Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
I need to remove the furniture door off my integrated dishwasher
The handle has threaded and I need to replace it but I don't know how to remove the furniture door. I have tried just lifting the door but it definitely does not come off this way.
Appliance is a Tecnik SE6TIE 1 GB/29
I have the same problem.I need to take off the door from the integrated dishwasher.I can see a possible screw on the either side of the door but difficult to visualise this to find out what kind of screw it is.
Can someone advise me regarding the method of take the door off the integrated dish washer.
Paul
Posted on Feb 28, 2009
I figured out which of the screws was actually holding the door on and managed to get it off. I did need a funny star shaped alan key thing to remove the screws but luckily we had a set of these already.
Many thanks anyway.
Christine
Posted on Feb 12, 2009
  • steve456 Oct 04, 2013
    And thanks for passing that info on christine!
Dishwasher door removal/replace
Short of buying new hardware, that is what I would do. Make sure that the threads are not metric and also make sure that you use stainless steel
Aug 13, 2013 | GE Profile PDWT580RSS Fully Integrated...
Loose Latch on dishwasher? The dishwasher keeps stopping - but will resume for a few more minutes if I lean against the door. Sorry, I don't have the model number on me at the moment.
Hi
Not knowing which make and model machine you have, the only thing I can suggest is either look from the top of the machine and see if there is an adjustment on the door latch or look in from the inside top and see if there is a screw on the latch that lets you pull the latch out slightly.
Sometimes you need to remove the dishwasher cover.
Othertimes you may need to remove the front control panel to get to the door handle assembly and see if the micro switch or handle assembly is worn out.
Best thing is to advise the make and model so that I can point you in the right direction.
Open the dishwasher door and on the inside of the door there should be a compliance sticker with manufacturer's details.
Ash
Sep 06, 2011 | Whirlpool Dishwashers
I need to remove the furniture from an old tecnik DW 2677 dishwasher as I have a new one and want to replace the front. I cant see any screws or how to remove it
1 Open door and you will see 5 crosshead screw on each side, undo the top screws and lift up the plastic control panel to release it from the metal clips fixed to the back of the furniture door
2 Lift up the door to release the plastic clips (fixed to the back of the furniture door) from the keyway slot in the metal dw door
3 If its a 2677 that is the replacement the reverse the proceedure on the new one, there is no point cahnging the clips, if its not then
4 Swap over to new makes fixings and rehang the door
Jan 29, 2011 | Tecnik TDW2677 Built-in Dishwasher
Ikea Whirlpool integrated dishwasher door front
how do i take door off to fix handle back on dishwasher
Jan 03, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
Amana Dishwasher Mod. ADB1500AWQ, Door won't open.
HI,
Please check whether the plastic pins are broken.
I removed the inner door panel and found the handle broken. It has integrally molded plastic pins that provide a pivot for the handle to push against the release assembly. These were broken off. Also noticed that there were some small fingers molded on the back of the switch panel that were snapped off. I'm not sure what these are for and I can't see how they are needed for the latch operation. My hunch is that they aid in positioning the handle during factory assembly. I'm NOT going to buy a new switch panel to replace these!
I don't know why the handle broke but it did so in stages. I think one pin broke, and then everything else broke because of added misalignment and stress. The good news: a new handle only costs about $10 and I'll have it in a couple of days. Thanks
Apr 24, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Bosch SGVV53E03GB/55 cannot get panel door off
I have an SGV53E23 so don't know if this will help. My door is screwed but also held in place by 2 double sided sticky pads about half way down. They stick like the proverbial so try easing the door off one side at a time and look down to see if you can see any sticky pads. If so firm but gentle easing will get the baby off.
Jun 20, 2008 | Bosch 24 in. SGV53E03 Built-In Dishwasher
Neff integrated dishwasher
there are some screws inside the door, around the edge. These would be the first to undo then I think the door would have o be pulled up slightly to relaease.
Mar 28, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
2,009 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
