Question about Cadet Manufacturing 09954 Baseboard Heater
Heater is excessivly noisy, can be heard over tv
6' baseboard heater 120v is very loud and cycles about every 15 mins. Is there a fix to this problem, my other heaters do not do this.
  • enerkem May 11, 2010
    is the thermostat being used 120 volts as well or just 24v?
    Problem Solver:
  • 12 Answers
First, my research into the Cadet model #09954 is a 240v unit. if it is wired to only 120v that may be your problem. I am not even sure it work work on 120v.
Posted on Sep 29, 2009
How to set heat for baseboard heat
They use a 120v thermostat you should be able to buy one wherever you bought the baseboard heaters. Be aware those heaters costs a lot of money to run and dry out your house like a desert buy a few room humidifiers when you get the thermostat. Make sure you use the correct size wiring to the baseboard heaters and the Tstat if you undersize the wires for the breakers involved you'll more than likely cause a electrical fire.
Oct 01, 2014 | Honeywell Heating & Cooling
I have baseboard heating and not sure if i bought the right thermostat there is a switch inside fir gas/oil or water pump/elect. modle # rth2300/rth221
No. Baseboard heaters will use a 120v or 240 thermostat. The thermostat you have is for 24v low voltage only. Hope this helps!
Dec 08, 2013 | Heating & Cooling
I need to wire a remote thermostat to my electric wall heater in the bathroom. Not sure if I run the wire from the panel to the heater first or to the remote thermostat then the heater.
Run the wire to the thermostat then to the heater
BASEBOARD WIRING WITH A SINGLE POLE (2 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLY
BASEBOARD WIRING WITH A DOUBLE POLE (4 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLYdennis675_0.gif
Jun 21, 2011 | Heating & Cooling
What is the recommended circuit breaker for a 220 volt connection to a 6' baseboard heater
depends upon wattage of baseboard. I would guess about 20 -30 amps. Amps = Watts/Volts. Example, 1500 watts/220 volts = breaker size of 6.8 amps (add 25%) The only breaker available is a 15 amp breaker.
Oct 05, 2010 | Heating & Cooling
The baseboard is very noisy? Humming sound
there are clips that hold the actual element inside the enclosure.check to see they are loose or broken. a small amount of humming noise is normal while the heater is being energized expansion/ contraction of alumimun fins is normal.
Feb 19, 2010 | Fahrenheat FBE15002 Baseboard Heater
Loose power when turing it on
sounds like it is wired incorrectly at the baseboard heater. BUT if it worked correctly before this, then you may have a bad thermastat. Wiring in two baseboards into one thermastat is a bit tricky, each time I do it I have to think it thru before hand to get it right. IF it has never worked right, again you probably have it wired in wrong at the baseboard.
Dec 14, 2008 | Electric TPI CORP TBS BASEBOARD HEATER...
Electric baseboard heater
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Jan 05, 2008 | Fahrenheat FBE15002 Baseboard Heater
Cadet Manufacturing 09954 Baseboard Heater Logo
214 people viewed this question
Top Cadet Manufacturing Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
