Question about Kodak EasyShare One Digital Camera
Camera will ot turn on
Put new batterys in it and still nothing happensWhen I install a freshly charged pair of batteries the camera will not turn on. I have 4 sets of batteries ( 8 batteries ) and all sets do the same thing.
  • 350 Answers
Dear baldpate1, Wed 2-11-2009 3:339am EST (USA)
Please specify your Camera Make & Model!
How long did it work with the last set of batteries?
Check the battery connection areas inside the battery compartment and if dirty, clean with a q-tip & alcohol.
Are the batteries fitting tightly?
jack
Posted on Feb 11, 2009
  • Kodak Master
  • 13,433 Answers
Clean the battery contacts and make sure they touch the batterys properly.
if that didn't work unfortunately the problem you have is in the internal electronics of the camera.
if you are outside of warranty you can get free repair estimate from
www.advancecamera.com/repair
    Master:
  • 848 Answers
Hi
clean the contacts of battery placed in battery holder of camera....just press the start button firmly........still problem exists have faulty board........
Brand new Nikon 3100 with freshly charged battery will not turn on for the first time. When I install the battery and close the flap, a small green indicator light lights up, but that's it. On/Off...
Well you have 2 choices...don't go back to Best Buy because you don't want to and you'd rather live with a brand new camera that doesn't work or.....take it back!
Sep 04, 2011 | Nikon D3100 Digital Camera
Change the batteries message keeps appearing even with fresh batteries. The camera turns on then immediately turns off What's up?
This actually a really common problem among Canon point and shoot cameras. There are a couple of methods that have worked well for others.
1. Open the battery compartment and remove the batteries. Then take a regular wooden pencil and place the eraser end down onto the battery contacts. Rotate the pencil to remove any corrosion. Sometimes a lack of proper battery contact will result in the low battery indicator.
2. Take a toothpick and wedge the tip under the battery contact and break it off. This will put more pressure between battery and contacts.
You can also try installing 3rd party firmware at http://chdk.wikia.com/wiki/CHDK_in_Brief
This is a bit technical and will probably void your warranty, but might be worth the try.
May 08, 2011 | Canon PowerShot A460 Digital Camera
My nex tech binoculars will not turn turn on . Batteries are good
Was the camera dropped??
If it wasnt dropped try changing the batteries.
install a new or fully charged battery/batteries into the camera.
1. If the camera is on, turn it off.
2. If any accessories (memory card, lens, USB cable, camera or printer dock, etc.) are connected to the camera, remove/disconnect them.
3. Remove the battery/batteries from the camera.
4. Verify:
That you are using the correct battery/batteries for the camera
That the battery/batteries are correctly installed
That the battery/batteries are fresh or fully charged
Follow the battery installation and charging instructions in the camera User Guide
5. Turn on the camera.
Feb 08, 2011 | Cameras
Camera won't turn on to take pictures~
This is a common problem related to batteries. Use 2100mA or higer batteries fully charge batteries. This problem occurs when you use alkaline batteries or faulty NiMH batteries. To solve the problem try with new fully charged NiMH batteries.
May 14, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
My camera cant charge if I put it on the light it dosen't CHARGE EVEN IF I PUT MY USB CORD WHAT SHOLD I DO?
Please note that the camera will only charge from the computer if the camera is turned off. Also try a different USB plug. 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare M863 Digital Camera
Power button does not seem to work have put in new batteries but nothing happens
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
3. Turn on your camera without the memory card.
Dec 07, 2009 | Kodak EasyShare C613 Digital Camera
Turns on then off. I have bought a new battery. Still didn't work. Charged it for hours. Still nothing. Only 4 months old.
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair w.4 months and no cust damage it is covered under the warranty.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 13, 2009 | Kodak EasyShare M1073 IS Digital Camera
Put in fresh batteries and camera telling me WARNING!! BATTERY EXHAUSTED
Either the fresh batteries are bad (this can happen), or they were inserted improperly, or the camera is defective somewhere. Measure the voltage on the batteries with a multimeter (voltmeter). Alkaline (regular) AA batteries measure about 1.6v to about 1.5v when new. NiMH (rechargeable) measure about 1.24v when fully charged. Be sure to install them with the + terminal and the - treminal going in the right direction. There should be some indication of this in the battery compartment of the camera. Hope this helps.
Nov 10, 2009 | Nikon Coolpix 3200 Digital Camera
My P5100 will not turn on - no green light & lens is stuck in ''out'' position
If nothing happens with a fresh battery set, then nothing can be done. Some thing has to happen in order to be able to tell what is going on.
If there indeed nothing happening when a fresh battery set is in and the on button is pressed, that means the camera needs service or some serious repair. This could be something very simple inside such as a disconnected or loose cable. On the other hand, this can also mean that this camera is good for selling on a site such as Ebay as parts or a fixer.
There is a Nikon P5100. If it is a Nikon, then you may consider this link to call the Nikon co. and ask for either repair or a trade-off or trade up to a similar camera or better. Nikon does have a trade-in or trade-up program.
http://imaging.nikon.com/products/imaging/index.htm
Aug 31, 2009 | Cameras
Empties batteries in 2 minutes
please insert a new pair of batteries and check weather the camera starts in proper manner. does the flash charges. normally even if the camera operates and switches on in proper manner but if there is any problem in the flash section the flash does not fires or do not charge. and if there is a short circuit in the flash section that will result in warming and consuming up the batteries in no time. the heatin of the batteries itself indicates that there is a short curcuit in the camera.
Jun 20, 2006 | Nikon Coolpix 4600 Digital Camera
Kodak EasyShare One Digital Camera Logo
14 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
