Question about HP PSC 500 All-In-One Printer
Scanner will not scan
When i push the scan button it says: Cannot connect to the pc See customer care guide.
I have misplaced my customer care guide. how can i fix this problem?
  • gclark1168 Feb 17, 2009
    I have same problem, when you press scan it comes up with see customer care guide, dont have it as we bought printer second hand.
I was using windows XP and had their drivers installed (as HP won't create any new ones). I had the scanner working and I came up with the same message. Here's what worked for me:
You will need to reboot the computer while having the printer on. After I did this, the connection was remade and I was able to scan again.
Posted on Feb 26, 2009
  • 350 Answers
If it worked before try pulling all the plugs in the back and waiting at least one minute then replugging!
Have you installed any new software lately?
Jack
Posted on Feb 11, 2009
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
http://www.qvc.com/footers/E167092_quick-start-guide.pdf
Good Luck!
May 04, 2012 | PANDIGITAL PANSCN Office Equipment &...
I want to scan documents but i don't know how to do it. please give me the steps to operate the scanner
Title: Scanning a document
Hi, at first connect your scanner with your pc then-
?? Install your driver
?? After installation restart your computer.
?? When your computer start, go to "Start " and see the new installed software, open it and choose "Ulead photo Express" any thing which is your scanner supported.
?? Then open your scanner and put document into the scanner.
?? Close the cover.
?? In scanner a scan button is there , just push it.
?? Scanning will be start automatically.
Thanks!
May 13, 2011 | Computers & Internet
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
Need scanning instructions for F4280
This is a link to a site where you can download the user manual, setup instructions, and a basics instruction guide. http://www.generalmanual.com/Printers/HP-Deskjet-F4280-All-in-One-Printer.htm
This should help you out.
Jun 10, 2009 | HP LaserJet 4650 Color Printer Manual...
CX6600 SCANNER
Download the Reference guide for your machine from th eEpson web site. It will inform you what you need to do to complete the scanning options. you can also download the Epson Scan utility to help with scanning to email etc.
Jun 02, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Jan 02, 2008 | Radio Shack Pro-95 Handheld Scanner
132 people viewed this question
Seeker5211
Seeker5211
