Question about Syntax SVM266A (SYSVM266A) Motherboard
Motherboard Pinout - Please Help
Hello all,
I'm having a problem with the pin out on my svm266a motherboard. If anyone know where I can find a diagram with the pin out configuration, I'll be grateful. The cables on the front panel connectors are: M/B SW, POWER LED, HDD LED, RESET SW, 2 cables labeled GROUND, and two cables labeled +5 -D +D. I need to see how/where these cables are connected on the board so I can have my PC back. Thanks to anyone who can/will help!
  • 1,602 Answers
Here are some sites that may help you.
all these should be marked power switch may say pw,prs,ps, power led may say pld, pl,led, hhd say hd, reset switch maysay rs, set, these connection will be grouped together, and pin layout 1 red or hot wire, or the main wire for the device you are trying to operate.
www.motherboards.org
www.tomshardware.com
www.twinight.org/chipdir/
www.anandtech.com
the connections to the back plate is standard the amount of pins match up the cable, the number 1 pin will be marked some how and or the cable will only be able to plug in one way.
with an exception if you are using serial connector and we hardly use them. the rules are the same as above, and plug ins maybe one way also.
the ribbon type will have a marking on the cable or ribbin line or dots or hasshs marks that is pin #1
match with pin out on motherboard pin1 or pin 0,
rod
Posted on Feb 11, 2009
Front panel pinout connections for ASUS A8M2N-LA (NodusM3
The Asus A8M2N-LA motherboard was made SPECIAL for HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757531&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3339286
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00820191&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3339286
As such Asus has no info on it.
Looking at the second link posted (Motherboard Specifications), scroll down to the bottom, and click right on - Motherboard Layout
Motherboard layout shown (Direction), is the same as is installed in your computer; Processor to the Top, white PCI slots to the Bottom, Ram Memory to the Right.
The plastic front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the cables (Wires) go to from the Front Panel, is the Front Panel header.
Abbreviated F_PANEL 1, at the bottom right corner of the motherboard, is the Front Panel header.
There are 9 contact pins. Two rows.
Across the Top row they are numbered ODD.
Across the Bottom row they are numbered EVEN.
Coming from the Left side of the motherboard towards the right side, on the Top row;
Pins 1, 3, 5, and 7
Coming from the Left side of the motherboard towards the right side, on the Bottom row;
Pins 2, 4, 6, 8, and 10.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive wire. ( + )
If the HDD LED is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive wire.
D) Pins 6 and 8 are for the Power On switch.
Regards,
joecoolvette
Apr 10, 2012 | Gigabyte Computers & Internet
I'm having trouble with the pin out connections on a syntax motherboard. Where can i find a diagram?
Align the motherboard in your mind, so that we are both looking at it in the same direction;
Processor to the top, Ram Memory slots to the right, the four white PCI slots to the bottom.
The plastic front of a desktop computer is the Front Panel.
The area of pins on the motherboard, that the cables (Wires) from the Front Panel go to, is the Front Panel header.
The Front Panel header for the Syntax SVM266A is below the IDE 2 connector. It is labeled Panel 2
(Harddrive plugs into the IDE 1 connector, optical drive/s plug into the IDE 2 connector)
Panel 2 is mounted horizontally. It is parallel to the IDE 2 connector.
There are 4 pins across the Top row, and 5 pins across the Bottom row.
The pins are numbered. Even across the Top, Odd across the Bottom.
1) Starting from the Left side going towards the Right, for the Top row;
Pins 2, 4, 6, and 8. There is no Pin 10, just a blank spot.
2) Starting from the Left side going towards the Right, for the Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 2 and 4 are for the Power On LED light.
If the Power On LED light is dim, switch the wires around.
B) Pins 6 and 8 are for the Power On switch.
C) There is no Pin 10
D) Pins 1 and 3 are for the Harddrive activity LED light. (HDD LED)
Pin 1 is for the positive wire.
If the HDD LED light is dim when operating, switch the wires around.
E) Pins 5 and 7 are for a Reset switch, IF a reset switch is used.
As for a motherboard manual,
http://web.archive.org/web/20060206024804/http://www.syntaxgroups.com/support/downloads.php
Scroll the page down to about 3/4ths the way down, until you come to the bold heading -
SVM266A
Click on Manual.
This is a PDF file. It may take up to 30 seconds before the first page comes up, and additional time for the file to fully download.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 16, 2011 | Syntax SVM266A (SYSVM266A) Motherboard
What speed,or memory that runs best in a syntax svm266a m.b.
The pc3200 would be best.
Do not mix different speeds together.
I'd go with the max of 2gig.
Mark
Mar 28, 2009 | Syntax SVM266A (SYSVM266A) Motherboard
I NEED THE PIN OUT DIAGRAMS FOR K9N6PGM2-V MOTHERBOARD
Hi, here's the link for the manual, with the pinout diagrams:
http://global.msi.com.tw/index.php?func=downloadfile&dno=6801&type=manual
Please rate if you find this helpful :)
Mar 16, 2009 | Computers & Internet
PC Chips M955G Motherboard Front Panel Pinout
i suggest to find in website..www.Fixya.com
if not found..post it again so that we can suggest another site.
thanks
Jul 25, 2008 | Mercury P4VM800M7 Motherboard
Pinout diagram
Mail sent.
For anyone else.. Visit the motherboard's online manual via their website.
Nov 13, 2007 | Gigabyte GA-7IXE4 (GA-71XE4) Motherboard
Computers & Internet Logo
367 people viewed this question
Top Syntax Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Steven Burn
Steven Burn
John Anderson
John Anderson
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
