Question about Canon XL1S Mini DV Digital Camcorder
CANON XL LENS CAP FOR 16X ZOOM LENS
I AM LOOKING FOR THIS LENS CAP, CAUSE I LOST MINE. I AM HAVING A HARD TIME FINDING ONE. PLEASE HELP!
B. FLORES
  • 2,036 Answers
According to its specifications, this lens can use a 72mm filter. So you should be able to get the type lens cap that clips into a 72mm filter to work. Such as the one shown here. I'd recommend you go to a local camera store and try one to make sure it works.
Posted on Feb 11, 2009
My Canon A590 is stuck in 16x zoom (which it isn't supposed to have?). It powers on and off but it unresponsive to the other buttons. No more warranty.
Buy a new one. I am still trying to figure it out. If I pull on the lens a bit, when I restart, I get a normal view for one second and then zooms to 16x. It's a bummer, I love this camera. I used the macro a lot and noticed I was having trouble getting a clear focus before it did this.
Aug 21, 2010 | Canon PowerShot A590 IS Digital Camera
Will not record picture- blackscreen
this problem was with CCD image sencor replace it
May 25, 2010 | JVC GRD33 MiniDV Camcorder with 16x...
Lens does not zoom in
This is not a common error on canon digital. This is caused due to possible short in zoom control circuit (main pcb). At normal use, if the lens does not retract due to mechanical jam, when the zoom control button is pressed, lens error 18 message supposed to be displayed. Since control circuit is shorted and faulty, error 18 message was not displayed. The remedy for this problem probably requires a replacement of a main pcb. Replacing a main circuit board may run around $100-140. -James
Mar 29, 2009 | Canon PowerShot A640 Digital Camera
Lost lens cap
http://www.bitssite.com/canon-powershot-pro-1/2827/rear-lens-cap/accessory.html
That should be the cap your looking for if not let me know. Please take a moment to rate my solution fixya if it helps.
Thank you,
Lee
Jan 04, 2009 | Canon PowerShot Pro1 Digital Camera
17-85MM IS - mechanically stuck at 17mm - will not zoom -
Hi all,
I've had the same problem. So I decided to give it a try because I didn't find any solutions on the net. Unfortunately you have to pay pretty much for a Canon lens while the internal quality is pretty cheap, the whole mechanism is of plastic and this is also the problem. And after a while some screws will vibrate loose from the plastic components and canon could have done this better.
Probably within your lens is now one of the three zoom mechanism screws complete removed and you will notice that there is some abnormal movement in the zoom part. Unfortunately these screws are deeply mounted inside the lens and you need a lots of skill and patience to get it fixed.
First you need to completely disassemble the lens, and please make a picture of your lens after every step you make because I had to disassemble my lens 4 times! Because some of the elements was not right in place.
I will try to place a more complete description later today including some pictures.
Regards Gert
Aug 30, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
ERROR REMOVE CAP LENS
I had the same problem with mine after I dropped my camera when it was opening up after turning on. It feel directly on the lens and ever sense has told be to remove the lens cap.
I’ve disassembled the camera and discovered that the zoom motor drive assembly has a small set of plastic gears inside that are quite fragile and like mine are easily broken. You’ll find the zoom motor after taking the back assembly of the camera off. It’s located on the bottom left side of the lens assembly if you're looking at the camera as if you were taking a shot.
Here’s the part no. from the Panasonic support web site.....
L6DAAAHB0001
ZOOM MOTOR
46.07
May 28, 2008 | Panasonic Lumix DMC-FZ8 Digital Camera
Zoom not working at all
You have a one year warranty with Canon, you should have all the information about shipping it to them in your original box.
Dec 17, 2007 | Canon PowerShot S3 IS Digital Camera
Canon MVX250i Zoom Problem
I had this problem on this camera. I found the battery removal rechnique seemed to work for only a short while, then the problem would come back repeatedly. I looked into just buying a new one but when I explained the problem to a salesman in an independent camera shop, he asked me if I'd just tried hitting the top of the camera. Apparently the motor sometimes gets stuck. Since the camera was virtually useless I tried this (hit it 2 or 3 times quite firmly, near the lens and by the accessory shoe). Now it zooms in and out perfectly and so far hasn't reverted to its problem state.
Must try to give the camera shop some other business - maybe when I buy a new stills camera
Apr 23, 2007 | Canon MVX20I Mini DV Digital Camcorder
Canon XL1S Mini DV Digital Camcorder Logo
77 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
