Question about Kenmore 62622 Microwave Oven
I have a Kenmore model 665.68611891 micro. The door pops open
The door keeps popping open during cooking causing the oven to stop. Is there an adjustment? If so where is it? Thanks.
    Novelist:
  • 140 Answers
Per se there is no real adjustment, but the linkage that holds the two nylon hooks on the door in may need to be lubricated with some lithium grease made for nylon or neoprene parts. The sliding neoprene part that holds the hooks in place is not sliding all the way down into position. That part once you take the cover off is right up against the right front hand side of your microwave exactly inline with the two hooks and next to the control panel assembly. Take the cover off and manually opening and closing the door you will see how that part moves up and down to release and secure the door in place. You will be able to see where to apply the lubricant which should be anywhere two or more nylon or neoprene parts rub against one another. Let me know how it goes or if you need more guidance.
Posted on Feb 11, 2009
Food not cooking in center
What make and model?? Sounds like it is not a carousel model. Have you tried a "Micro Go Round" ?? Otherwise, try rotating the 'plate' each quarter cycle...ie; every 30 seconds on a 2 minute cook time. Be sure to push the stop button first before you open the door to save wear and tear on the door switches......
Nov 04, 2013 | Microwave Ovens
The microwave wont respond to the timer. It keeps cooking unless you open the door. After the timer runs out it seems like it cuts off but there is still a low buzzing sound and it is still cooking. Have...
low buzzing can be a power relay or a (solid-state)
triac which both supply power in their own right to the power transformer to operate the magnetron tube,even though you say it quits cooking when you open the door,i would still check the micro-switches in the door for proper alignment and operation, because it can be a door switch mis-alignment or a leaking triac still supplying power to the unit
Jul 14, 2010 | Kenmore Microwave Ovens
The other day my microwave quit cooking and the turntable stopped turning. The fan still turns on and the light still works as if it is cooking but it doesn't. We shut off the power and tried again but it...
It may just be a bad door switch. See this file.
You can enter your full model number at the Sears parts site to find helpful exploded view diagrams.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########.
May 27, 2010 | Kenmore 62622 Microwave Oven
Model JVM130G
what brand is this and did the light go on when the door was opened before you changed the bulb?
Jun 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ewave kot-131UB pops breaker
Yes, this is caused by either a bad door switch or a loose door or loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 13, 2008 | Kenmore 80412 Microwave Oven
Keypad only works
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Dec 22, 2007 | Kenmore 62622 Microwave Oven
OLD Kenmore Microwave Oven
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
Dec 05, 2007 | Microwave Ovens
Runs but wont heat up
Probably magnatron is bad. Best test is to substitute a known good one. There are others but you are in the 4000 volt area of the unit.
Aug 06, 2006 | GE JES1039 Microwave Oven
Kenmore 62622 Microwave Oven Logo
100 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Ed Mac
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
