Question about Spark Plugs BR4HS Plug 10/BX #3322
Spark plug settings for ford focus 1.6 zetec
Spark plug settings
  • 211 Answers
Hi
The sparkplug gap 0.7 mm
Posted on Feb 11, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Weak spark on #1 and #4 spark plug how do i repair this
Check your ignition coil. Could be the cause. Also check crank and camshaft sensors with a scope to see if you have a uniform pulses. I hope it helps.
May 01, 2014 | 2000 Ford Focus
2003 ford focus 2.0 liter zetec 16 engine. Miss in engine.
check the timming, check spark plugs, check compression of the cylinders, check spark plug wires and if all else fails replace the ignition coil module
Aug 28, 2013 | 2003 Ford Focus
What type of engine oil for 1.6 focus zetec 2003
2003 FORD FOCUS 2.0L 4-cyl Engine Code [3]
Engine Oil Grade 1......API* All TEMPS......SAE 5W-20, Engine, with new oil filter 4.3 liters.
Thank you for using fixya and good luck Oil Drain Plug.....17ft/lbs Torque
Apr 27, 2010 | 2003 Ford Focus
2001 Ford focus
lol, I never knew they made a sohc focus, 99% of these are zetecs DOHC. so they have the spark plugs down the middle of the cyliderhead.
Jan 13, 2010 | 2001 Ford Focus
Timing belt slipped on 2003 1.6 focus need the timing marks
there are no timing marks as such on the focus mate you have to lock the cams with a setting bar (to do this you need to remove the rocker cover and lock the cams with a locking bar)
the crank is locked up by removing a plug behind the oil pump on the back of the engine (the crank needs to be at top dead center on number 1 cylinder and this can be done by removing number 1 spark plug and using a long piece of welding wire or screwdriver, place in to the cylinder and turn over until the piston is at the top)
with the cams locked and the crank locked your engine will be timed up
please let me know if this has been of any help
cheers
big mike :)
Dec 29, 2009 | 2003 Ford Focus
How to change the spark plugs on a 1.6 zetec ford
get a plug spanner (more a socket than a spanner) and after removing the plug lead, use the spanner to remove the plug. Do one at a time so you dont get the leads mixed up or it will not start.
Nov 23, 2009 | 2002 Ford SVT Focus
What are the spark plug settings for a 1.8 zetec engine
you can set the gap by using the new spark plug casing papar thikness.try it and it will work
May 24, 2009 | 2000 Ford Focus
What Bosch super 4 spark plug fits a Ford Focus 1.6 zetec.
my advise don't get those, they don't work as well as you think they do.
if you think about it if they are so much better why don't drag racers use them?
because they actually block the ignition point.
just get the factory style plugs and you will be better off.
May 16, 2009 | 2001 Ford Focus
How do I change the transmission oil in my Ford Focus 1.6 Zetec SE 16 value engine ?
  • drain oil using allen key plug underneath gearbox till all oil is drained refit use new seal if old 1 is damaged then look at front of g/box quater of the way up is another allen key plug remove fill with new oil till it starts to run out hole refit plug and ur done
Jul 09, 2008 | 2000 Ford Focus
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
1,329 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Ian Kime
Ian Kime
Zachary Reed
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
