Question about HP Pavilion dv6000z Notebook
The DVD Rom was disabled.
There was some problem in the driver hence when the system boots up it's not detecting the pioneer DVD R/W hardware. Pls tell me some solution for this problem.
  • HP Master
  • 32,281 Answers
To enable the DVD drive :-
Click on Control Panel - then System - then Hardware tab - then Device Manager - then expand DVD/CD-ROM drives.
Then right click on your DVD drive and click on Properties.
Then at the bottom under Device useage scroll down and select Use this device (enable) - then click OK
Posted on Feb 11, 2009
Problem associated to the booting sequence, the 'my computer window ' is divided into four fragmentations .at the floppy and dvd. thedvd is not highlighted therefore imposible to access thecd player
You mean the CDROM or DVDROM is not selectable as a booting option in the BIOS, right? There must be something wrong with the device, the driver or your BIOS. Is your hard disk still bootable? If so, you can boot in hard disk and see whether the DVD-ROM is still there and check the device manager of your Control Panel to see if any errors about it. If it is not working there, you can check whether all the cable connections are connected well and the jumper settings are fine. There could only be one master device on a single ribbon of the IDE interface. So if you have a hard disk and your DVD-ROM connected to the same ribbon and the jumper settings of both are set to master, you will need to adjust one of those settings to slave or cable selection. Then you can use the AutoDetect feature of your BIOS to detect the CD-ROM if available. If those are not working, you can uninstall and reinstall the driver of your DVD-ROM if available when you boot in hard disk and open device manager for hardware change scan or directly right click on the CD-ROM icon in device manager and select update driver then select the right driver downloaded from the manufacturer's web site. You can also plug that DVD-ROM to another computer and see whether it is working there to detect mechanic issues of it. If everything is working on the other computer about this DVD-ROM and it is not working on yours, you can also try to flash your BIOS and/or replace the ribbon and see if it works before you replace your motherboard.
Aug 23, 2010 | Computers & Internet
I have a toshiba satellite A laptop,it use to play DVD movies and now only plays music CD's. What can i do?
You have a software problem not a hardware issue. You will find that the register may need repairing. ( Run Mechanic program in Win xx ) or to put it simply the computer forgot it has a DVD/CD you should go into control panel revome the CD drivers in uninstall or add/remove hardware. Then reboot and let Win detect new hardware as the DVD/CD let it find the drivers over the net or if you know the infoof the DVD/CD 'select from list' to add manually. Chances are though you don't have a driver disk nor would it be able to read it because you will have disabled the malfunctioning driver so it must come from the inter net or change the boot sequence in the 'set-up' to cd rom first and put the original Win disc in the CD and reboot.
Happy movie'ing! < not a word, yet.
Good Luck. Let me know.
ash
Jan 25, 2010 | Toshiba Satellite A105 Notebook
Hp cd rom dvd drive
Try this quick fix :
Get a screw driver, unscrew your machine and remove your drive. If you cant do this by yourself, just try and get a good technician to do it for you.
After this, power up your system normally without the drive connected.
Then shut down properly, and reconnect the drive, making sure that its firmly connected.
Then power on again and check it in the system BIOS if its now detected, then save and exit, then boot your system properly again.Then when the system boots, just right click on my computer, then properties, then select the hardwares tab, then click on device manager.
When you get to device manager page, try and locate DVD/CDrom Drives, then click on it, if your drive is there, then just right-click on it, and select uninstall, and after this, on that same page, click on 'Actions', and select "Scan for hardware changes". But if its not there. Just click on the "Actions, and Then select "Scan for hardware changes".
This should automatically out it back inside your My Computer page.
Hope this helps you out.
Jul 19, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Toshiba Satellite P205D-S7479 Drivers for DVD-ROM
Download new driver files of pioneer dvd drive fron internet.
