Question about Polyvision Walk-and-Talk Lightning WTL 1600 (WT1600L)
Replace controller module Polyvision 1600
I have the repalcement part but cannot remove the old one. It appears the old one needs to slide off the back of the unit but I am not sure how to remove the end caps.
To replace the controller the end cap can be removed by removing 2 screws that are on the back of the board. The end caps will then slide off.
Posted on Feb 12, 2009
How to replace starter
Are you trying to replace the entire ignition system or just the battery operated starter module?
Neither is is extremely hard to do. The best way, is to keep most of the existing wiring in place to use as a guide. The Ignition Module is the easiest to remove. Unscrew the outer plastic ring of the igniter button and the module can be removed from under the control panel. If that's all you're planning to replace, leave the wires intact to the old module and transfer them one by one to the new module. Then install the new module in reverse order of the way you took the old one out. When you install the new battery into the new module, be sure the + end of the battery is facing you, when you slide it into the holder or it will not work.
If you're replacing the spark ignitor(s) at the burner, leave the existing wiring intact (unless it's damaged) . Remove the cooking grates, the flame tamer and the igniter shield and you will have access to the spark ignitor(s). Slide the wire off the spark ignitor pin, remove the old one and install the new one. Slide the ignitor wire onto the pin and you're ready to go.
A word of caution, always use Broilmaster Parts and watch your hands and fingers around any stainless steel parts. As, it they be very sharp and cut you before you realize it.
Hope this helps you replace the starter.
Please be kind enough to give me a good rating for the solution I provided you. Thanks and Happy Grilling!!
Mar 26, 2011 | Broilmaster Deluxe D3 Grill
Can you tell me where the serial number is located on the eno mini polyvision slates?
The Mini itself does not have a serial number. If you need to provide a serial number for support or any other reasons just use the Serial number for the stylus. This is located inside the stylus underneath the battery. If you have any other questions you can call PolyVision tech support directly at 800-620-7659 Opt. 1.
Good Luck!
Jan 06, 2011 | Polyvision eno mini 2120 Interactive Slate...
When the Polyvision Click Eno pen cap is left off for a length of time it appears to require recalibration. Is this the case?
No, the eno board shouldn't require any calibration after the pen cap is left off. The pen does power off after a while to save bettery power. You just put the cap back on for a second and Presto! - it's on again!
May 24, 2010 | Polyvision eno click 2850 Interactive...
Location for the head light control module
The LCM or lighting control module is located under the dash to the right of the steering wheel, first you need to remove the hush panel under the knee brace, then there are 2 screws the hold it to a bracket. Unplug the 4 connectors towards the back and then slide it out and replace.
Oct 22, 2009 | 1996 Lincoln Town Car
Low volume on Nokia 1600 phone
sometimes the volume is in a funny place. did you try going to menu then settings then audio/ringtones then volume? I hope this is helpful
Jan 15, 2009 | Nokia 1600 Cellular Phone
Repalce harness from temperature control
You need to drill out the rivets on the bottom of the drawer then slide the stainless sleeve up and out. Then you need to remove the 2 rivets on the middle part inside the gasket. Once you drill them out the insulation goes downward to remove. Then you will see the excess for the harness. Replace the rivets with flat head screws.
Dec 07, 2008 | U-Line Echelon Series 2075DWRRSS...
Printer 1600 JAM
Assuming you cannot lift the rear door and pull out, you will need to remove the back cover (take out the four screws) and take out the fuser module (it has heat temperature warnings on it so let it cool down before handling). The module has two sets of wires on either side that need to be disconnected. Four screws hold the module in place and need to be removed. The paper usually gets stuck in there. After removing the module, you may need to remove the small rear roller from the module by gently prying it up and out after removing four additional screws on the fuser that hold the metal bracket on the fuser in place. Removing these four screws (two on top, two on side) allows you to slide the bracket up and down and more easily access the small roller that needs to be removed so you can get all the paper out (it will likely be accordion-folded and really compressed in there).
Dec 17, 2007 | Dell 1600n All-In-One Laser Printer
Drivers for Microfield softboard model 203
Try Polyvision: http://www.websterboards.com/support/downloads-presentation.asp
Apparently, Softboard brand became Webster and is now Polyvision LT series.
Oct 29, 2007 | 3M Microfield Softboard Model 203...
Polyvision Walk-and-Talk  Lightning  WTL 1600 (WT1600L) Logo
169 people viewed this question
Top Polyvision Computers & Internet Experts
David Payne
David Payne
Are you a Polyvision Computer and Internet Expert? Answer questions, earn points and help others
