Question about Linksys SPA901 IP Phone
I cannot make a call from my Linksys spa901
When i try dialing a 3 digit extension within the office from my Linksys spa901 i get a beeping tone. What could be the problem
2 Suggested Answers
bbl242003
  • 1637 Answers
SOURCE: I set up a Linksys SPA941 Ip phone at home which
Press Reply or Accept
I can fix this
Bruce
Posted on Jan 14, 2011
How tto make a call from Alcatel Advanced Reflexes 4035 Corded Phone using another extemsion
this feature's name is "substitution". You can do this if your pbx is Omnipcx Enterprise.
Usage:
1. Dial the code of the feature "substitution"
2. Dial the extension number which you want to substitute
3. Dial the four digits secret code of this extension. (default=0000)
If this was successful you would get a dial tone which was the same as the remote extension did off hook and could make call.
Thanks
Aug 22, 2013 | Alcatel Advanced Reflexes 4035 Corded...
How do we make internal calls with Panasonic KX-T7433 handsets?
By default, Panasonic numbering is 101-164 and 201-264. The Intercom gives you dial tone and you dial the 3 digit extension number. Dial 0 should ring extension 101. Normal digital phones start at 101-116 on a TD816/1232 cabinet.
Carl
Jul 13, 2011 | Panasonic KX-T7433B Corded Phone
How do i transfer a call to another extension?
Unless your phone is connected to a TAW-848 or higher, your extensions are numbered 101-124 maximum, or 21-36. Try going to any phone but the main one and dialing either 101 or 0 and look at the display. You'll figure out your 3-digit extensions. Now just press TRANSFER and dial that 3-digit number. The outside call is put on hold when you press transfer, so there's no need to use the HOLD button.
As an alternative, you can press HOLD, putting the outside line on hold, and dial the 3-digit number into the intercom dial tone and announce the call for line number x. Or, dial the page code 330 and announce to all phones for the person to pick up line x.
Carl
Jun 16, 2011 | Panasonic KX-T7730 Corded Phone
I have a esp office 6100 series all in one printer, it is connected to a fully functioning phone line - I have checked everything is working. Each time I try to send a fax I dial the number it dials 3 or...
most likely the fax is incorrectly set up as an extension in a multi-line system rather than a single "telephone". probably the fax injects digits such as a leading zero. the setup needs to be corrected.
May 27, 2011 | Office Equipment & Supplies
No dial tone when pressing hook fax is returned
The only thing that could stop you from sending a fax or not get a dial tone, would be the connection to the phone line. Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 06, 2010 | Brother Multi-Function Center MFC-240C...
Hi it is my first time using a IP Phone SPA901, The red light is blicking, do you know why?
the reason the red light is blinking is because you have a voicemail
Oct 06, 2009 | Linksys SPA901 IP Phone
My phone buzzes when I try to use it
If you have no dial tone one of the wires is completely broken between you and the central office.
If you have a dial tone but the noise is riding on it, there is more than likely a break in the wire going to one of your extensions or a bad phone on the extension.
If it is more of a popping instead of a buzzing, it is water in the line some where.
May 28, 2009 | Vtech Lands Phones
How do you forward a phone call from this phone to a cell phone?
to forward calls...go to your phone service providers website and help section for complete instructions...
with most companies simply pick up the phone... wait for dial tone... press *72 wait for 2 beeps and enter the number (area code first) that you would like it to forward to...once you enter the number wait for the line to ring... once it rings and is answered you are all set!
if it doesnt ring or is in use.. try again within two minutes...you should hear two short rings if it is activated...
to deactivate call forwarding...
pick up the phone (in the office)
wait for dial tone and dial *73 or #73
you will hear two short beeps... it is then off..
Apr 10, 2009 | Panasonic KX-TS3282B Corded Phone
Lost the IP from spa901
Hi!
Try this:
Press ****110#
Once you pressed the asterisk symbol four times (*) you should hear an IVR then press 110# and it will tell you it's IP address.
Hope this helps!
Mar 28, 2008 | Linksys SPA901 IP Phone
SW Bell FA-980 Answering Machine
Here is a link to a similar model: http://www.swbfreedomphone.com/ib/ibansw/fa970.pdf Here is what it says: TONE REMOTE OPERATION Remote Security Code To access answering functions from an outside line, you will need to enter the three digit security code located on the bottom of your unit. Write this number on the Remote Access Card, which you can keep in your wallet. Remote Turn On If you forget to turn on your unit: 1. Call your unit from a touch-tone phone. 2. Wait 12-14 rings until the machine answers. 3. The FA970 will automatically answer by playing your greeting. You may hang up the phone, and subsequent calls will be answered. Remote Message Playback 1. Call your unit from a touch-tone telephone. 2. After your FA970 answers, it plays the outgoing greeting and beeps once. Dial your three digit security code within 20 seconds after the beep, pressing and holding each digit for 1-2 seconds. Allow a 2 seconds interval between each digit. 3. Your FA970 will sound one beep to indicate the code was entered correctly. (If there are no beeps, enter your code again.) 4. You can press the following buttons on your keypad: Option Press Playback Mailbox 1 Messages (1) Playback Mailbox 2 Messages (2) Record Memo Message (3) Record New Greeting (8) Turn Off Answer Mode (9) If you press ?1? or ?2? (to playback messages), you have the follow options: Option Press Erase Current Message (0) Repeat Current Message (4) Repeat Previous Message (4) repeatedly Stop Message Playback (5) Skip to Next Message (6) To SAVE messages, hang up the telephone. Note: Your FA970 will sound a series of beeps if there are no messages. Remote Record New Greeting If you press 8 (to record new greeting): 1. When you hear a beep, begin recording your new greeting (up to 30 seconds). 2. When you have finished recording your new greeting, press (5). The unit will beep, and the new greeting will playback to you. 3. Hang up the telephone. Remote Record Memo If you press 3 (to record memo message): 1. Within three seconds of pressing ?3?, press ?1? or ?2? to select Mailbox 1 or Mailbox 2. Otherwise, the memo will be recorded in Mailbox 1. 2. When you hear a beep, begin recording your memo (up to 60 seconds). 3. When you have finished recording your memo message, press (5). 4. The corresponding Mailbox message count will be increased by one. To Retrieve Messages when Recording Memory is Full 1. When the message capacity is full, the unit will sound 3 beeps after answering the phone. 2. Within 20 seconds after the 3 beeps, dial your 3 digit security code. 3. Your FA970 will sound one beep to indicate the code was entered correctly.
Mar 22, 2007 | Southwestern Bell FA970SN Digital...
Linksys SPA901 IP Phone Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
