Question about Bosch Dishwashers
Bosch SGS4012GB/14 dishwasher - top arm not rotating/cleaning
I have a Bosch SGS4012GB/14 dishwasher which doesn't seem to be washing properly.
I have checked the filter, checked the outlet pipe drains stuff away, cleaned out the rotating arms... I have opened the door during the cycle a few times to see if the arms are spinning and spraying and they seem not to spin, but do spray water. It seems the water pressure isn't strong enough to spin the arms.
The top arm tilts a bit too...Can anyone advise what I can check next or if I can replace something?
  • nicholas_jar Feb 23, 2009
    My solution that fixed it (since no-one commented...) was simply to risk buying a new upper spray arm.
    Worked a treat! Never washed so well in its life.
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
catriver
  • 878 Answers
SOURCE: small plastic top and mid spray arm do not turn, bottom does
decrete, you want to get down to the chopper and screen. If the screen is plugged up with gunk there won't be enough pressure to reach the top spray arms. Check out the posted pics. Remove the lower spray arm. Rotate the rear feed arm to the right until it unsnaps from the tube going up the back. See the 4 torq screws holding the filter on. Remove them. Lift the filter up. Now you will see the chopper inlet cover. 1 torq screw holding it in. Lift it up and there's the chopper and screen. Catriver..post back
Posted on Apr 09, 2007
  • 4 Answers
SOURCE: bosch dishwasher sgs43a52gb
try http://www.bshappliancecare.com/Bosch/boschspares.html
it's pretty flaky and I didn't work when I tried to download a manual for my SRS43A02GB/08, but the parts-lists do.
If you go to the 'Launch the spare parts eShop' and enter your model number (you only quote it partially above, so you then need to select the particular model), you can see the exploded parts diagram - click right-hand icon 'print all pages' to get a pdf of all the exploded diagrams. You can order from here too and they seem a lot cheaper than alternatives, but I haven't actually bought anything yet.
Posted on Jul 13, 2008
  • 412 Answers
SOURCE: Lower spray arm does not spin on my bosch dishwasher
Sounds like you may have put it together wrong. I would just take the arm back off and make sure that it all fits together right. A little tip for you too. Dishwashers will clog up all the time with water deposits and food gunk. There are all those expensive cleaners out on the market but the best and cheapest way to clean them is with white vinegar. Simply pour it into the dishwasher when it is empty and run it on the pots and pans setting on hot. Always make sure to pre heat your water too by running the sink till it starts steaming. This will make it easier for your dishwasher to heat the water. If you don't, then when you turn on the dishwasher it starts to fill with cold water and has to heat it on its own. Run the vinegar though through it at least once a month or so and it will extend the life of the dishwasher. Hope this helps. Just try taking that arm back off though and putting it back together making sure everything is fitting properly. If you have any other questions feel free to ask me. Good luck.
Posted on Mar 20, 2009
  • 56 Answers
SOURCE: upper spray arm falls off during operation, even after snapping
the clips that hold it in place are worn. you will have to replace it. they are not very expensive. to remove it simply unscrew the round disc above the arm
Posted on Feb 08, 2010
Testimonial: "Wish one could buy just the clip and not the whole assembly, but it is not expensive."
Top arm stopped rotating on Bosch clasixx
not worth fixing, you are better off putting that money towards a new one. unless you can find the arm and repair it yourself
Nov 10, 2011 | Bosch 24 in. SGS43C12 Classixx...
I have a Bosch dishwasher Model No: SMU7056UC/14. The top rack does not seems to be cleaning good. I took out the filters under the lower wash arm and cleaned out the pump area. Any ideas would be very...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 14, 2011 | Bosch 24 in. SMU70 Built-in Dishwasher
Bosch SHU 8805 upper arm is getting no water.
replace the upper water arm conduit and wash arm hub as they leak under years of pressure and the o-rings leak water and then it can't hold pressure and supply the upper arm with full pressure water,also replace the center arm conduit if it has one as this will wear out too
Mar 23, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
I have a bosch dishwasher, SHU535E05UC/14. The
the spray arms are not rotating check they spin freely if they do remove them and clean any residue food deposits blocking holes for water spray.
Jan 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
SHU43C06UC dishwasher cleans dishes on bottom rack but leaves dishes on top rack dirty
your top spray arm is blocked and not rotating,remove it from top basket and thoroughly clean it paying particular attention to the holes right at the ends these are angled to drive the arms round if they block up the arms will not rotate.
Nov 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Suspect arms not rotating
there is insuffient water in appliance it needs 32 litres to wash properly and have enough pressure for wash pump to drive spray arms round this is quite easy to fix but messy, remove base panel plastic and metal one behind this exposing a plastic corrugated hose this will be blocked with fat limescale etc and needs cleaning it is a push fit with o rings pull out clean pipe refit and all should be well.also check holes on ends of spray arms are not blocked as they will not rotate but water will still come out
hope this helps
Jul 14, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Sprayer arms not spinning
I know this sounds too simple, but on My dishwasher which is an SHX46b model, the plastic supply arm that comes out of the pump and supplies the upper arm popped out of it's correct position at the base. It is held in place by two dinky nibs. I just popped it back in and voila, pressure was back and arms were spinning.
Jul 02, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Clogged dishwasher arms
Our Bosch has a round knob in the center of the arm, under the basket. ROtate it 90 degrees, and the arm drops away and can be cleaned.
Jan 16, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch dishwasher model #SHU43C05UC/14 drains well and has enough water(I replaced the inlet water valve already),but not washing the dishes clean especially the top rack.What could be wrong?
open machine when running and check both spray arms rotating - you will get a bit of water out. if spray arms not rotating, usual cause is debris in the arms. the spray arms only rotate by water jetting from angled jets at the end of the arms. take them out and make sure all debris removed
Jul 14, 2008 | Dishwashers
Dishwashers Logo
258 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
