Question about Microsoft Visual Basic 6.0 for PC
How to write a programe to convert F to C
Can you please post me the codes of the mentioned program
  • 295 Answers
See http://www.ehow.com/how_4551691_convert-fahrenheit-celsius-vbnet.html
The tutorial is for VB.Net, but when using VB6 it should be 90+ % the same ... The single line of code for the conversion is VB6 compatible so only the GUI handling code is slightly different.
Posted on Feb 11, 2009
Ineed a code for tv converter box,What would the code be for a tv converter box ?
Different brand converter box will have differen tset-up codes. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Jan 11, 2017 | Televison & Video
On the 2004 honda crv along with code 1259vtec, l also have code 0420 which deal with the oxygen. If I upgrade the gas and put in lucas fuel injection cleaner, is it possible to correct the condition
NO--- code p0420 refers to the catalic converter system, bank 1 --efficiency below threshold===causes --cat converter, wiring-HO2S sensor 2
code p1159 refers to heated oxygen sensor (HO2S) -front circuit low voltage positive terminal===causes--wiring--HO2S--ECM programming---ECm
In both codes the heated oxygen sensor is mentioned so I would have it replaced before I spent money on a cat converter.
Feb 09, 2015 | 2004 Honda CR-V
How do i program accsee hd dta1050 converter box with trisonic ts-rc411 universal remote control
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Sep 13, 2014 | Televison & Video
I need program code for vizion tv to program my DTA800B1 remote
0029,0027. Try these codes. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 17, 2013 | Televison & Video
Program a ge rc24914e universal for a Magnavox DTV. Converter box that has no power on off switch ?
Programming procedure is too much to type in here, and is not practical. Try these codes.For more information http://electrohelponline.blogspot.com/Setup procedure, and setup code list to many popular remote controls are given.Pull up older posts.
Nov 29, 2013 | Televison & Video
I am having trouble scanning text documents into pdf format. The pdf format type does not show up as an option to use. Also, scanned images are hugh files 8 -10 Mb. Help!
Good Day Agcarson!
It will be easy to provide you the answer if you mention the brand and model of your printer and your operating system.
Please post back.
Jul 01, 2011 | Office Equipment & Supplies
Is there a universal code to use for the zinwell digital to analog converter box? I have a oneforall remote URC-3220
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Zinwell Converter Box. I recommend using the remote's code search function.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Dec 19, 2009 | Digi Zinwell ZAT-970A tal TV Converter Box
PROGRAM INSTRUCTIONS
You mentioned that you need the instructions. You can go to the link below then select your model number. Since you posted your query under URC-4021 then select this model then the devices that you have then click search. it will give you the option for your manual hence you can see the instructions there.
http://www.oneforall-na.com/advanced_search.php
I hope this has answered your
question. If you have more
questions please post a reply and
i would be happy to assist.
Thanks.
Sep 02, 2008 | One For All URC-4021 Remote Control
Microsoft Visual Basic 6.0 for PC Logo
231 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
