Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
15'' MacBook Pro Wont Switch on
My Mac Wont switch on but the charger is showing light and the battery also show it has power but when i try to switch in on nothing happens. last time it was trying to update firmware and it said it needed to shut down then i should switch it back on and it never did. is there a way of switching it on or reseting it
It sounds as though the mobo has had a serious issue from shutdown without final install, may need to replace the motherboard :(
Posted on Feb 11, 2009
My mackbook dropped and wont turn on
I love Mac so please keep it safe. It look like some internal damaged to your MacBook so if is it in warranty than talk to officials of Mac.
I suggest you don't try anything go to http://www.apple.com/macbook-pro/ and check your system and if you need any technical guidance follow Mac Tech Support .
Feb 22, 2014 | Apple MacBook Pro Notebook
Laptop not recognizing battery macbook
ifixit has teardown guides. The battery is probably dead, but the contacts could be dirty. The charger may also be bad. if the battery icon shows up in the top, it's probably connected properly.
Feb 13, 2014 | Apple Customized 15" MacBook Pro Laptop...
Restart appears on start up
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jan 26, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Macbook pro dark screen
Close the lid, attach an external monitor, reopen lid.
Your display should now show on that monitr. If it is, your display on the MacBook Pro may be bad. I would try resetting the PRAM and the SMC before going to an Apple store. The SMC controls the MacBook's power founcts (see below)
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jan 12, 2014 | Apple Computers & Internet
Keyboard Backlit not coming on at all
Set your backlighting in
Apple menu
System Preferences
Keyboard.
otherwise try:
Resetting the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jul 08, 2012 | Apple MacBook Air
My apple macbook air shows a question mark when i turn it on
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
May 22, 2012 | Apple MacBook Air
It shows message as "turn on camera" while try to
Assuming your computer has a built-in iSight camera - which should be all Macs made since 2006 except for the Mac Mini and Mac Pro (not MacBOOK Pro!) - your camera
a) May not be being seen by the computer. Check Apple Menu > About This Mac > More Info > USB and see if "built-in iSight" is listed in the USB Device Tree. If it is, then it may be being used by another application that uses a webcam, like Skype, iChat, or what have you. If it IS NOT detected:
b) Try resetting your SMC:
Resetting the SMC on Mac portables with a battery you can remove
Note: Learn about removing the battery on MacBook and MacBook Pro.
  1. Shut down the computer.
  2. Disconnect the MagSafe power adapter from the computer, if it's connected.
  3. Remove the battery.
  4. Press and hold the power button for 5 seconds.
  5. Release the power button.
  6. Reconnect the battery and MagSafe power adapter.
  7. Press the power button to turn on the computer.
Resetting the SMC on portables with a battery you should not remove on your own
Note: Portable computers that have a battery you should not remove on your own include MacBook Pro (Early 2009) and later, all models of MacBook Air, and MacBook (Late 2009).
  2. Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
  3. On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
  4. Release all the keys and the power button at the same time.
  5. Press the power button to turn on the computer.
    Note
    : The LED on the MagSafe power adapter may change states or temporarily turn off when you reset the SMC.
Resetting the SMC for Mac Pro, Intel-based iMac, Intel-based Mac mini, or Intel-based Xserve
  2. Unplug the computer's power cord.
  3. Wait fifteen seconds.
  4. Attach the computer's power cord.
  5. Wait five seconds, then press the power button to turn on the computer.
Dec 20, 2010 | Computers & Internet
The fan on my macbook has turned on and the battery icon shows an X when it appears. Also when the charger is plugged in the light is a very dim green.
The green light on your power adapter is normal, this indicates that it is charging the battery. The fan within the MacBook is controlled by an internal heat sensor. The fan inside will speed up and slow down based on the internal temperatures.
The X icon for where the battery is, indicates that the battery is not connected or the system doesn't recognize the battery anymore. Meaning, you will need to buy a new battery for your computer.
Nov 14, 2010 | Apple MacBook Pro Notebook
Apple laptop battery not charging enough keeps showing 0% instead of 100% charged when plugged in, if i unplug the charger it will switch itself off as battery died!! hope u understood what am trying to...
Depending on the age of the laptop battery...it may have simply died. My MacBook Pro 17" use to run for 5+ hours, now only 30 mins or so.
For 120-150ish, you will be as good as new.
You might want to do a Power Management Reset before getting a new battery. Google it for model of your laptop.
Also, Batteries should be recycled or at least disposed of properly. If you have an apple store near by, take the old batter with you and leave it at the store. Free Recycling but no store credit.
Aug 17, 2010 | Apple MacBook Mac Notebook
How do i turn on my computer?
There are many different models of MacBook, most have the power button on the right side of the palm rest up by the screen. If you are pushing this button and there is no response, try removing the battery, remove the ac adapter and press the power button for 15 seconds. Plug in the battery and power adapter and try the button again.
Jun 10, 2010 | Apple MacBook Pro PC Notebook
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
126 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
