warranty:
http://www.care.philips.com/support/contact/contact_page.jsp?userLanguage=en&userCountry=us&_requestid=24727
Jun 20, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Phillips 42" flat screen ty
Well, I spent $20 on FixYa which did absolutely nothing and now and waiting for the Phillips to show up to take my TV to their shop (which alone will cost me $100 in itself) and wait for approximately 2 weeks to find out if the fix costs more than the TV is worth, in which case, I'll be out thousands of dollars, plus $20 to you, plus the Phillips charges AND whatever a replacement TV costs.
Did that answer your question?
May 19, 2008 | Philips Televison & Video
Ws 65909
I had a half power outage where everything turned half off, how I still dont know. Anyways I unpluged it and didn't plug it back in until the next day. When I did the timer light was blinking for an hour. I unpluged it for a couple hours more, then I plugged it in and waited for 1 min, unplugged it and repeated, then I plugged it and unplugged it 3 or 4 times in a row, plugged it back in and waited. 1 min. then poof the tv worked. YAAAAAA HOOOOOO!!!!
Dec 30, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
167 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
