Red and Green colour bleed on Sony LCD TV
My LCD TV picture has red and green colour bleed when the picture shows shadows. often this appears in hair colour or shadow from peoples faces which have a red / green appearance or edge. I have tried with HD TV and the problem still exists. The TV was supposed to be the top of the range during spring 2008. I have noticed this on some other LCD TV's but the majority are ok. Is this right? Can it be corrected? Please help? The colour is driving me crazy and I have been on to Sony to get resolved. What can I expect?
  • Anonymous Mar 14, 2009
    I am using a Samsung LN40A650 as a computer monitor via DVI - HDMI connection.
    Red text and green text on white 'smears' a bit.
    Blue text on white does not. It's intolerable.
  • lorax1284 Mar 14, 2009
    I am experiencing a similar problem on a Samsung LN40A650.
    I am using it as a computer monitor via DVI - HDMI connection.
    Red text and Green text on a pure white background "smears"
    Blue text is nice and crisp.
SOURCE: toshiba regza lcd hd ready, black gone green?
The problem is definitely not magnetic interference. There are no speakers near the television and it is not a CRT screen.
Posted on Oct 27, 2008
  • 225 Answers
SOURCE: Screen shows blue patches on white also red lines on dark colour
Replace the video board, if you can find one. Letting it cool down will not help any.
Posted on Nov 14, 2008
SOURCE: shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Posted on Jan 05, 2009
  • 25 Answers
SOURCE: Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Posted on Apr 02, 2009
  • 8457 Answers
SOURCE: i have red and green shadow on top and bottom of the screen.
Ur Convergence board is dead or deffective with the IC chip.
Posted on Aug 17, 2009
Why are green horizontal lines are appearing, too much yellow colour and green light blinking red?
These horizontal lines are vertical flyback lines and would indicate
one or more of the tubes cathode drive circuits are defective.
As the picture is predominantly yellow this would indicate excessive drive to red and green guns. Check the red and green video output stages especialy any clamping diodes.regards from Vintie
Sep 19, 2013 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Our tv has red and green shadows on the picture when words come on at the bottom of screen they look like a shadow double Peoples faces will be outlined with red and green lines
your color engine is failing its also known as the optic block and they are very expensive to replace good luck google the optic block failure in these sets to better educate yourself with what your dealing with ok it most often blue that shows the failure but green and blue to and red
Dec 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
This tv have convergence problems,it dead.Red,green,blue misaligns colors,have colors shadows,3d colors pic like.All these problems are the convergence board have 2 STK convergence ICS some or all it resistors are dead.These parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Oct 26, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Tv works but picture is showing in blue
If the picture is blue only and there is no red or green, you have either colour gun failures or if you are trying to watch a picture from a component source there maybe something wrong with the red and green cable feeds. Try watching a DVD using a single composite video feed (usually a yellow RCA plug). If this unit has an internal tuner (either analogue or digital) and you still only see blue broadcasts then you have a problem. Whether this unit is an LCD or CRT rear projection TV the repairs will probably be expensive. Ultimately, it is not a user repairable device and needs a qualified Sony tech to undertake the work.
Sep 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Connecting old DVD player to LCD
Just respect the colors. Green output from the dvd to green input tv, Red output from the dvd to red input tv and the same with blue. All 3 cables (green , red, blue) are for the picture, so you got to plug another 2 for the sound.
Dec 25, 2007 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
The picture is only producing the basic colours red green and blue
You can start with the make, model and age off the back of
the TV..........................T.
Dec 24, 2007 | Televison & Video
Sony KDF-55WF655 55" LCD Projection TV
I have the same TV and the same problem, I take out the block of colours red, green and blue (the blue colour is broken) and I went to the electronic supplies for ask the price  and they don't sell just the little blue mirror (blue pixel), they sell all block for $2,050.00 dollars. It's the price for a new one
Oct 09, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Problem in Screen display
Hi, J ! You didn't say how old you set is, but to me it sounds like you may have a warped shadow mask in you picture tube. A shadow mask could be compared to a piece of screen wire. It's function is to make the electron "beams" from the three electron guns strike the proper phosphor dot to produce the proper color- red-green-or blue. If this is the case the picture tube would requie replacement. Stargazer
Jan 09, 2007 | Sony KV-21CT1 21" TV
Televison & Video Logo
1,416 people viewed this question
Top Televison & Video Experts
