Question about Sony CDX-FW570 CD Player
Display issues on CDX-FW570
Display/text info (ie..clock/time, station, etc.) won't come up on my CDX-FW570. Lights do come on though and the unit works fine other than the display issue. Can someone help. I have read manuals and am not getting anywhere. I'm reading info about a code? Is there a code I need to use and if so, without being able to read the display how would I be able to enter this code?
Thx
  • Heidi Int-Hout Feb 11, 2009
    I pushed & held the reset button behind the face plate, but it didn't seen to make a difference, but thankyou for responding & trying to help.
    Thx
  • 3 Answers
I had the same problem. The brass pins behind the faceplate that connect the main unit to the faceplate get dirty. clean them off with a little rubbing alcohol and a Q-tip. it fixed mine right up.
Posted on Mar 01, 2009
  • 37 Answers
YOU MUST RESET THE PLAYER BY PRESSING A RESET SWICH LOCATED ON FRONT SIDE OF YOUR PLAYER. PRESS THE RESET SWICH FOR 10 SECONDS WHEN THE POWER SUPPLY IS ON.
IT MAY SOLVE YOUR PROB.
BEST LUCK
REGARDS
KETAN PATEL
Posted on Feb 11, 2009
Sony CDX-FW570: sound only from one speaker on radio. Both speakers work on CD. Checked that mono/stereo function was on stereo. All wires are connected correctly.
Sounds like a bad unit. If it's still under warranty, contact customer support or call a local electronics repair shop for more information.
May 28, 2014 | Car Audio & Video
How do i replace burned out lightbulb in my in my cambridge soundworks cd - 740 clock radio ?
I believe the problem is either a faulty light sensor the unit has to dim the display when the lights dim since it was designed for bedroom use with alrms and snooze button. or it is simply a failure in the circuit that drives the LCDs. Mine has been dim for a long time but I can still see just enough to adjust the sound settings. I tune and set stations by sound. so the display has not been an issue since we do not use it for a clock or alarm. I doubt there is a fix for the dim display.
Mar 10, 2014 | Cambridge Soundworks CD-740 Clock Radio
RDS failure?
some stereos you have to input the name of the station yourself.
May 05, 2010 | Sony CDX-GT310 CD Player
Stereo will not save time or set stations. not
sounds like a very common power wire issue. if not connected to the cigarette lighter or other continous power source when the car shuts off all memory will be lost, ie... audio settings, station memory, clock memory
Feb 18, 2009 | Sony CDX-GT110 CD Player
Display doesn't display info....just bright light
Have you tried resetting the unit? Remove faceplate and push the reset button with a ball point pen. If it's a bluetooth model there is a different procedure.
Aug 25, 2017 | Sony CDX-M610 CD Player
Set time on Sony CDX-L400x
Press and hold the [DiSPLay] button (in the bottom row of black buttons -number presets etc.- most to the right side) for a while, then the unit should enter "Clock Set" mode.
(likely that you've found a solution by now; but i might aswell add one for others having the same problem).
Nov 11, 2008 | Sony CDX-L400X CD Player
Car Radio
I have the same head unit and disconnected from the battery. There was no input code required when reconnecting the battery You should be ok! I can't help with your Tuner problem though! Good Luck!
Aug 20, 2008 | Sony CDX-L580X CD Player
Faceplate not working
Try disconnecting the unit completely.
Nov 09, 2007 | Sony CDX-F7700 CD Player
SETTING THE CLOCK IN THE CDX-F7700
press the display button until the time appears on the display (instead of the radio station or cd track). once on the time press and hold the display button and the time should flash. use the sel (aka select) button to jump from hours to minutes.
Oct 16, 2007 | Sony CDX-F7700 CD Player
Sony CDX-FW570 CD Player Logo
182 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
