Question about Apple LaserWriter 12/640 PS Plus Printer
Hi, I have a Apple Laserwriter 12/660 Colour Laser Printer with a little problem!. The printer was purchased out of town, so was freighted 1000 k's (600 miles) upon my purchase. When I tested the printer out all worked fine except image was not printing 100% - 1/3 of the image was not there and what was left prints 'side-shifted' to the left. I am guessing some form of Optical damage?. Not to sure. The printer is probably past its time, but If it can be fixed reasonably cheap then it might be worth it. Thanking you in advance, Pete
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Like most laser printer, your particular model requires consistent heat application on the whole sheet for the toner powder to adhere to the blank sheet. Your description indicates 2 possible issues:
  • '1/3 of the image was not there' - indicates that possibly the fuser/heater has switched off early;
  • 'prints 'side-shifted' to the left' - tells us that the paper did not travel evenly along the paper path.
Ideas you may want to try/consider:
  • clean the rollers;
  • check for anything not seated right;
  • if your model uses a removable cartridge to hold the toner powder, remove, shake vigorously and re-insert making sure it is seated correctly;
  • follow the paper path. If possible check for clearances between rollers to check if they are even;
  • if the unit is unit, look for any locking tabs, tape or inserts. They are placed to ensure that some of the mechanism do not move while in transit.
Good luck and thank you for using FixYa.
Posted on Feb 11, 2009
    Master:
  • 848 Answers
Make sure the Media Type setting matches the paper or media loaded. Also, the Halftoning and Color Adjustment Mode options may be set incorrectly for your document type.
For vertical banding, rough or grainy images run the Print Head Alignment utility to align the print heads for precise vertical lines. If the image does not contain the colors you expected, the color settings on your application software may need adjustment. Refer to your software documentation for help on adjusting colors.
the print head nozzles may be clogged. From the Utility section found in the apple printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check MUST be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
If the nozzle check prints completely, and you're still experiencing a problem, make sure you are using the most current version of the printer driver. You can obtain the latest printer driver from the apple web site. The resolution of your image may also be set too low. Increase the image resolution using your image-editing software, or decrease the size of the image.
Apple Laserwriter 8500 paper light out, when there is paper in the cassette. Not blinking. Solid yellow.
make sure the usb lead connection is secure
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow? ! question exclamation mark or a red X
this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Oct 06, 2011 | Apple LaserWriter 8500 Printer
12/640 PS wont feed from tray
I found the owners manual for your model, and it has detailed explanations of how to turn off the printing of the Startup page: This is where the owners manual is available online in .pdf format, at this URL: http://download.info.apple.com/Apple_Support_Area/Manuals/printers/0340211ALW12640UM.PDF Startup Page Info From your Owners Manual: (Yes, I've been reading the Manual for your printer. I have no life. :P ) From page 25 of the manual: "The printer takes a minute or two to warm up, and then it automatically prints a startup page. It prints the startup page every time you restart unless you turn the startup page off using either the Apple Printer Utility for the Mac OS or the Apple LaserWriter Utility for Windows. See Appendix A for details on these utilities." From page 249 of the manual: "Appendix A - Setting the Printer Default Settings" "Though the printer itself has no control panel, you can configure it by using programs on computers connected to the printer: - On Mac OS?based computers, use the Apple Printer Utility and the desktop printer?s setup function." So the answer is YES, you CAN setup the printer to not print the test page, but you have to use the setup utility on your computer to do so. Opening the Apple Printer Utility (From page 251) "The Apple Printer Utility has two windows: the Printer Selector window, which is similar to the Chooser, and the printer features window, which you use to view or change the printer?s settings." 