Rank: Wiz
Rating: 83%, 134 votes
Hi
This will not work if you iPhone is jailbroken .
You must have SSH already installed.
Before you begin, make sure your iPhone is connected with your 30pin USB to your computer(Computer must have connection to internet),
and that SSH is turned on, and make sure EDGE is turned on.
What you will need:
-- Proxy - ccproxy -
http://www.youngzsoft.net/ccproxy/ccproxysetup.exe-- Archive with all necessary internal iPhoneUSB - ðð°ñ€ð¾ð´
-- Net Framework 3.5 - Download details: .NET Framework 3.5
-- iTunes
1. Extract Archive to desktop.
2. Install ccproxy on your computer, then run it.
3. Double click, or execute, file 1_start_ssh_tunnel.cmd - it opens a tunnel between your phone and your computer (do not close the window, you can reduce, postpone or scale down). Remember the phone must be connected to a computer via usb.
This image has been resized. Click this bar to view the full image. The original image is sized 502x182 and weights 6KB.
4. Next set a proxy for EDGE on your phone.
execute winscp.cmd, navigate to folder / private / var / preferences / SystemConfiguration
You'll need to transfer the file preferences.plist to you computer, and edit, or paste over, the Proxy area.
<key>Proxies</key>
<dict>
<key>HTTPEnable</key>
<integer>1</integer>
<key>HTTPPort</key>
<integer>808</integer>
<key>HTTPProxy</key>
<string>127.0.0.1</string>
<key>HTTPProxyType</key>
<key>HTTPSEnable</key>
<key>HTTPSPort</key>
<key>HTTPSProxy</key>
<key>ProxyAutoConfigEnable</key>
<integer>0</integer>
</dict>
5. Once edited transter preferences.plist back to your iphone and overwrite the existing file.
6. Click the Options button in ccproxy, and click the "Advanced", then click the tab Networks, then untick with "disable external users" save and go back to main ccproxy window.
7. Execute file 1_start_ssh_tunnel.cmd - it opens a tunnel between your phone and your computer (do not close the window, you can reduce, postpone or scale down). The phone must be connected to a computer via usb.
8. Execute proxy_tunnel.cmd - opens port 808 on your phone. (do not close the window, you can reduce, postpone or scale down).
The Internet should now work!
To jailbreak your phone just go to this site it will be done in a miunite
http://www.appleiphonereview.com/iphone-tutorials/iphone-jailbreak/
Hope this helps and do let me know
