Question about Coleman Powermate Premium Plus 6250W Portable Generator
Has one lage burned out
Only has 110 taht will work 220 will not work
  • 52 Answers
Check circuit breaker
Posted on Feb 14, 2009
Is the Hunter portable AC High Effiency Model 31125 to be plugged into a 220 outlet only?
if the plate on the side says 220 volts then it will only work on 220 -250 volts outlet
at a 110 volts outlet it will fail and at anything more than 250 volts it will burn up
Apr 20, 2016 | Hunter Heating & Cooling
Installed turboflush300 in the Philippines and need to change 110 to 220. Can the wiring terminal be changed?
Don't forget the heating element it's 110 will burn out quickly on 220 also the electronic control same
Jan 19, 2015 | Dishwashers
110 volts 220 volts
if you lucky the fuse is burned....
in the back of the console thar a hiden fuse chack is it burnd
Dec 16, 2013 | Behringer Music
My fan burn its a 110 volt but plug it direct 220 volt i want to find out what that burn
It must be burned because the voltage requirments is only 110 volts if it goes beyond that voltage it might be that the internal fuse of the fan or either the motor is burned and itshould be recoiled or replaced.
Oct 01, 2013 | Lasko 2515 Tower Fan
WhAT HAPPENS IF I plug a 110 volt machine to a 220 outlet
Normally the plug connector would not fit, they are different. But for some reason, if you have one that takes 110 and you plug it into 220, there will be af ire. You will burn through the circuits immediately and short the entire thing out at every solder point. The real problem is the wattage. The watts are pushed with 220 volts of fource, which will fry your 110 setup.
Sep 27, 2012 | Olympus HPU-20 Cautery Unit
I bought a GE microwave oven model wes1450dm1bb at the USA, but now I am in a different conutry that uses 220 volts as standard. I just read the user manual and in any place says the voltage of the...
No, You'll burn up the appliance. When I was in Germany there were commercially available transformers to step the current down. The transformers plug into the 220 sockets and provide several 110 sockets to plug your appliance into. We purchased several transformers and ran our 110 tvs, kitchen appliances and other 110 appliances. The 220 sockets in Germany were different than 110 and 110 plugs sould not fit.
Feb 23, 2011 | Ovens
I bougth reciprocating saw, model BJR 182Z and circle saw, BSS611Z while I was in the U.S.A.These tools use the 18 volt LXT Lithium-Ion battery BL 1830. I also bought this battery.However I am going to use...
Why can't you buy the 230 volt DC18RA charger in europe (amazon.europe country) and use it. I had the same issue yet i burned out the fuse in the 110 volt DC18RA charger because i plugged it into the wall just using an adaptor. Lesson learned. Therefore, my first solution was that i bought a converter from 220V-to 110 Volt. This showed me that my charger was done. So instead of getting another 110 volt charger sent here to Europe from Canada, I returned the converter and have on order a 230 volt input DC18RA charger from amazon.de which has the same 7.2-18V output. I have been told this will work yet the fear, and I don't know why, is that it will burn out the batteries in a year or so. It is difficult getting specific information from Makita, but I hope it all works out. Best of Luck for you
Dec 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
220 volt was applied to motor due to faulty 220/110 V adapter. How can I troubleshoot motor
The first thing to do is smell it. If it smells burned, it is probably fried. If it isn't working after being plugged into 220, there won't be a fix. Armatures & field coils aren't available for these.
Nov 07, 2009 | Dremel 300-N/55 300 Series Tool Kit
Plugged a 110 volt kenwood receiver accidentally to 220 volts
Considering 220 and 110 systems have different receptacles, you worked at doing this.
Since it is already inoperable, you may as well remove the housing and inspect the guts. If you see burned traces or boards, don't bother to have it repaired.
If you see a fuse in a clip, you might replace it once, two would be the waste of the second fuse.
Aug 23, 2009 | Harman Kardon AVR 135 Receiver
Wii power source probably broken
Plug something else into the adapter to make sure it works, if it works you may have blown the Wii's fuse which will need repair.
Jul 28, 2009 | Nintendo Wii Console
Coleman Powermate Premium Plus 6250W Portable Generator Logo
61 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
