Question about Dell Inspiron E1705 Notebook
ADAPTER WILL NOT CHARGE MY LAPTOP
OK MY LAPTOP BATTERY DIED AND THE ADAPTER WILL NOT CHARGE THE BATTERY THE ICON LIGHT WILL NOT LIGHT UP INDICATING THAT IT IS CHARGING EITHER SO I BOUGHT A NEW BATTERY I PUT IT IN AND IT WORKED SO I PLUG IT IN AND IT STILL DOES NOT PICK IT UP IT TELLS ME TO CHOOSE A DIFFERENT POWER SUPPLY WOULD I NEED A NEW ADAPTER??
  • 57 Answers
Yes, more than likely you will need a new power supply. You can locate them at any computer store.
I hope this solution is helpful. Please remember to rate this solution.
Posted on Feb 11, 2009
Battery/Ac adapter issues for Sony VAIO Model
So I gather the laptop does not run when the battery is in and the AC adapter is not connected? Laptop batteries tend to ware down over time and will need to be replaced as they end up not being able to hold any charge. Look online for a new replacement of the battery under the model number of your laptop
Aug 13, 2013 | Sony VAIO PCG-K33 Notebook
Hello. I have a lenovo n500. The battery died after i unplugged the adaptor for a few minutes. I plugged the adaptor back in blue light on adaptor and blue light on laptop are on- no power up. I have tried...
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 28, 2013 | Computers & Internet
My Pavilion g6-1b79dx notebook will not charge even with a new battery and charger. The light indicating the charger is plugged in is blinking white
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/replacement-hp-pavilion-g6-ac-adapter-19v-90w.html
Dec 09, 2012 | Plantronics Hp - Pavilion G6-1B79Dx Laptop...
Laptop will only work when plugged into the mains, battery will not charge
your battery may be died or discharged comptletely and your power adapter are not charging.
get test the power adapter first, if it is ok, you should buy a new battery then
otherwise you should buy a new power adapter.
Aug 18, 2010 | Dell Inspiron 1525 Notebook
My Gateway NV5386u battery died and the computer shutdown. When I tried plugging it in, it still would not turn on. The adapter part of the charger has a green light, indicating power is being applied, but...
Often when a battery is real flat, it hangs up the entire system. What you need to do, is remove the battery completely, as the laptop should be able to be powered by the AC adapter itself. You may find if that is the case that your battery has gone bad, and you will have to replace it. If your laptop, will NOT work from the AC adapter, then either the adapter is faulty, or there is an internal vault, in the Power conditioning circuitry inside the PC. Try another adapter, if still no go, then it is definitely an internal problem.
Jul 16, 2010 | Gateway NV5386u 156Inch Laptop (Blue) PC...
Laptop not working on battery, i have changed the battery
There are several simple indicator to determine the source of the problem. There are 4 major components involved, the laptop circuitry, contact terminal, AC adapter and battery. Every laptop has a LED light indicating if it is in the charging mode (without powering up the laptop). Start out with your laptop shutdown. Pull out the battery, then plug in the AC Adapter. See any LED light go on? Try again, the same procedure now with the battery plug in first, then plug in the AC adapter. See any additional LED lights go on? If there is no different, than the laptop can not detect your battery. If the AC adapter can power up your laptop, you can eliminate the battery (assumed brand new battery) & AC adapter. This only leaves you with the laptop circuitry & contact terminal. If your laptop can charge up your old battery or any battery, then it might be still the battery & contact. So, you try these procedure to reduce down to the "problem" component.
Oct 13, 2009 | Acer Aspire 5315 Notebook
Laptop computer won't turn on...
this is ur battery problem so just get ur baterry cheked
Jun 25, 2009 | HP Compaq Evo n610c Notebook
DC Adapter for laptop doesn't work
there is nothing you can do appart from replace the car adaptor or check that the cigarette lighter is recieving power to the socket
regards
Nov 24, 2008 | Dell Inspiron 6000 Notebook
Acer laptop
If the machine works properly with no problems, it's probably the battery light, indicating that the battery is no longer working properly, ie.. not charging, not holding a charge, not charging completely, etc... and needs replacing. Somewhere right around the light there should be an icon or symbol, I'm betting a little battery icon.
Jul 08, 2008 | Acer Aspire 3003WLCi Notebook
I CANNOT OPEN!!!
Hi, Try running you laptop with the battery and the AC adapter. If by plugging in your adapter there is no light indicator likewise or no powering up, then presumably there is a problem with the power supply circuitry in the motherboard. Normally the laptop should work with just the adapter, just the battery or both the battery and the adapter. If it will not perhaps your best bet is to seek professional repair service since this would require opening the motherboard. In most instances, this involves an smc fusible link, regulator transistors or even just cold solder or loose connections. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Sep 24, 2007 | Acer Aspire 5500 5570-2609 Laptop
Dell Inspiron E1705 Notebook Logo
134 people viewed this question
Alun Cox
