Question about AMD Mobile Athlon XP-M 2800+, 2.13 GHz (AXMJ2800FHQ4C) Processor
Need Guidance I want to know that is there any way by which I can use change my IP Address time to time so that i can download files from the same site without getting an error : "Your IP ............. is already downloading a file please try again later" If ther is one then please tell!!!
    President:
  • 1,073 Answers
You cant change your ip yourself, the ip is provided from you internet-provider, but you can go via proxy servers and that way get different ip:s
Or via anonymus server who dont shows your ip at all
Nic
Posted on Feb 11, 2009
How to change ip address
Method 1:
To release and renew your IP address:
Step 1
Go to "Start > Run" and type "cmd" (without quotation marks), then select "OK"
Step 2
Type "ipconfig /release" (without quotation marks) and press "Enter"
Step 3
Once the prompt returns, type "ipconfig /renew" (without quotation marks), then hit "Enter,"
Step 4
Last, type "exit" (without quotation marks) then press "Enter" to close the window.
you have a new ip address.
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at Ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always..It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always .. You can also display your ip from Canada using proxy,even if you are in USA.
Aug 27, 2013 | Computers & Internet
Tip
DHCP Server configuration in Linux
Linux is a UNIX based operating system. It is a server operating system. REDHAT Linux is Enterprise version of Linux. Now a day's Most of corporate sectors use red hat Linux as server in their company because it is secure very much.
Full form of DHCP "Dynamic Host Configuration Protocol. DHCP server assigns IP addresses and other network configuration information like subnet mask, broadcast address, etc to computers on a network. The DHCP assignments are the following.
Lease Request: Client broadcasts their request to DHCP server with a source address of 0.0.0.0 and a destination address of 255.255.255.255.
IP lease offer: DHCP server replies with an IP address, subnet mask, network gateway, name of the domain, name servers, duration of the lease and the IP address of the DHCP server.
Lease Selection: Client receives offer and broadcasts to al DHCP servers that will accept given offer so that other DHCP server need not make an offer.
The DHCP server then sends an ack to the client. The client is configured to use TCP/IP. Lease Renewal: When half of the lease time has expired, the client will issue a new request to the DHCP server.
Installation of DHCP server: First of all while install the RedHat Linux enterprise version server be careful about the ports and the services must be turned on. To create DHCP server in Linux first download DHCP RPM package and install with "rpm-ivh" command. Where I have done it there I have create YUM server, so easily I have download and install it by YUM (yum install dhcp version). DHCP package will locate in /usr/share/doc/at Linux file system. I copied the DHCP's files from /usr/share/doc/ to /etc/dhcpd.conf.. Then I started to configure the dhcpd.conf file to route the DHCP server in there local network. I have open the configuration file with "vi" command. Then commented out the lines from "default gateway to option netbios" because system don't read the commented lines. After that I set the range of IP address in dynamic- bootp of their local assumption of system. I have change the "next-server" with the dhcp server name and have also change the fixed address with the dhcp server IP address (end range of dynamic IP). It is very easy job to configure DHCP server. After configure the .conf file of dhcp just turn on the service with "chkconfig" command and restart the dhcp service. After that entire job I reboot the system. And after rebooting of server I turned on the other client system. While startup the client system without static IP address all of those picked up IP from dhcp server and going on successfully. I have prefer the command line mode to do the total job.
The DHCP server configure file is following:
ddns-update-style interim
ignore client-updates
subnet 192.168.1.0 netmask 255.255.255.0 {
# The range of IP addresses the server
# will issue to DHCP enabled PC clients
# booting up on the network
range 192.168.1.201 192.168.1.220;
# Set the amount of time in seconds that
# a client may keep the IP address
default-lease-time 86400;
max-lease-time 86400;
# Set the default gateway to be used by
# the PC clients
option routers 192.168.1.1;
# Don't forward DHCP requests from this
# NIC interface to any other NIC
# interfaces
option ip-forwarding off;
# Set the broadcast address and subnet mask
# to be used by the DHCP clients
option broadcast-address 192.168.1.255;
option subnet-mask 255.255.255.0;
# Set the NTP server to be used by the
# DHCP clients
option ntp-servers 192.168.1.100;
# Set the DNS server to be used by the
# DHCP clients
option domain-name-servers 192.168.1.100;
# If you specify a WINS server for your Windows clients,
# you need to include the following option in the dhcpd.conf file:
option netbios-name-servers 192.168.1.100;
# You can also assign specific IP addresses based on the clients'
# ethernet MAC address as follows (Host's name is "laser-printer":
host laser-printer {
hardware ethernet 08:00:2b:4c:59:23;
fixed-address 192.168.1.222;
# List an unused interface here
subnet 192.168.2.0 netmask 255.255.255.0 {
on Mar 17, 2011 | Computers & Internet
Hpow u change ip adres
Method 1:
Step 1
Step 2
Step 3
Step 4
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at www.ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always.It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always.You can also display your ip from Canada using proxy,even if you are in USA.
Aug 07, 2013 | Computers & Internet
Lost my IP address from zyxel
According to me there are two reason for not connecting to internet through your ISP.
1. Configuration setup might have got deleted
2. Driver files may be corrupted
An important thing to know is We would not lose our IP address.
Static IP address wouldn't be changed while restarting our modem,
Dynamic IP address changes on every restart of our modem. To know the Current IP address the following URL will be useful to you. http://www.ip-details.com/
Jul 25, 2012 | Zyxel P-2602HW Router (P2602HW)
How do I set an ip address on a panasonice dp 190
Hi
I have put an PDF files on my website for you to download.
