Question about Stoves Premier 720GRa Gas Double Oven
How does the q900 works
Hi every body
I recently bought i used kitchen with a built in double oven stoves Q900 GRF do but I could not but to work, because I don't know how and the buttons(5 in total ) are missing (only the signs and the wholes where the buttons suppose to be ), I coonected it to electricity and gas but I don't know how it works. Any ideas?
  • 38 Answers
I do not know either but I would be tempted to turn off the gas, but keep the electric to the oven, and use a plastic Knitting needle to find out. It should show on a display somewhere.
Posted on Feb 11, 2009
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts -
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
Dec 19, 2015 | Thermador C272 Electric Double Oven
STOVE Q 720 GRF DO continuously on OR does not maintain the right temperature and goes off. Could it be the thermistor? Problem in both ovens
If it has a digital display, then it is computer controlled... which means you need a new controller board.
Dec 31, 2014 | Ovens Ovens
Stoves Q720 GRF DO main oven ignitor clicks / sparks continuously
Might be the PC board, or it might just be the switch behind the oven knob - try disconnecting the wire leading to that switch and see if the clicking stops. If it does, the switch is bad. If not, suspect the electronics.
Aug 23, 2014 | Ovens
Hello, i have a stoves q720 grf do double oven and the problem is with the lower oven, after about 20 minutes the oven switches itself off and the lights on the front of the oven flash on and off. van...
I have the same problem. After anywhere from 5 to 30 minutes the oven(s) switch off and the light and clock start flashing - I have to switch the cooker on and off to start using the oven again.
Any resolution please?
Oct 07, 2010 | Stoves 720EF Electric Double Oven
Using the oven timer of a Stove oven circa 1999
The normal STOVES label is on the rear of the oven, but there should be a small label visible on the left hand side of the lower oven when you lower the door. There should be a long product number on that with the unit serial number. The product no can be used to identify the unit. STOVES may be able to help here.
I have a 720EF handbook scanned and it is on my BT Digital Vault, so if you want this version give me a valid email address and I will ensure you receive a copy.
Mar 28, 2009 | Stoves 720EF Electric Double Oven
Cant work oven!
I have the Stoves 720EF manual stored on the BT Digital Vault which might help. If you want a copy of it, supply an email address and I will give it access.
Also someone else has said that if you speak to Stoves nicely they may be able to send an electronic version of the manual instead of the paper copy.
Nov 27, 2008 | Stoves 720EF Electric Double Oven
Stoves Q900 GRF DO fan assisted gas double oven
hi everyone, i hope this helps.
you may need to take the oven out and use a vacuum cleaner to **** out the dust from the back of the oven, i found that this is the cause for ovens not lighting and grill not working, its a simple thing to do, just pull the oven out and at the back you will see where all th dust has accumulated, just vacuum it out
and it should work. i have had so many problems that i am going to replace the whole piece of **** now that the fans have packed up !
stoves know that the ovens are rubbish and unreliable, but have done nothing to help (even the engineers know this)
Mar 13, 2008 | Stoves Premier 720GRa Gas Double Oven
Stoves Premier 720GRa Gas Double Oven Logo
359 people viewed this question
Top Stoves Ovens Experts
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
