I have a Toshiba 1800-514 with a built in DVD player. My problem is that it will pay Music CD's and Data CD's but will not play any DVD's please can you help
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Almost always, the problem is lens related. In some models, there would be 2 sets of laser system; 1 for CDs and the 2nd for DVDs. You could try cleaning using a CD disc cleaner embedded with a tiny brush to 'sweep' across the lens assembly. In some instances, a spray of compressed air could also help clean the lens. There would be occasion that it may be required to open the DVD unit and manually clean the lens using a cotton bud.
Worst case scenario is cleaning or replacement of the optics assembly. Repairs would be economically reasonable if done DIY (do-it-yourself). If you would be seeking the services of a computer/repair tech, perhaps you should also factor in the repair cost, downtime and efforts involved. Should repairs be no longer justifiable, you may want to re-evaluate your options and consider replacing the DVD drive.
Hopefully cleaning should address the issue.
Good luck and thank you for using FixYa.
Posted on Feb 11, 2009
  • 837 Answers
Follow my colleague ginko's advice
    Master:
  • 848 Answers
lens is dirty ........clean the lens using the lens disk cleaner...........still problem continues the laser head is not picking up the disc...........need to replace laser assembly.......
    Genius:
  • 3,422 Answers
HI,
Please reinstall your dvd player drivers from device manager option.This will fix the issue.
  • Priya darshan Feb 11, 2009
    To do that right click on My computer icon and click on properties,a window will open just select the Hardware tab and click on device manager.(procedure is for xp).If you have vista then right click on My computer icon and click on properties,a window will open and on the left side you will see device manager.click on that and the device manager window will open.Next double click on the dvd/cd rom drive you will see the name of your player,right click on it and click on uninstall.If it a window popup's asking you to remove the cd/dvd drive click on 'ok' then restart your Pc/laptop and load a dvd disc.Let me know if it plays the dvd or not.
    If you still face the problem then:
    see if the player tries to read the disc. Load a disc and listen.
    Does
    the player make squealing noises or is it totally quiet? Squealing
    noises may indicate that the player is trying to synchronize with the
    disc but can't due to an obstruction on the lens or in the laser path
    inside the pickup or a defect in the pickup. This can also be caused by
    an intermittent signal problem due to a faulty ribbon cable.
    Totally
    silent means that the photo sensor is not getting any usable input from
    the laser at all, meaning that the pickup is "blind" for lack of a
    better word.
    This can be caused by an obstruction of the beam by
    foreign matter on the lens or inside the pickup all the way to a
    marginal or failed laser diode and/or photosensor array. This can also
    be caused by a bad ribbon cable with one or more severed traces.
    You
    could try to clean the optics. This is the most common malfunction as
    far as i know in all disc players. It would involve taking the cover
    off and finding a way to expose the lense, and then cleaning it with a
    very gentle brush. some players have a cover for the lense that swings
    to the side during playing, this greatly reduces the chance of dust
    accumulating, but its still worth the try.
    If you actually see dust on the lense, then its just that simple. clean, close, play.
    It may also be worth your while to check on the small shafting that
    guides the carriage of the laser pickup. Dirt, grome, dust and
    solidified lubricant can cause stoppage of the carriage and the laser
    eye then fails to read the next track.
  • 19,396 Answers
That is because of dirty lens.
Why toshiba l305-s5945 media player not playing cd
Possibly it is in the wrong format. Download vlc media player, that will play anything and will let you know if the DVD player is faulty or bot.
Jun 14, 2014 | Audio Players & Recorders
Problem
first you most clean the laser with alcohol and try again or change the region code on your DVD player.......
Jun 13, 2010 | Coby DVD-215 DVD Player
When I want to copy a CD must I only record on a CD blank disc; i.e. not a DVD
It depends upon what type of data you want to copy onto a CD or DVD.
If you want to copy and play music in a CD player then it needs to be on a CD disc.
If you want to copy and play movie DVDs in a DVD player then it needs to be on a DVD disc.
If you want to backup data files then it can be on either CD or DVD discs (depending upon the amount of data to be stored on the disc - CD holds 700 Mb, single layer DVD holds 4.7 Gb, and dual layer DVD holds 8.5 Gb of data).
A DVD player can read both CDs and DVDs, but a CD player cannot read DVD discs.
Dec 30, 2009 | Dell Insprion 4F778 (4F779) DVD Drive
Sony Q58A will play DVD but not audio cd or data cd. Help!!!!!!!
Are you sure that you have the file type associated in your Windows operating system to a Music player like Windows Media or iTunes? This may be the most common reason that music CDs won't play.
Sep 16, 2009 | Sony DWQ 58A 8x8x4 Slim DVD RW w/ NTI DVD...
DVD player won't play DVD, says "load"
The unit can recognize that a disc has been loaded but can not read the contents. This can be as simple as a dirty lens or more drastic like failing optics. Try cleaning the lens using a cotton swab and alcohol. If that fails to correct the problem and a music CD will play OK, then the optics are failing. DVDs require more laser power to read than a music CD.
Dan
Feb 04, 2009 | Toshiba SD-3990 DVD Player
Dvd player refuses to read any disc I load into the machine
Hello I was looking to try and help you with your DVD player, we will start by loading a music cd store purchased, no burned cds please, if the cd loads and plays then your dvd player is either out of adjustment or going bad, most dvd players, i have worked on, will load and play a music cd, but will show loading errors when trying DVD's. If the music cd dosen't load then there could be an issue with the drive or tray. If the music cd plays just fine, then your laser is either out of adjustment or going bad. You can call the manufacuter to see if there is a process for resetting the DVD player, not all DVD players have this option, if resetting the DVD player dosen't work, but music cd's do then your laser lens is dirty or going bad. At this point you have three options 1) Take it to a repair shop, 2) Get an new one, 3) Get your hands dirty if your really handy and know what your doing to clean and replace the laser. I hope I can be of further assitance and I look forward to helping in the future, Thank You and have a nice day.
Jan 14, 2009 | Televison & Video
Dvd player RCA DRC245NTV
did you try cleaning the eye with alcohol?
May 31, 2008 | RCA Televison & Video
Meridian 586 DVD/CD Player
If it reads data it will read music (which is only data!)
Do you have a Music Program installed? The type of program will depend on whether the music is in CD Audio format or is in the MP3 format.
Windows media player should be able to read Audio CD's (but I don't think it will read MP3's). If you are trying to play a CD encoded as MP3 then you will need to search for a program that plays MP3's (there are many free ones on the Internet.
If it will not read Data, then buy another unit and install it (they are terribly cheap nowadays and uneconomical to repair).
Good luck.
Apr 21, 2008 | Computers & Internet
TOSHIBA HDDVD PLAYER A20
I have a problem like this but mine will play regular dvd's
and just stop playing hd dvd's . exact same message
gene
mrjazz1959@gmail.com
Nov 03, 2007 | Toshiba HD-A20
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
