Question about Quantum (SE21S011) 2.1 GB Hard Drive
Hdd does not setup xp
My seagatehdd has some bad sectors and itcant take setup xp. how i setup xp on it?
    President:
  • 1,185 Answers
Go to www.grc.com/spinrite.htm
Download this program and copy it to a cd run it on the defective hard drive
It should map out all of the bad clusters
Posted on Jul 08, 2009
You can use Partition Magic. By this software, you can repartition your HDD & Hide the partition that have BAD sector. Make a new partition without bad sector space & active it as a primary partition. That's ok. Now you can install XP.
Posted on Feb 11, 2009
Wd hdd, no bad sectors, but still blue screen error??
Most people don't know how to look for any trojans, they get all the wrong antiviruses and miss all of them. try spynomore and tell me what it found
Dec 01, 2013 | Western Digital Computers & Internet
My phonex core utility doesn't know my HDD plz help
FOUR bad Sectors? The harddrive is toast.
1) http://computer.howstuffworks.com/hard-disk7.htm
2) http://computer.howstuffworks.com/hard-disk.htm
If there is any data on the harddrive you wish to save, stop fooling with it, and take it to a professional data recovery service. The more you mess with it, the harder, and less, data that can be recovered.
Regards,
joecoolvette
Jul 10, 2012 | Toshiba NB520 Netbook
Win xp install problem
According to your problem , the main problem can be of your Hard disk having bad sectors.
This is common problem as the Hard disk goes old.Hard disk having bad sectors can make you lose your data and also it cannot be recovered. So your decision is very right to look for a new Hard disk,this will solve your problem permanently.
Thanks for using Fixya.Have a good day.
Apr 01, 2012 | Computers & Internet
I stopped the formating of my hard drive and then try to reinstall windows xp, the set up stays at 27% at copying driver.cab. it been more then hour it running.
You may have to try formatting your HDD again. If you have bad sectors on the hard drive, an incomplete format will not be able to flag back sectors so your windows install might be trying to copy to a bad location on the HDD. (speculation) your HDD may have no bad sectors, but this is one example of what could happen with an incomplete format.
You might also have a dirty install CD. take the CD out and look at it. If it is full of finger marks you might want to clean it and try again.
Chris
May 19, 2011 | Computers & Internet
Bad Sector Failure
Simple thing is u hav to boot with XP cd
http://support.microsoft.com/kb/315265
do this procedure
May 20, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How to remove bad sectors laptop hdd
Sir,
Bad sector removing is difficult task to remove /find. u can't solve bad sector harddisk. first go to run and type CHKDSK and check how the disk was or % of bad sector. the chkdsk command will solve badsector automatically. if not solves better to buy a new one or using the hdd with bad sector it not a problem
Jul 11, 2009 | Computers & Internet
Seagate sata hdd error
Quick format removes files from the partition, but does not scan the disk for bad sectors, while a normal format does that. That's why the formatting takes so much longer.
You should definitely check your drive for bad sectors by issuing "chkdsk /r" in the command line, which scans for and attempts the recovery of bad sectors.
If there is a bad sector somewhere, your system might crash at any time and it might be at a very inconvenient moment.
If you find bad sectors, you should consider replacing the drive
Mar 02, 2009 | Seagate Barracuda 7200.10 ST3160815A -...
Formatting HDD
Sounds like you need to run a scan disk,
at c: prompt type " scandsk /f " or chkdsk /f
This will find and fix bad sectors then you should able to format disk
Jun 04, 2008 | Toshiba Satellite A15-S127 Notebook
Harddisk Bad sector & not detecting
Hi, If your partitioning and/or formatting program is already reporting "bad sectors", then your best bet is to replace the hard drive. The mere presence of bad sectors indicates drive problem which in the normal course of time/usage would increase and eventually make the drive inoperable. Using such a drive as your "C" and/or to contain mission critical files may not be to your advantage. Hope this be of some idea/help. Good luck and kind regards.
Sep 28, 2007 | Seagate ST3250820A 250 GB EIDE Hard Drive
Quantum (SE21S011) 2.1 GB Hard Drive Logo
206 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
