Question about Nokia 6021 Cellular Phone
Message Contact service Nokia 6021
Is there a possibility to save information from a Nokia 6021 after the moment that the message appears: Contact Service.
When I start the phone gives immedeate this message sometimes i can put in the pincode, but always the message Contact Service Appears
  • 52 Answers
It sounds like it has gone into secure mode...have you entered any codes unsuccessfully into your device before it did this? If you entered any codes in before this happend and you have turned off your phone and turned back on and it's still doing the same thing..unfortunately anything you saved to your phone is a loss cause.
Posted on Feb 11, 2009
Missing contacts, same sim card
You didn't save them to your SIM card on your old phone.
If you take your old phone & your new phone into a store you can ask them to switch the contacts over & they should be able to do it right then in there in just a few minutes.
Jun 06, 2013 | Nokia 6021 Cellular Phone
How to slove the network fault in nokia 6021
Hi there!
If you're encountering this kind of problem on your phone then all you have to do is powercycle your phone.You can do that by removing the battery while the phone is on.After 15 seconds kindly reinsert the battery and turn the phone on again.If you still have the same error message then kindly go to a different location because it might be that the phone is not getting a good reception.And if you still have the same problem then kindly contact your service provider because its a probable issue with the network,not with the phone.
Thanks!
Apr 17, 2011 | Nokia 6021 Cellular Phone
Setting web
Hi, The easiest and simple way to set web connection on your Nokia is to contact your service provider ( or check it on service provider website). Each service provider has difference settings of web connection on particular phone. It will required user name, password ( if any), proxy etc.
Regards, Jay
Jan 19, 2011 | Nokia 6021 Cellular Phone
Nokia 6021 I have set the email setting, when I try to retrieve emal I get an error message saying subscribe to gprs first, I don't know what this means
GPRS stands for General packet Radio Service. It is a technology that provides internet facility to mobile phones. To check Emails on your Nokia 6021 you first have to activate GPRS facility on your connection. For activation of GPRS contact your Customer Care number and ask them to activate GPRS facility and to send GPRS settings on your number. After activation of GPRS you can check Emails on your phone after proper email settings.
Hope this will help for sure..cheers:)
Oct 01, 2010 | Cell Phones
MODEL NOKIA 6021 CONTACTS STORED IN PHONE MEMORY DELETED BY MISTAKE HOW CAN I RETRIEVE IT?
H,
Once you delete the phone numbers from phone then it is not possible to retrive the phone numbers.
If you saved the numbers in SIM card then you can copy to phone memory.
To copy contacts from SIM card to phone,Contacts > Copy. You can copy names and phone numbers from the phone contact memory to the SIM card memory or vice versa.
Thank You
Aug 11, 2010 | Nokia 6021 Cellular Phone
Try to turn phone on but it says "contact service and goes back off
this problem maybe firmware problem, if you have flash box, just flash it..if you have don't, send to technician near you to flash firmware phone. latest firmware ver 5.22. for nokia 6020/6021.
Jul 20, 2010 | Nokia 6020 Cellular Phone
I have a nokia 6021 and my screen is broken how do i transfare my numbers from phone to sim
This works for the Nokia 3109/c and also the 2323/c which have a Nokia menu like in the picture. If you have the same menu then it should work. The handsets have a central navigation button which allows you to move up, down, left and right through the menus.
Save Contacts to SIM blind. Nokia Broken Screen
Press Central Navigation Button to get Menu
Press Up once - Contact Menu
Press Central Nav Button
Press Up once - Copy Contacts Menu
Press Central Nav Button - From phone to SIM card
Press Central Nav Button - Confirm copy
Leave for a few minutes depending on how many contacts you have to copy
Press Button above call end several times to exit from the menu
This also maybe useful
Delete Inbox Messages Blind Nokia Broken Screen
Press left once
Press up once - Message Menu
Press up twice - Delete Messages
Press down once - By Folder
Press Central Nav Button - Inbox
Press Central Nav Button - Confirm Delete
Note on the 2323 (not sure about the other models) you have an option to keep unread messages. If you still want everything deleted then swap confirm delete step above for
Press Left hand button set above green call button - confirm delete all messages
Delete Sent Messages Blind Nokia Broken Screen
Press left once
press down three times - Sent Items
Press Central Nav Button - Confirm delete
http://www.fixya.com/uploads/images/eb5cca9.jpg
May 21, 2010 | Cell Phones
Nokia 6021
Take it to your service dealer and ask them to test it and if possible to retrieve your data. Sometimes they will be able to make the phone work long enough to be successful. You will likely have to replace the phone anyway, so this process will relocate your numbers to your new phone if successful.
Nov 01, 2007 | Samsung SCH-a670
Nokia 6021 Cellular Phone Logo
738 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
