Question about Intel D915GLVG Motherboard
Motherboard 915glvg power supply chip probelm
I have a Motherboard 915glvg which has power supply chip problem according to the service centre and can't be replaced, only option is to replace with a new board but since it is obselete and unavailable, could someone advice as to what would be an ideal board to look for maybe a gigabyte or an Asus which will be compatible with my Intel pentium D processor 630 3.0Ghz 2mb, its a pinless processor, I've been using DDR 1 ram on my 915 but I dont mind switching to DDR2 if need be, so please advice and would expect a prompt reply
  • 1,602 Answers
I read a magazine with information about manufacture and the bois and configuration issues from board that high end to boards low end and the name of the magazine is cpu computer power users, march 2009, the front of the magazine states motherboards and the mother lode.
you have some sites with additional information
www.motherboards.org
www.anandtech.com
www.chipanalyst.com/q/
www.chipset.com
www.hardwarecentral.com
www.the-view.com
www.tomshardware.com
www.tweakit.com
www.twinight.org/chipdir/
www.x86.org intel info only
www.x86,com intel info only
www.csif.cs.ucdavis.edu/-wen/intel.html giude to intel chipsets only
best of luck candymangandy
Posted on Feb 11, 2009
I have a Panasonic 42" plasma TV. It's 3 years old. Yesterday all of a sudden it started fetting switched off on it's own , the power light keeps blinking with red colour and with a click .. click ......
Hi Amol,
This kind of problem usually occurs when the power relay in your TV is damaged. This may happen due to heating up of the system, soft solder, chip problem or other minor problems in the board housing all the chips of your power equipement. Your technician is right and you have to take the set to your Service Centre and get the power board checked. In my case, it was a cracked board which affected the chip due to over heating. You can get your issue checked with the technician. Hope that helps.
Regards,
Arun
Sep 23, 2010 | Televison & Video
My motherboard will not power up after the power supply was changed.
hi...
1.the probelm is with the power supply unit which supplies power to all the unit.check weather output is comin or not.
2.check the power cable is properly inserted in the socket.
3.the socket connecting to the motherboard is damaged.
if my answer was usefull please vote me.
Jul 13, 2010 | Biostar K8VGA-M Motherboard
My HP Media Centre Model M7460 wakes itself up overnight when left in Standby Mode. I have disabled everything that I can think would be waking it up - but the probelm persists During the daytime - in...
It is possible that you have a CA Voltage problem... so, do you have overvoltage protection at power supply?. though you should remove jumper from "boot block" pins (or similar) in the Motherboard (HP computers usually have it). This surely willl help you.
Greetings!
Apr 19, 2010 | HP Computers & Internet
No display
Dear Sir,
By analysing your problem it seems to be problem with mother board only.
Before that
1.check with new RAM
2.check with another SMPS
3.Remove the processor and reinstall the processor
if these tips not helps deffinately a problem with motherboard.Visit nearer motherboard chip level repair service centre.
if you need service centre address post a comment with more information about the problem and your location.
good luck.
Aug 11, 2009 | Intel D845WN (KD845WNPAK10) Motherboard
Won't power on. standby 5v warning led is on.
You could have a probelm with the connection where the power supply connects to the motherboard or you may have a bad power supply. If you have a power supply tester, try testing the power supply first. If it pass, you may need to replace your board.
Good Luck
C2Solutions
Aug 03, 2009 | SuperMicro P4SGE (P4SGEBULK) Motherboard
945GCCR Motherboard Problem
DD SYSTEM SOLUTIONS
(MOTHER BOARD CHIP LEVEL SERVICE CENTRE)
OLD NO.28, NEW NO.67, II FLOOR
SESHA CHALAM STREET, SAIDAPET,
CHENNAI - 600 015.
PHONE NO : 98405-11595
May 04, 2009 | Intel D945GCCR Motherboard
When i try to start my intel d845glva mobo it just show a green light And nothing else.while my power supply is working properly.
DD SYSTEM SOLUTIONS
CHENNAI - 600 015.
Apr 27, 2009 | Intel Desktop Board D845GLVA...
No Signal
No signal on screen means that there is no input for your monitor from the PC.
1. There might be problem in your PC or in the cable connected to PC from monitor.
2. Your PC might damage that it could not send signal to the monitor.
2.1 In your Motherboard might be faulty in the VGA chips.
2.2 In your Motherboard's SMPS mean power supply.
I think you can got my point. If you are tech person it will help you, otherwise you should take a tour to any service centre.
Thanks & Goodluck
Iqbal
Jul 21, 2008 | Intel Desktop Board D845GLVA...
Testing a power supply
Most commonly it is the power supply. Rarely it is the motherboard when it just stops working with no other signs. You can take a power supply from another computer and test but I bet it is definitely the power supply. You can purchase a power supply tester for around $20 or so but you can get a power supply for not much more than that and test it that way.
Jun 19, 2007 | Antec SL400 (761345254007) 400-Watt Power...
Intel D915GLVG Motherboard Logo
338 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
