Question about E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply
No os found
When I put the win xp cd in cd/rom it won't run
    Problem Solver:
  • 11 Answers
You need to make sure that the computer is booting to the cd/rom. I think on an e-machine that you have to hit F-10 when the big e-machine splash screen appears and then choose cd-rom.
Posted on Feb 11, 2009
I have problems with my asus p4c800 mothterboard, i can not boot in dos mode with a bootable usb stick made with win98 kit (on ather pc's my stick does well), i can not install win xp from cd, my...
No your motherboard is doing just fine. you cannot install OS to your hard disk from another computer that don't have the same spects like yours, The program won't initialize properly, or like what you said it would freeze. The only way fro you to be able to install an OS to your computer is to buy an external usb cd/dvd. If you have one, then we can proceed, enter the bios setup by pressing the delete or f2 key. Then set your settings from boot option ( primary boot ) select or change it by pressing Pg Up or Pg Dn to boot from a usb cd/dvd rom press f10 to save your setting or select save and exit settings. Then press y and press enter. From there your system will automatically boot starting your OS installation setup. Have a nice day friend and i hope this would solve your problem.
Aug 18, 2011 | Computers & Internet
I have a pc, model dell optiplex 360. i got a hard disk. i install to the pc and then try to install the win xp os. i had set the boot seqence to decect the cd room first. but the pc not detect it. so i...
Ensure the disk and ROM compatibility.
check the CD/DVD in other drive and vice versa (another CD/DVD in PC CD/DVD ROM.
then ensure the booting sequence in BIOS setup. if every thing is ok and fine then the problem is with your CD/DVD ROM.
vote me if found helpful.
Aug 06, 2011 | Dell OptiPlex GX260 PC Desktop
Nightmare ned CD/ROM
This software was released long before Win7 was being worked on. Thus it isn't going to work directly in Win7; Microsoft has changed a lot in the OS. However, with a bit of work and either Win7 Pro or Ultimate, there is a workaround. Install the XP mode program from Microsoft (it's a two download process) and create a virtual computer inside your main computer. You should be able to install and run the game within the virtual computer.
I hope this helps.
Jan 24, 2010 | Microsoft Windows XP Home Edition
Task manager in win xp keeps blinking, it will not closed, no matter what i push nothing, plus win xp keep freezing any solution how to fix this problem
VIrus infection?
to check and secure u need:
win-xp cd or other bootable win-cd, seperate up-to-date antivir software on cd or usb-stick,
your passwords
procedures:
boot system from cd/dvd (do not bother if screen resolution is different from usually),
exit windows-setup,
insert antivir-cd or stick, run full system scan.
found infections? remove/erase these files(antivir will do that for you)
if possible, back-up personal data (my folder, music, save games, etc.)
this data has to virchecked by another protected system before reinstallation !
boot from win-xp cd-rom, run setup until repair options are available,
repair your xp on harddisk(xp-will do that mostly), exit setup without installing win xp anew
boot system from hd, ignore error messages, run vircheck again.
if you're lucky, this will do, else lemmie know
Jun 13, 2009 | Dell Inspiron 6000 Notebook
IBM ThinkPad 600E trying to put os on it
that is correct.. IF you are using windows 2000 the files are NOT the same as the files under XP.. Your best bet is to EITHER install the complete XP or find the win2k installation disk,, even an upgrasde disk for win 200 can be found probably around 100.00. IF the system isn't booting from your XP disk IS Your disk an ORIGINAL or a copy of the original?.. If for example your CD rom is drive E then see if you can find a win XP emergency boot disk and access the CDROM goto e:\windows\i386 then run the setup program, many cases this will overwrite your existing OS.. but do so at your OWN RISK I will not be accountable if you lose any of your important files.. some win98 emergency boot disks can access the cdrom but you may have to make certain additions to the autoexec.bat and/or config.sys files. be careful when using DOS because you can completely delete EVERYTHING on the HDD if you use the right command(s). As A DOS BABY I have performed many lazarus miracles but I have been using dos since the early 70's
May 22, 2009 | Computers & Internet
Slimtype Combo LSC-24082K does not recognize audio/program software
  1. Click Start, click Run, type regedit in the Open box, and then press ENTER.
  2. Locate and click the following registry key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom
  3. To enable automatically running CD-ROMs, change the Autorun value to 1.To disable automatically running CD-ROMs, change the Autorun value to 0 (zero).
  4. Restart your computer
Dec 31, 2008 | Computers & Internet
No OS FOUND on my Pavilion a1600n (preinstalled Win XP) can I install Win XP Home Edition I bought. My recovery disk will not work.
boot with win xp setup disk.
set first boot devic as cd drive then insert win xp disk into it.
then follow wthe procedure .try to repair os win xp .if it is not found bye setup go to recovery console run this command: CHKDSK /r
then wait untill cmd probmpt.
ten u can repair win xp
Sep 15, 2008 | Computers & Internet
Repairing Windods
plz put your os cd in the cd rom and boot through it, when repair option for the first time came dont accept and proceed for total instalaion then again the repair option will come then you have to accept it and your system will be repaired.
Jul 02, 2008 | Computers & Internet
E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply Logo
79 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
