Question about HP Scanjet 5590 Flatbed Scanner
Can the default numbers be removed from scaned file name?
I name my documents specifically for upload into a web program. The Scanner is adding 001, 002, etc to the end of the names. Cane this be stopped?
I didn't know you had to pay for a solution. How about you pay me and I'll tell you how I fixed it.
Posted on Feb 12, 2009
How to upload products
How to upload products -
While listing products on Amazon is a great way to sell your products and expose them to millions of customers, adding multiple items to your merchant account can be a time-consuming process. Instead of adding products one-by-one, sellers with Pro Merchant Subscription accounts can use Amazon's tools to upload product details in bulk.
1. Download Amazon's pre-built inventory file template from Amazon.com that fits your product category. This template is a Microsoft Excel file. You can use free programs such as Apache OpenOffice Calc and LibreOffice Calc to open and edit the file if you do not own Excel.
2. Open the template in a spreadsheet program. Each template has detailed instructions specific to your product category at the top of the document. Carefully read the instructions before entering your product details so you do not make any mistakes.
3. Print the "Data Definitions" tab in the spreadsheet. This worksheet includes important details on the acceptable values and formats you can enter into the template. Keep it handy as a reference when filling out the template.
4. Add your inventory items to the template. Pay close attention to template columns to make sure you enter product details in the correct cell. Enter details such as SKU, product ID, title, brand, manufacturer, description and more. You can also add bullet points to expand on the description of your item in the cells labeled "BulletPoint1," "BulletPoint2," "BulletPoint3" and so on.
5. Save the file in the .xls format when you are finished entering product details. In Excel, OpenOffice Calc and LibreOffice Calc, select "File" from the program menu, then click "Save As."
6. Save the file again as a tab-delimited .txt file, per Amazon's instructions. This is the file format needed for uploading on Amazon.com. If a dialog pops up that says the file format does not support files containing multiple worksheets or something similar, click "OK." If another warning says the document contains features incompatible with the file format, click "Yes."
7. Log in to your Amazon seller account. Click "Upload multiple items," then select the template type for the file you want to upload. To completely replace all of the items in your inventory, select "Purge and Replace."
8. Click "Select File Upload," then "Browse." Locate your product file on your computer using the dialog box, select it, then click "Upload Now." After you upload the document, the page shows the status of the upload. Refresh the page to see the upload progress. Files over 5MB may take several hours to process.
Aug 05, 2014 | Work Safety
All my scanner will let me do is pictures. I had to re-install and the part of the program that let me choose pictures or papers is missing. What do I do?
Scanner hardly needs any software. Most of them are default. I would suggest to remove the Software altogather and simply press scan button on the scanner. it may ask you where to save the Image file.
There you go ! save it on your desktop.
Happy scaning !!!
Rate this solution, Write a comment to keep in touch.
- WisBee
Sep 16, 2010 | Computers & Internet
Last time any click on item in results of google or yahoo redirects me to other sites mostly ads. It happens with IE and FireFox. I scaned my system by several antiviruses but they did find any...
Something is "hijacking" your web-browser(s).
Look in the C:\WINDOWS\SYSTEM32\DRIVERS\ETC folder
for the file named 'HOSTS'. Open the 'Notepad' program
(All Programs -> Accessories -> Notepad) and drag-and-drop that file into Notepad. Ignore all the lines that start with '#' -- they are just "comments". If there are many entries, some computer-virus has updated that file, to point to "malicious" web-sites.
Aug 22, 2010 | Computers & Internet
Hi! My matchine is scaning all documents in Grayscale by def
yep!
sorry but our panasonic dp-8035 is only black&white document scanner.
Jan 14, 2010 | Panasonic DP-8035 Grayscale Copier
MP7001 - SCAN FILES ARE BEING SENT TO EMAIL AS A DAT FILE INSTEAD OF PDF
Press the Scanner button, on the left hand side of the LCD screen there should be a button that says "file type" press that and change the current setting to multi-page PDF. Now press ok and you should be back to the main scanner screen. on the right hand side of the control panel above the numbers press the program key, now on the LCD screen press program as default a window will pop up asking if thats really what you want to do, just press yes and you should be good to go.
Dec 09, 2009 | Ricoh Office Equipment & Supplies
HP Deskject All-In-One Scanner Problem
try from program if you have it installed on your computer, look in my documents , my scan directory that is in most cases default directry for scaned files. But try from program ( software which you have with your all in one)
May 08, 2009 | HP DeskJet F380 All-In-One Printer
While setting up user registrsation for scan to pc beteween kyocera 8030 and dsektop pc i receive message unnamed file and invalid path
Reinstall the scanner and follow the on screen directions. That should solve your problem, Alternatively define the path\folder where you want to save your sans to and make it the Default Folder(generally My Pictures in My Documents. Save it with a specific name(your choice) and see if can retrieve the scan and then you can do anything you may want to once you know the location of the scanned image......sodeep
Apr 12, 2009 | Computers & Internet
Scanner
to be able to scan to pc you have to have the scan file utility set up on the pc
the scan file utility is on the CD that came with the copier.
you can Google the file if need be
when you have loaded the file you will need to go to
start, all programs,kyocera (scanner file utility and open it
once in configuration you will need to do the following
select setup
on the top you will see a box, type in 001
file destination, you should hit the box next to this and select kyocera/scan file
press ok and you are done
Next
get the ip address of the scanner, you will find this in scanner default when you have pressed thecounter/system menu button
get back into normal copy mode
on your web browser type the scanner ip into the address bar and you will get into the scanner command center
press the start icon bottom left of your desktop, go to run and type in cmd
once in dos mode type in ipconfig, this will give tou the destination address for your scans
now back to the command center, select sender info (left side menu) and type in kyocera after selecting 001 (blue numbers) and submit
then go to destination setup (scan to pc) and under 001 (blue) enter the relavent info, the address will be your pc's ip address.
say no to all password requests
and submit
very important now is to close the browser as you cannot scan when the command center is open
please take the time to rate this fix
Mar 27, 2009 | Kyocera Office Equipment & Supplies
Scan a Multipage Document into a Single File
My scanner is a Cannon but the basic jist of what your trying to do is universal. You need to open up the software for the scanner and look for an icon that says scan to file. It sounds like you have already done this. If so you are very close in the step I mention to the setting you need to scan multiple pages into one PDF file. Once you find the setting to scan multiple pages be sure to not click "FINISHED" until your last page is scanned in.
LB
Nov 30, 2008 | HP ScanJet 2400 Flatbed Scanner
HP Scanjet 5590 Flatbed Scanner Logo
127 people viewed this question
Ben Johnson
