Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Windows Restart hello sir , i have problem in my windows xp , today i was start my pc but i could not start properly. Becouse of the pc was continues restart so pls suggest me a solution.
  • 39 Answers
Hi, your best bet is to start XP in safe mode, or, if that does not work, do a repair after booting from your installation disk.
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
Posted on Feb 11, 2009
Shuttle xp, ntldr is missing
replace the cmos battery, reboot the computer go into bios reset date and time and change boot order cdrom to boot first save changes. boot from windows xp cd do a repair. form command type sfc /scannow checks all system files.if any are bad should repair them.
Apr 17, 2017 | Computers & Internet
RES SIR, PLESE GIVE ME THE SOLUTION ABOUT ' WINDOW FILE PROTECTION MESSAGE' i.e. fills that are required for windows are replaced by unrecognized versions.To mentain system stability windows must restore...
click start menu, then run and type regedit.exe click ok
the look for this registry key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
and find the value SfcScan
right click over SfcScan and click Modify
change current value to 0 and click ok
restart your computer and that will take care of the issue.
The SfcScan value in the following registry key has three possible settings:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\WinlogonThe settings for the SfcScan value are:
  • 0x0 = do not scan protected files after restart. (Default value)
  • 0x1 = scan all protected files after every restart (set if sfc /scanboot is run).
  • 0x2 = scan all protected files one time after a restart (set if sfc /scanonce is run).
Mar 31, 2011 | Microsoft Windows XP Professional With...
Windows XP Professional With Servise Pack 2 (e8503040) for PC: sir my pen drive is not showing in windows xp .\r\...
it may happen in some case when you are inserting your pendrive first time it will get installed its driver and all itself so it might happen that you have to restart. you can also update this USB driver..
May 18, 2010 | Microsoft Windows XP Professional With...
Cant acess safe mode in windows xp, just cycles startup screens
Here are some steps to use MSCONFIG to force your computer into SAFE MODE
  1. Click on Start and then Run.
  2. In the text box in the Run window, type msconfig and click OK. This will open the System Configuration Utility program.
    Note: Do not make changes in the System Configuration Utility other than those outlined here to avoid causing serious system issues. This utility controls a number of startup activities other than those involved with Safe Mode.
  3. Click on the BOOT.INI tab located at the top of the System Configuration Utility window.
  4. Check the checkbox next to /SAFEBOOT and click OK.
  5. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  6. After the restart, the PC will automatically boot into Windows XP Safe Mode.
    Note: Windows XP will continue to boot into Safe Mode until the System Configuration Utility is configured to again boot normally.
  7. When your work in Safe Mode is complete, click on Start and then Run. Type msconfig in the text box and click OK.
    This will again open the System Configuration Utility program.
  8. Choose the Normal Startup radio button and click OK.
  9. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  10. After the restart, the PC will boot into Windows XP normally and will continue to do so.
    These instructions were written by About.com
    http://pcsupport.about.com/od/tipstricks/ht/smsysconfig.htm
May 24, 2009 | Microsoft Windows XP Media Center Edition...
FORGOT PASSWORD
3rd Method:
If the above mentioned tricks don't work, then try following trick which is actually a loophole in Windows XP Setup and a big security hole:
A. Boot using Windows XP Setup CD and follow the instruction like Accepting EULA, etc.
B. When it asks to repair your existing Windows installation, accept it and press "R" to run the repair.
C. Setup will start repairing your Windows and will start copying files, etc.
D. After a few minutes setup will restart your system and when it restarts don't press any key when it shows "Press any key to continue..." otherwise Setup will start from the beginning. Don't press any key and setup will resume where it left.
E. Now it'll start doing other tasks and will show a small progressbar with a few details in left side.
F. Look carefully at the details and when it shows "Installing devices", press <Shift>+F10 keys in your keyboard.
G. It'll open a Command Prompt window. Now type nusrmgr.cpl and press <Enter>.
H. It'll open the same "User Accounts" window which you see in Control Panel.
I. Now you can remove or reset any account password without any problem.
This is the long way but one of the easiest ways to make sure all is going to work fine on next restart
Feb 09, 2009 | HP Pavilion dv2000t Notebook
Reformatting problem
Do you mean that you are re-loading windows? if you are when it reboots after re-loading and it says boot/start with cd-rom support do not press enter again or anything else for that matter because if you do it will keep taking you through the whole process again. Once it has loaded and reboots do not press anything it will start windows( even though it gives you the option to start with cd-rom support - just ignore it), itself and take you to the welcome screen etc... once this happens you can take the disk out.
Oct 25, 2008 | Computers & Internet
Sound problem
Hello sir, i have a problem with my sound, i have windows xp 2005 service pack
Sep 18, 2008 | Microsoft Windows XP Professional With...
Acer laptop aspire 4710z config my notebook have problem
There could be an issue with the user accounts logins. This could be corruption in the OS when you installed it or a clashing driver . I would recommend you reinstall the Operating System with the Disks and before you start installing the drivers try to shut down and see if it shuts down properly . If it does then you know the Operating system and hardware is all fine and can continue installing one driver at a time and shutdown and restarting, continue doing this until you see which driver is causing a confict with your system. I have had a problem similar to this but it was some windows updates pack that I had done one time and had to reinstall windows too and do one by one. Hope my answer gets you closer to a solution.
Aug 07, 2008 | Acer Aspire 5500 5570-2609 Laptop
Windos xp trouble!
You can run your system in safe mode.Restart your system and press F8.then remove your antivirus.Becouse few time two antivirus problem each other .Other wise you should repair your window
Mar 04, 2008 | Microsoft Windows XP Professional for PC
Problem with the Windows XP Operating system
Who installed your windows?
If you still have yhe cd then pop it into the drive , restart you computer and it should automaticly install a fresh copy of XP.
If it does'nt then press F8 (varys on all computers look for boot control etc.)at start up and choose to boot from cd drive this will install windows> if it still does'nt work , just give a reply and ill give another solution.
Jan 19, 2008 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
