Question about Acer Aspire 5315 Notebook
Acer Aspire 5920 will not power up
I was booting up my laptop, it was powered on for approximately 15 seconds. Plugged into the mains. Then... I am notsure there was a popping sound or whether that was the speakers losing power, but the entire thing just cut out. The mains is not getting through - the green light on the power unit flickers when it is plugged into the laptop but stays solid when not plugged in, and the laptop is not responding at all to anything.
    Sergeant:
    Champion:
  • 237 Answers
It sounds like the motherboard has been damaged. Might of been a short circuit some where.
Posted on Feb 11, 2009
Have an Acer Aspire 5920G that is dead. The power supply seems OK with the green light on and ~19 VDC on the DVM when checked. no power light on computer when plugged in, with or without battery.
It is possible that there is a problem with the connection from your power supply going to the main board of your laptop.
This is rather a technical problem and my best recommendation is to bring your laptop to a technician and have them check it.
Hope it helps!
Thanks!
Feb 02, 2011 | Acer Aspire 5920-6727 Notebook
My acer laptop 5920 just went off and now won't
Obiviously It is the problem of the connector of the power adapter.
Apr 23, 2010 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 will not power on at all. The
Just to make sure:
1. With battery alone in notebook, and no power cable, do you get power?
2. With the battery taken out, and power cable plugged in, you do get power?
IF YES to the above two questions
... and u can get power using the power cable but not using the battery, then your battery is dead and u need a new one.
Mar 16, 2010 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 won't turn on, the charger lights up, (bright green) until you plug it into the back of the laptop, then the light goes dim and flashes.still no power to the laptop,not even the fan.
Your power supply or regulator in you laptop has gone south. sorry no quick fix for this one. It needs repaired and would include tracking down soldered connections.
sorry to tell you this.
clb199@yahoo.com
pls rate me 4 stars
Nov 27, 2009 | Acer Aspire 5920-6727 Notebook
My Acer Aspire 5920 is not booting up. When the power supply is plugged into the wall, its green LED is solid. As soon as I plug it into the laptop, the light starts to flash. When connected to the AC...
Your motherboard is probably shorting out your A/C adapter, you may need a new motherboard. With a Dell, the A/C adapter light will be green when plugged into the wall but as soon as you plug it into the PC the green light goes off. Which means that the Motherboard is shorting out the A/C adapter...
hope this helps
Sep 08, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
My AcerAspire 5920 laptop won't turn on. It is plugged in. When I push the power button, nothing. No lights, no sounds, no action. It worked fine yesterday! What happened? How can I fix it?
Sir,
Unplug the power
Take out the battery
Wait 2 minutes
Put the battery back in
Try to turn on the machine
If that doesn't work, take out the battery
wait 1 minute
Plug in the latop and try to see if you can turn it on after that.
If that doesn't work, then yes it's something else
However try to hold the power on key down for 10 -15 seconds. If that does nothing take the battery out and use only the power adapter.
Thanks Good Luck
Aug 09, 2009 | Acer Aspire 5920-6335 Laptop
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5315 Notebook Logo
141 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