Apr 17, 2009 | Toshiba Satellite P205D-S7479 Notebook
The dvd-rom cannot be found. cd or dvd emulation software has been detected.
hi there,
try to detect in the CMOS set up. restart your computer in booting process press F2 or Delete tab
and check if your dvd is detected if not you should check the cable/ power connection of your dvd. and then try again.
if detected if your using vista update dvd drivers for vista and then if it is xp you have a like this if you downgrade your pc from vista to old XP. you have this problem. update to microsoft the SP2 and SP3 updates.
Nov 29, 2008 | Computers & Internet
VISTA and Pioneer DVD DVR-K17
(1) Try to detect manually from control panel "ADD new hardware".
(2) Check the device manger for DVD is not disabled
(3) Check vista is geniue and not tweaked too much
Apr 17, 2008 | Computers & Internet
Change CDROM on Toshiba 2805 -s 202
IDE 1 is the CDRom (or any optical device attached). IDE 0 (zero) is the Hard drive. So this message is telling you there is a problem with the DVD/CD-Rom, that has halted the boot process. Now you have no choice but to go to BIOS (read startup screen to find the procedure, usually DEL, F2, or F12 keys) and see if the problem can be corrected there (or if not, disable the drive, save change, and try rebooting again). If this is not possible, then you might try booting from an external device (floppy, CD, USB etc) if your system allows that (and if you have the boot software/media). Otherwise, you must remove the drive, in order to regain your desktop (pass the halt stage in boot process). Here is how to remove the CD:
Underneath the laptop, there will be a screw about 4 inches in, on a centyer line direct from the DVD/CD tray panel. Remove this screw. Insert a pin or paper clip (carefully, and STRAIGHT in!) to the small hole next to the CD tray release button. This opens the tray manually. Pull it out to the full open position, then GENTLY pull further, and the whole drive will release from the laptop.
Once you have reached the desktop, you should try to remove the previous driver if possible, via start menu/settings/control panel/system (or r-click my computer and select properties). In system control panel, there is a hardware settings tab. Here you can remove or disable hardware. Try adding a "generic CD-Rom", so the DVD might get past boot process when you reinstall it (later, below).
Now, try to start the laptop without DVD/CD. If it starts normally, your driver change was incompatible, or possibly, in the process of changes you did something that impaired the drive or its ROM (or perhaps needs to be cleaned).
Now try reinstalling the CD Rom drive (no screws yet, just insert fully). If you are still at the same halt, you have cut yourself out of using this CD, unless perhaps tou can reboot with a windows CD while the drive is installed, and let windows detect and install a PROPER driver.
If that is not possible, you need another DVD/CD drive. You can also buy a replacement or cheap older model for testing system at any legitimate advanced PC shop, or many used computer parts stores. Try the drive before you buy, just slide in and mount a CD/DVD. (you may have a special adapter that must be removed from the old OEM drive and attached to new one, and the tray cover may need to be switched to allow the CD to close for testing)
Regardless of the outcome of any of the above, please post your results, and the complete text of the black boot screen here, so I can analyze the problem -or any other possibilities that may be indicated by the post dialog.
Mar 05, 2008 | Toshiba Satellite 2805-S202 Notebook
HP dvd rom disabled
if you can open your desktop..try to replace the ide cable of the DVD/Cdrom it might be deffective.before you open your pc just make sure that the power is off.after changing the ide cable of your dvd the system will automatically detect your drive.if you got same problem again try to consult your hardware vendor to claim your warranty parts and service.good luck
Dec 03, 2007 | HP Media Center m7060n PC Desktop
Dvd/cd rom drives
i cnt run my dvd rom drive but only cd.disk
Oct 15, 2007 | ASUS 52x (CD-S520) QUIE TRACK BEIGE RETAIL...
My DVD Rom is not detected by the system
When it comes to installing a new driver you have to make sure is supported by your PC, that said it may be that you need an installation CD, if the driver does not come whit one try to download it from the website of the manufacturer. another solution can be that your driver may be conflicting with another driver, this means that your problem driver needs to be a master or slave check on the installation manual that came with the driver. Try this
Aug 21, 2007 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