1. Double-click the Apple Printer Utility. - The Installer puts the Apple Printer Utility in the Apple LaserWriter Software folder. You can move it wherever you like. 2. In the Printer Selector window, select and open the printer you want. - If the network has zones, click the zone where the printer is located. - Click the name of the printer you want. 3. Click Open Printer. - The printer feature window appears with the Printer Information category displayed. 4. To view or change settings under a category, click the arrow beside the category name to open the category and display its information and options. - Additional options may appear that you can also open and work with. When you are finished changing options in a particular category, you can click the arrow again to collapse the options. (NOTE: The option you want is "Startup Page".) 5. After viewing the information and making changes, click the Send button to send your changes to the printer. 6. Click the Close box to close the window. Turning the startup page on or off (From page 257) "The LaserWriter 12/640 PS normally prints a sample page when you turn the printer on. This page shows the printer?s name, the total number of pages printed, the amount of memory, installed options, and communication settings. You can turn this feature off if you wish. 1. Open the Startup Page category. - The Startup Page panel appears. 2. Click the checkbox to turn the startup page on or off. - When an X appears in the checkbox, the printer is set to print the startup page. 3. Click Send to send the startup page setting to the printer. That should remove the default printing of your startup page. HOWEVER, there is another possibility to affect a repair to your problem... As the paper-feed rollers get older, the rubber on the rollers gets slick and won't grip the paper anymore. Try buffing the rubber rollers with some fine sandpaper and see if that allows the machine to pick the paper up once again. If this is your problem, then you might make the lower-feed paper tray work again. Hope this helps, but let us know if you need more information to solve this problem. ;)
Aug 07, 2007 | Apple LaserWriter 12/640 PS Plus Printer
Just updated my mac to 10.6.1 It cannot see my apple 12/640 PS Printers.
Hello, I have the same problem after updating to Snow Leopard (10.6.1). Have you found a solution?? Thanks martinzeller@comcast.net
Sep 23, 2009 | Apple LaserWriter 12/640 PS Printer
HP 1000 Laser Jet Printer - error printing
Turn the printer off and then back on. Does it go to the ready state? or does it come up and error? If the error only comes up when asking the printer to print then the printer probably has a worn paper pickup roller. You can take the old roller out and rotate the rubber tyre a little.
Mar 26, 2009 | HP LaserJet 1000 Printer
Drivers for a C3200 Oki laser printer to go with an Apple MacBook
Do a google search, there are 3rd party drivers that work all sorts of old and odd stuff, the Oki sounds mainstream, the term is GIMP driver I think
Feb 01, 2009 | Apple LaserWriter 300 Printer
12/640 Laserwriter - driver needed.
I had the same problem when I got a new computer with Vista. I just went through the available 600 DPI printer drivers until I found one that worked ok with the 12/640 printer. The driver I used was the Samsung 6000 PS. I have had no problems with it.
Nov 19, 2008 | Apple LaserWriter 12/640 PS Plus Printer
Laserwriter 8500 "dirty" print outs
Toner bubbles are characterized by large blotches of color toner on
printed pages caused by color toner leaking from cartridges directly
onto the transfer drum. Solve the problem of toner bubbles by checking the manufacturing codes on the toner cartridges and replacing cartridges as needed. Compatible carts are notorious for this so don't use them.
Heat-stamped on the toner cartridge, opposite the label-end of the
cartridge, is a manufacturing code. If a portion of the code does not
match the list below, replace the toner cartridge.
Use toner cartridges that contain any of the following manufacturing
codes:
 9I
 9J
 9K
 9L
 any cartridge that begins with the numbers 0 through 6 in place of
the 9
Oct 09, 2008 | Apple LaserWriter 8500 Printer
Apple LaserWriter 8500 not turning on
There is a glass-tube fuse inside, near the power switch that blew on mine a couple of years ago. Being the curious type, I popped off the side cover to see if there was any obvious reason, loose connectors, burned resistors, etc., and found the blown fuse. Can't remember where I got the replacement, but think it was Radio Shack. It's a common type.
Dec 12, 2007 | Apple LaserWriter 8500 Printer
Apple LaserWriter 12/640 PS Plus Printer Logo
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Don  Farrell
Don Farrell
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
