Cleaning the screen
I accidently used a cleaner on the screen while the TV was switched on. Now there is a huge discolouration mark in the middle of the screen. This does not affect the image but looks really bad when the TV is switched off. How can I clean this mark? Will I have to get the screen replaced?
  • 38 Answers
Try hot soapy water, since a flat screen TV should be glass.
Posted on Feb 11, 2009
Son sprayed cleaner on tv.
I have not a clue what to tell you, but doubt the cleaner is the cause of this. In any case the TV is so old you will not be able to get parts.
Jul 09, 2017 | Televison & Video
Kenmore glass cooktop discoloured
I use a straight edged razor blade on mine and it finally got clean
Nov 15, 2012 | Kenmore Frigidaire Glass Cook Top...
Why are roof tiles, under TV aerials, discoloured on most roofs?
Most of the discolouration I see has got nothing to do with the metal, which is usually a fairly inert aluminium covered in aluminium oxide. What does seem to happen quite a lot is birds sit on the aerials and just do what comes naturally - leaving behind a bit of a stain. I spent a few years at sea and saw an albatross roost on a rotating radar aerial overnight. The next morning the deck underneath was a mess of semi-digested fish, a huge amount for just one bird! Here you will get more information about aerials.
Oct 16, 2012 | Acer Aspire AS5334-2153 Notebook PC
I have a smudge on my Panaboard and would like to clean it but don't know what I can use? Any suggestions?
All Panasonics can have a moist cloth or even a little metholated spirits on the screen. Occasionally a machine has a heavy bump which causes a greying effect between the two layers of the screen- you will NOT be able to remove the discolouring if that has happened. By the way- NEVER use whiteboard cleaning fluids on the screen- use water or a moist cloth for tough cleaning jobs-metho if desperate. Never use whiteboard cleaners on any whiteboard. Their job is to eat the surface so that you always need to use them.
Sep 19, 2011 | Panasonic Panaboard UB-5815
What is the best to use to clean fingerprints on the screen? Soap and water or glass cleaner?
I always suggest Monster Screen cleaner, It is not alcohol based and is designed for cleaning LCD screens. I use this professionally in my tv shop, this stuff is great, even removes crayon marks.
http://www.youtube.com/watch?v=523NZbh_Qpo check out this guys review.
Aug 03, 2011 | Philips 32PFL3505D 32 in LCD TV
My 3 year old niece touched the centre of my panasonic viera plasma screen leaving a grey "burn" mark - how do I repair or clean it off?
That will be just a discolouration, not a burn mark.
Use dilute washing up liquid and a soft clean cloth that has been wrung out almost dry, to wash the grease marks away.
Hope that helps.
Jan 15, 2011 | Televison & Video
Front screen
HOW TO CLEAN TV SCREEN;
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Hope this may help;
DON'T FORGET TO RATE:
Sep 06, 2008 | Toshiba 55H70 55" Rear Projection...
How to fix my paint on vizio tv
This may sound dumb but it has worked for me at times.. USE BLACK shoe polish the kind that comes in the little round can. Don't try to touch it up with paint because some paints eat plastic.
Jul 10, 2008 | Vizio L32 32 in. LCD HDTV
Blue screen
no sounds on tv
Feb 25, 2008 | JVC AV-27260 27" TV
Tv discolouration
It sounds like your problem is magnetisation of the crt. Try to switch it on and off for 3 times: on for 1 minute, off for 3minutes, on for 2minutes and off for 5minutes. Then switch on and see if the discolouration dissappeares. IF not, then a technician needs to check the internal degauss circuits.
Jan 24, 2008 | Beko 324250WN 28" TV
Televison & Video Logo
551 people viewed this question
Top Televison & Video Experts
Electro Med Services...
