Log in to the router's administrative console through a Web browser using the current password and username.
In
the router's administrative console, navigate to the appropriate
administration / security section where the password setting can be
changed. In this example, the Administration tab at the top of the
screen contains the Linksys router's password setting.
Choose a
suitable password based on the standard guidelines for strong password
security. Enter the new password in the Password box, and re-enter the
same password a second time in the space provided. Entering the password
a second time ensures you did not accidentally type in the wrong
password the first time.
The password change is not applied on
the router until you save or confirm the change. In this example, click
the Save Settings button at the bottom of the page to have the new
password take effect. You will see a confirmation window appear briefly
to confirm the password change was made successfully. The new password
takes effect immediately; rebooting the router is not required.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Boot up or restart your Toshiba laptop.
Immediately and repeatedly tap the F2 key on your keyboard until the start screen appears to change your BIOS (user) and supervisor
(HDD user) passwords.
Use the arrow keys on your keyboard to highlight "Set User Password" or "Set HDD User Password" and press "Enter" on your keyboard.
Type the current password in the box that appears.
Type your new password ox.
You will be asked to enter your new password a second time to confirm it.
Set up blocking schemes to block specific channels, ratings, and external viewing sources.
A password is required to gain access to this menu.
Setting up Your Password
For USA
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
Movie Rating
TV Rating-Children
TV Rating-General
Downloadable Rating
Input Block
For Canada
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
TV Rating-English
TV Rating-French
Downloadable Rating
Input Block
Close
Enter Password
Select LOCK.
1MENU
ENTER
Input the password.
2 Enter the password as requested.
The TV is set up with the initial password
"0-0-0-0".
Hope this helps
John
