Question about PfaFF Creative 7570
Hobbylock 796 left thread not sewing
The machine is all threaded but the left thread is not looping in with the others.
If the machine is correctly threaded this could be caused by incorrect installation of the left needle, if not full inserted it can cause the machine to drop the stitch, just loosen the needle and push it up into the holder.
Posted on Nov 27, 2011
I have a Hobbylock 796. Trying to sew stretch lace. Great difficulty. Could you please help with tensions numbers.
Stretch lace may present a challenge in itself. Be sure to use ball point needles. Try threading with 4 different colors and practice on a piece of scrap lace. The thread colors will help you determine which thread tension to focus on adjusting to get the result you want.
Dec 01, 2017 | Sewing Machines
I need a video on how to thread a pfaff hobbylock 4842 serger
Pfaff has a video on threading the Hobbylock 4842 here: http://www.pfaff.com/mediafiles/threading_guide/index_en.html . You need Adobe Flash Player available on your browser. Enter the tutorial, the link is below the Quick Help paragraph. Then choose the correct machine (from the links across the top). Then use the drop-down menu to choose the stitch that you will be sewing for the appropriate threading video. Then click on the appropriate thread (below the video window) to see how to thread that section of the serger. (For two-thread stitches, you will see two options are greyed out.)
I hope this helps.
Jun 14, 2017 | PfaFF Sewing Machines
Pfaff hobbylock 4842 serger - how to thread
here is a manual:
PFAFF hobbylock 4842 Instruction Manual
Be sure to ALWAYS RAISE the presser foot when threading the machine. Also, thread each thread in the ORDER specified or your machine will most likely never stitch correctly (usually, the upper looper first, lower looper next, and then the needles).
Left needle thread not connecting
Timing an overlocker is NOT for home service, it takes training, tools, gauges and experience take it in to get it fixed
Jan 06, 2014 | White Sewing Superlock 1934D Mechanical...
Hobbylock 797 how to thread
The hobbylocks all thread in much the same fashion.  There is a diagram for a four thread hobbylock on this website.  It would be better if you found a Pfaff dealer to show you as it is quite complicated.
http://www.pfaffmachines.co.uk/overlock/pfaff-hobbylock-2-overlocker.htm
Once you have it threaded, always cut the old threads at the spool and knot new ones on and pull through.  You will have to thread the needles as the knots will not pass through but it does save an awful lot of frustration when needing new colours on the spools.
Mar 28, 2011 | PfaFF Sewing Machines
Janome 4400 bought new bobbin holder but still have lots of issues with thread looping while sewing. The repair person says I pull the thread forward after cutting it and undo the proper bobbin threading....
looping the material ( bird nesting) is an indication of incorrect needle thread tension before threading the needle pull the thread and there should be resistance to the pulling
Nov 15, 2017 | Janome MC 4400 Computerized Sewing Machine
I own a Bernina 1260 and am having a problem adjusting my bottom thread (it has loops in it). I have tried adjusting the tension but I still cannot get a perfect bottom stitch.
Hello
You would pull out several long lengths of matching thread from my spool of thread and knot the threads together at one end (to hold them together). Grab the knotted end of threads with your left hand and place the threads(held taunt together) under the presserfoot of your sewing machine.
Select a narrow zigzag stitch that will zigzag over the threads, and holding both the knotted end(Left hand) and the other ends with right hand( holding tauntly), zigzag down the length of the threads.
You can use this for matching button loops, cording for belt loops, or whenever you need matching cord. The thickness of the cord will depend on how many strands of thread you want to use. You insert the loop of cord into the seam, so that when the garment is turned RIGHT SIDE OUT, the loop will be sticking out of the seam and you can put the button through the loop.
THANK YOU FOR VISITING FIXYA
Feb 02, 2011 | Bernina Sewing Machines
My machine will not stitch....have tried every combination and it keeps dropping stitches
Start with brand new needles. Make sure you use sharp needles for woven and ball point for knits.
Remove all threads from machine. Open all covers,, including top cover (under thread tension). Remove all lint. Oil moving parts. Replace covers.
Thread your machine from right to left. In other words, start with the lower looper, upper looper, right needle, then left needle. That should solve your problem. Thread must be threaded in specific order and through every loop in order to work. One miss threaded loop will cause the machine not to sew properly.
Apr 16, 2010 | White Sewing Superlock 2000 ATS Mechanical...
Hi :) Just got a Hobbylock 788 and need to thread
Here is the trick: If you look at your thread spools, left to right, thread machine beginning with thread from spool 3, then 4, then 1, then 2.
Thread 4 is tricky. You must line up the purple line on the big wheel on the right end in order to do this. Thread the machine according to the diagram on the inside, then, making sure you lined up the purple line, push the lever at the bottom of the machine (below threading guides) to the left while holding on to the thread end. This will push the thread up and along the horizontal arm you just threaded.
Mar 21, 2010 | PfaFF Sewing Machines
How do i thread this machine
thread this machine by taking a strain of thread from the spool pull it to the thread guide on top left side of machine criss cross the thread when you wrap it around the thread guide pull thread down and loop it under the needle thread tension control dial bring thread up and loop it on the thread take up lever, continue down to the needle looping it first around the metal piece above it then through the needle it self pull thread to back of sewing manchine with the bobbin thread
Feb 12, 2009 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
338 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
