Question about A4tech PK-635 Webcam
I cant see an image at my a4tech pK635
When i launch the software i cant see an image and a message appeared, "no capture device". What should i do
Fhccf ubogyhi bgkvhtm ffyyyyyyyrffhvgf
Posted on Feb 13, 2009
How to get A4tech PK635 installer for free?
Here are the two most updated driver for your a4tech web cam and the manuals to help you install your web cam.
1. A4TECHPKDrivers.rar
2. PK635.zip
3. A4TECHPK-635TroubleShootingManual.pdf
Good luck.
May 21, 2010 | A4tech PK-635 Webcam
How to install a4tech pk635 web cam in my pc
you can follow this simple steps to install your a4tech pk635 web cam :
Read the installation instructions completely before attempting to install the camera. Although this may seem tedious and unnecessary, it can save time and headaches in the long run.
Back up the computer's hard drive just to be safe. This will allow for a speedy recovery should the installation mess up the computer.
Install the webcam software with the disc that came with the camera, check the Internet for an updated version of the software and download that if available.
Plug in the webcam. The software should give a prompt at the appropriate time. Cameras are usually installed with a USB cable. If installed correctly, the computer will acknowledge so by popping up a message saying it can see the new device.
Download an instant message program if using the web camera for chatting.
Apr 10, 2010 | A4tech PK-635 Webcam
Device does not display image upon opening instead a box appears that says no video capture hardware
Uninstall webcam software
Disconnect webcam
Restart computer
Install software from here
http://www.a4tech.com/ennew/support.asp
Run diagnostic check
http://www.download32.com/webcam-diagnostics-d35065.html
Oct 15, 2009 | A4tech Computers & Internet
No video capture
Test your webcam here by hitting "Allow" in the top window and assess the picture in the left hand panel.
http://www.testmycam.com/
If its ok you know your software is at fault
Download and run this diagnostic webcam tool and check the results
Sounds like a driver problem - you can expand the 'imaging' file in your Device Manager and right click on your webcam text - update driver via the internet when prompted.
Further assistance / drivers are available at A4Tech support
Aug 06, 2009 | A4tech PK5
Install A4 tech PK635 M web cam without cd installer
Hi, The drivers and software are available for free download from the manufacturer. Click the link below and the save the file. When it's done downloading, open the file and run the installer/setup file. http://www.a4tech.com/ennew/driver/CameraA.zip Chris
May 31, 2009 | A4tech PK-635 Webcam
How do i capture audio along with video?
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Mar 01, 2009 | A4tech PK5
Problem installing my a4tech-pk635
Hi Chebang and others This may be the result of having a step fail in the installation process. You can get the downloadable driver at the below weblink. Download and install it from the link below and then try again. If you have trouble figuring out how to work it just comment back here. Chris http://www.a4tech.com/ennew/download%20driver.asp?cmodnum=PK-635
Feb 12, 2009 | A4tech PK-635 Webcam
What do i do
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
2) Resolving the problem
1. Plug the USB cable into the camera and Macintosh again.
* If you are using a USB hub, do not connect the camera to the Macintosh via the hub.
1. Select "Other".
2. Click the "Applications" folder.
3. Click the "FinePix Viewer" folder.
4. Select "FPVBridge" and click "Open".
5. Click [OK].
1. Launch FinePix Viewer.
2. Select "Automatic Save Settings" in the Settings menu.
3. Tick the "Auto save images when the camera is connected" checkbox in "Operation Settings When Camera Is Connected".
4. Click [OK] and close the "Automatic Save Settings" window.
5. Exit FinePix Viewer.
6. Turn the camera off and then on again to test whether FinePix Viewer launches automatically.
Apr 28, 2008 | Fuji FinePix S5700 Digital Camera
http://www.a4tech.com/en/driver/PK-5(35n%20635%20935%20735%20835).rar
1. Download this file.
2. Unplug your camera from computer.
3. Extract the file using WinRAR.
4. Open the extracted files and launch setup.
5. Follow the on-screen instructions.
6. After installation is finished, plug-in your camera to the USB.
7. The device should be detected automatically.
Hope this answers your question.
Apr 10, 2008 | Computers & Internet
A4tech PK-635 Webcam Logo
71 people viewed this question
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
