Question about Hotpoint HSS25GFP Side by Side Refrigerator
Moved Side By side w/Dolly now Refrig side is not working
We moved our side by side Refrig. using a Dolly. Dolly was used on left side and the compressor is on the right side. Now the problem is, the Freezer side works good but the Refrig side will not get cold. It was unplugged about 2 hours before it was plugged back up at the new location and has been plugged up for over a week (hoping that it would start working again). Have we messed something up doing this, or can it be fixed?
    Novelist:
  • 161 Answers
I have seen this happen so many times with all appliances.
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer. The settings may both be numbers however, they work the same way as described above.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system but, this would also cause the freezer side to not get cold after 2 weeks.
Posted on Feb 11, 2009
Ice maker not working since i moved refrig
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
fs45
Aug 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do you turn off freezer,refrig. is a side by side with a lower freezer that pulls out. Recently moved and freezer door broke and need to use just the refrig.
I don't believe you can turn off the frezzer section because most if not all frezzer/fridge units use the frezzer section to cool the fridge side!!!! that's just how they are designed.
Sep 21, 2009 | Refrigerators
I have a Domestic 2804 frig in my RV, The freezer works great but the frig part will not cool at all, can you help
All cooling takes place in the freezer. The refrig/fresh food side is a parasite, depending on cold air circulation from the freezer side. The fan in the freezer provides that circulation, and usually the freezer control setting determines how much air is moved into the refrig side.
If the fan is up to speed and the both controls are set in a middle position, the refrig side should be fine. if the problem continues, replace evaporator fan motor or clear the blockage preventing circulation (usually frost build-up from a defective defrost system part or blocked defrost drain).
Jun 13, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Motor and compressor work but no cooling
If you tipped the refrig on it side to move it you must leave it unplygged for 24 hrs before plugging in.  Does the fan work?  If not see if something is stopping it.
Feb 01, 2009 | Hotpoint HSS25GDMWW Side by Side...
Fridge not cooling
Hello.
The most common thing that happens while moving a frig is when moving it they put the dolly underneath the condenser fan housing and bend it into the fan causing the compressor to overheat before it has a chance to cool down everything. If this isn't the case then I will send you a list of things to check out. Let me know.
Dec 07, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Refrigerator will not work
no such reset button that im aware off id check for the obvious power in, thermo on, perhaps a wire off the rear panel somewhere
Nov 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
I just had a new counter put and the refrig had to moved out. Now the cold water is coming out of the door front but I can't get the ice cube to produce. I have looked in the booklet but ofccourse that...
the unit has a duel water valve one side may be bad you can swap the wire on the valve and test to see if it comes into the ice maker when you press the dispenser t is located in the back left corner
Aug 21, 2008 | Whirlpool Refrigerators
Freezer dethawed
By the end of the day we realized we thought the refrig. part was working but was not. We pulled it out from the wall, unplugged and plugged it back in. Still no results. I unloaded everything from the freezer in the morning and refrig in the evening. Right after I got almost the very last item out, (the door on the refrig was opened and left opened) I moved the temperature control levers back and forth quickly, really just out of frustration, thinking, 'great no more refirgerator' - now what am I gonna do?!. i went to dump the last of the contents, and like some sick joke, the refrig started working and then the freezer. We have quite a bit of dust under the refrig. that may have been blocking a fan or something. I think God just wanted me to empty the refig contents and things that looks like pieces of the moon from my ridge. Go figure. I am praying no more problems.
Jun 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Control panel inactive
See if you accidentally unpluged or damaged any wires under the refer during the move. There are connectors that can sometimes easily pull apart if a dolly hits them.
Dec 17, 2006 | Samsung SRS20DTD Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
110 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
