Question about Lexmark X215 MFP All-In-One Laser Printer
Toner Empty Dear sir : There was the note toner empty , ( empty finish) because the printing paper not obvious , and I replace the old cartridge with new cartridge , the printing is obvious , painting but not recieve fax and the Toner empty is still found . please I want the Best solution for this problem . Best wishes Reem
  • reemon_2008 Feb 11, 2009
    Dear rinaj Limbu :
    befor replace the toner I cannot receive the fax and after replace the toner , and the print give red sighn indicate the Empty toner while the toner is new .
    I did this method ( turn off the print and turn on ) but with out benefit .
    Best regard
    Reem
  • wim4 May 12, 2009
    I have refill my toner, but the display still sign that my toner is empty.
    Also I cannot print and copy.
    Is it possible to reset the printer?
    Sergeant:
  • 183 Answers
It it was receiving fax before replacing the toner then it still should be able to receive so just turn your printer once off and turn it back then see what happens.
if problem still remains then please post back.
and rate all answers.
Posted on Feb 11, 2009
My Toshiba toner near empty, but i replace already.Now it is display toner near empty k
Go to job status, press the TONER tab, press REPLACE TONER CARTRIDGE. answer yes. Then replace the TONER cartridge. Press FINISH.
Jul 21, 2016 | Toshiba E-Studio 456 Copier
Tip
Why i get black streaks on paper in laser printer prints?
there are some possibilities for this problem. i will explain it. 1) First of all check out if the toner is full ,half or near to empty. There is no exact procedure to check the powder left in the toner without opening the toner.but in one toner there comes about near to 1500 copies.if you have got about 1200 to 1300 copies.then its quite possible that the power left is near to empty so the streaks comes on the paper due to less powder left.many times in this case removing and shaking the toner then reinserting the toner again and checking the printout helps. 2) But if you are sure that toner is not empty then other possibility is.in the toner cartridge there is a aluminium drum.its easily seen in the cartridge.once you remove the cartridge. if that drum is got very much used then due to that drum the streaks appear.fox example.if the drum is new the print is very dark.if the drum gets old the print gets very light or with streaks or faded print. 3) Now if drum and toner powder both are proper and still the problem then its the fault in the printer.in your printer there is some toner powder got spilled out on the inner parts from where the printing paper passes.so when the paper passes from the part where the powder is fallen or got collected then the streaks comes.in this case the printer needs internal cleaning and servicing. 4) but in some cases it has been noticed that internal powder of the toner becomes moist and very hard to come out from the toner for printing.in this case either toner needs to be refilled or toner needs to be replaced.you can get the toner refilled from local cartridge refilling store or local stationery shops dealing in cartridge refillings.The cartridge refilling shops also have the same printer for checking the cartridge.so at the refilling shop it will be confirmed whether the fault is in cartridge or printer.
This will help. Thanks .
on Mar 18, 2010 | Office Equipment & Supplies
How do I know which toner is empty on samsung clp315
  • 1.Log on to your computer and print a test page to the printer. Click on the "Start" button, choose "Control Panel" and then "Printers and Faxes." Right-click on the laser printer, choose "Properties" from the drop-down menu and click the "Print test page" box.
  • 2.Look at the quality of the print on the finished page. If the print is light or faded, the ink cartridge is probably empty or at least empty enough that it should be replaced. You can try to get some extra life out of your toner cartridge by taking it out of the printer, shaking it vigorously and putting it back in. Under normal printing loads, this can give you one to three days of additional printing capacity.
  • 3.Open the printer cover and carefully pull out the toner cartridge. Set the cartridge aside while you open the box containing the new toner. Pull the new toner out but do not yet remove any of the packaging materials. Compare the weight of the new toner with the old one. If the old toner is very light, it is nearly empty and should be replaced.
  • Sep 22, 2011 | Samsung CLP 315 Laser Printer
    Changed toner---back side now prints dirty with band on the top. Did the cleaning procedure - no luck
    If you changed toner because old was empty and now you have this defect with the new cartrige, it is most likley a defective cartridge. Try the old cartridge again, if it prints clean, then you know for sure it is the cartridge. If you purchased a new HP cartridge, get it replaced by HP, they warranty their toners against defects. If you bought a 3rd party toner, return it to where you bought it and get them to replace it. If you had your old toner refilled by someone, get your money back, they don't know what they are doing. This type of defect is often caused by a filled waste toner bin then then runs back out when you print. Some refillers just throw toner in and don't empty the waste toner bin.
    Jun 07, 2011 | Office Equipment & Supplies
    I will refilling in toner Samsung scx 4x21 printer but display is toner empty what to do sir
    I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder. When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
    Jun 01, 2011 | Samsung SCX 4521F All-In-One Laser Printer
    Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
    Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
    Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
    Streaking on left side of page
    This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
    Mar 18, 2010 | HP LaserJet 1200 Printer
    I have samsung scx-4300 printer this time show toner error
    good day sir, these are the possible causes of toner errors of samsung scx. You can check all this causes.
    • You have used an unauthorized cartridge.
    • the toner cartridge is not installed.
    • Paper has jammed in the fuser area or in the fuser manual feeder.
    • The toner cartridge has run out.
    • the toner is almost empty.
    • To prevent serious pollution of breakdown of printer, the printer stops printing.
    • the toner cartridge is not a samsung genuine cartridge.
    hope this will help you. god bless.
    Mar 24, 2009 | Samsung SCX-4300 Monochrome Laser...
    Printing in grayscale
    yes u can use it with black and white
    Nov 01, 2008 | Dell 3010cn Laser Printer
    Not printing, making me crazy
    A paper jam has occurred. To solve the
    problem, see “Clearing Paper Jams” on
    page 6.3.
    • The front or top cover is opened. Close the
    front or top cover.
    • There is no paper in the tray. Load paper
    in the tray.
    • The waste toner container is not
    installed or full. Check the container.
    • Your system has some problems. If this
    problem occurs, contact your service
    representative.
    • Also i can indicate that the Toner Cartridges are empty and need replaced with Genuine Samsung Cartridges
    Jun 17, 2008 | Samsung CLP 300 Laser Printer
    Lexmark X215 MFP All-In-One Laser Printer Logo
    255 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