This will tell you hoe in the file.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/PDL_OI.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Apr 26, 2010 | Panasonic Workio DP-190 Multifunction...
I HAVE ONE IRC 3200 AND I DONT KNOW WHAT DRIVER INSTALL FOR SCAN AND PRINT, I HAVE WIN XP
Go to http://www.usa.canon.com
Select Downloads
Select Office/Production
On next page from the dropdown select Office/Production products again
Next page Select Networked Office Systems/Copiers
Next Page select Color ImageRunner Series
Next Page Select Color ImageRunner Series
From List select Color Image Runner Irc-3200
From the choices select the driver needed. PCL or PS (postscript)
Select either Setup or INF.
If Setup or INF file. Download the zipped file. Create a folder on desktop or downloads. Call it Canon Copier or whatever. Download the zipped file to this folder. Go to the folder you downloaded the zipped file to and double click on the file. When Win-Zip started and asks where you want the file un-zipped to enter a period (.) this will unzip the file to the folder you created.
Once the file is un-zipped if you downloaded the setup file run setup exe.
At somepoint in the setup process you will be asked which port you want to use. You will need the IP Address of the copier ( which can be obtained by pressing the additional Functions key on the copier, selecting report settings, selecting Network and print report. If the IP address needs to changed select additional functions again, Select System settings Key, Network settings key, TCP/IP settings, Check or Set IP Address here or select DHCP to get new address. Repower the copier if any changes are made.
At the which port to use select New Port, select Standard TCP/IP port and create new port. Enter IP address in the new port window.
If using INF file after INF is unzipped. Go to Printers folder and select create New Printer. Follow Printer Wizard. Create New Standard TCP/IP port. When the Wizard Asks for Driver, select have Disk and browse to the folder you created and click the unzipped file and continue clicking until the file installs.
Mar 20, 2010 | Canon imageRUNNER C3200 Copier
I am using Belkin F5D7632ak4A. My problem is that:
In doing a port forwarding, you actually need to assign a manual address on the computer where you are using the service port for the computer not to change the IP address. If your private address on the network is 192.168.1.XX then you may assign on your computer 192.168.1.2-99 any of the address there. Also you may need to know the DNS you are using on the router which you can find on the status tab of the router.
To assign an IP address, if your computer is wired then right click on the wireless connection and select properties, if it is a wireless computer right click on the wireless connection and select properties.
After you have selected the said properties> look for Internet Protocol TCP/IP then select properties.
Then click on USE THE FOLLOWING IP ADDRESS and USE THE FOLLOWING DNS server as well.
then from there you can put in the set of address you have for ex.
IP address 192.168.1.10
subnet mask 255.255.255.0
Default gateway 192.168.1.1
DNS
preferred DNS 66.28.87.105
alternate DNS 66.28.87.104
Note: these are just example. after you have done assigning an IP address then you may do the port forwarding again. change the IP address on the port forwarding tab to the IP address you have assigned. Then don't forget to save the settings.
Jul 17, 2009 | Belkin (F5D7230-4) Router (587009)
Need BL-C30 installation exe file.pls hlp
Thank you for contacting Panasonic. We apologize for the delay in our response.
The CD can obtained through our parts department at 1-800-332-5368 or through the link below:
http://www.pasc.panasonic.com/epartr/
It can also be downloaded at http://netcamdealer.com/resources/file/82/103
The CD-ROM is not needed for setup. To setup the camera, type in the local IP address of the camera. If you do not know the IP address of the camera, press the reset button on the back of the camera to reset the IP address. This will default the IP address to http://192.168.XXX.253, with the XXX being replaced by the 3rd octet of your router IP address. For example, if your router IP address is 192.168.0.1, you will type
http://192.168.0.253 into your internet browser and you will be able to configure the camera. Another example is if your router IP address is 192.168.1.1, you will type http://192.168.1.253 into your internet browser and you will be able to configure the camera.
To obtain additional assistance for your product, please contact our Panasonic Customer Call Center at 800-272-7033. The hours of operation are Mon. - Fri. 9A.M to 9PM and Sat. - Sun. 10A.M to 7PM Eastern Standard Time. A representative will be available to assist you. Please have your case number 26813996 available at the time of the call.
Thank You,
Panasonic Consumer Support
Apr 13, 2009 | Panasonic BL-C30A Network Camera
IP Address
To check your IP you need to Go To Start Rum and type cmd and enter
You will find a DOS screen poped up . you need to type Ipconfig . It list you your IP. You need to have a local admin to change your IP
Dec 20, 2008 | Computers & Internet
Changing a Dell 3010cn IP address and Storecenter
Print a settings page from the printer. If you are not sure on how to get the settings page, download the user manual from support.dell.com, there should be instructions in there on how to get this. Once you have the settings page locate the IP address on the print out. Take this IP address (which may be different then the one you want to use) and open internet explorer, put the IP address in where you would normally type a web address, hit enter. This will take you to the embedded web server of the printer. Once you are there, you can look for printer settings, ip address or TCP/IP address. Once you have found this, you can set a static (meaning it will not change, unless you change it) IP address (the IP address your tech person gave you) and submit the information to the printer. The printer must be on and in the ready state for this to take hold. If you are prompted for a username and password for the embedded web server, dell default username in small case is admin, leave password blank or username admin, password is password. To confirm that the address has taken, print another settings page from the printer.
Nov 14, 2008 | Dell 5100cn Laser Printer
AMD Mobile Athlon XP-M 2800+, 2.13 GHz (AXMJ2800FHQ4C) Processor Logo
190 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
