Question about Gateway (802.11usb) Wireless Adapter
Problems with wireless connection - gateway notebook
Hi, I have had a gateway T1631 notebook, MS Vista, (with Realtek RTL8187S wireless adapter) for about 6 months now and only recently I have been having trouble connecting to my home wireless network - my roommate has a mac and has no problems connecting to the home wireless network. The home network is a secured network (WPA Personal, secured network with a 16 digit alphanumeric passphrase).   I have no trouble connecting to unsecured wireless networks.  However, when I try connecting to the secured home network it does not work.  As far as I can tell, the passphrase does not seem to be saving properly.  When I change passphrase to the 16 digit alphanumeric, it reverts back to an incorrect +/-8 digit code.  I have tried removing the network connection via the control panel and then re-entering the passphrase but this does not work either.  I am unsure where the problem lies and any help would be MUCH appreciated!!!
  • elnourab Apr 21, 2009
    signal is ok
    connecetion established
    explorer not open pages
    messenger not connected
    connection without gateway
  • 66 Answers
Might be several things, but perhaps start with checking for any driver updates that might be available.
Posted on Feb 12, 2009
  • Jackie Finch Feb 12, 2009
    Now that I can see the rest of your post, one route is to set the security type to "no authentication (Open)" , WEP encryption, then type in your passphrase. Is the network availability set to "all users"? I've had this issue at home before, but it's been a while, and I don't remember every step needed. You can also type in the wireless router number that's on the bottom of the router for your passphrase, that might be easiest.
I have a Gateway T-series (Model:W350A) laptop. I just reinstalled Windows Vista and now the computer is not recognizing the built in wireless card. How do I get it to recognize it? Or how do I install the...
Plug in an ethernet cable into your ethernet card port on the left hand side of your laptop. When it connects to the internet click on the Windows update icon in the system tray. It should show you a Realtek Wireless RTL8187b wireless adapter driver update. Install it, you may need to reboot, but in any case you will have wireless networks available to you and you can pull out the ethernet cable. Good luck.
Dec 30, 2009 | Gateway M305CRV Notebook
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
Realtek rtl8101 wireless adaptor not recognized
"It also says under Network Connections that the Realtek card is my Local Area Connection and it has a network cable unplugged. " that's for your wired connection so don't worry about it...
Here's a couple of things to check, make sure your wireless switch is in the on position on your laptop...go to "My Networks" and click "new connection" and follow wizard for home and small office wireless>>have you had to input your WAP Key yet? it will not connect unless WAP key is input..let me know and we'll take it from there...good luck
May 28, 2009 | Computers & Internet
Drivers instalation
You can down load the driver for windows XP from the following link.
Download RealTek RTL8111C Auto installation program v.702 driver
For windows vista
Click here
Download RealTek RTL8111C Driver v.6.208
Good luck
If my solution proves useful please rate it.
Regards
Arjun.
Mar 27, 2009 | Computers & Internet
I have a Gateway MX3215. The wireless connection won't read my Linxsys router but if I hard wire it to my computer it works. I originally had XP and upgraded it to Vista. The wireless connection was...
You should check for updated drivers for the wireless NIC device. Gateway may have them available, but no guarantees. Did you do a compatibility check befiore installing Vista? It would have shown you what if any devices, and software were not compatible with vista before install. Try get as much info about the wireless device you can, and do a web search for known issues and solutions also. You may find others have had the same problem and a workaround.
Feb 26, 2009 | Gateway MX3215 Notebook
WiFi unable to connect/maintain connection
Hello b... couple things.
First; see if going into Control PanelNetwork Connections and disabling the wireless network connection, then enabling it again fixes it. If it does then you have a work-around...
Second; there was a Realtek driver update offered by Windows Update. If that has
been installed (Control Panel-Programs and Features-View Installed Updates)
roll it back to the previous driver through Device manager and get the
update direct from either Toshiba or Realtek.
See if that helps.
This seems to be happening with that Wireless card and Vista... let me know what happens please.
Dec 26, 2008 | Computers & Internet
Wireless connection problem, I have a gateway T1631 laptop. I cant see any network within the range even though I place d next to the router, but I can connect to the internet through the ethernet drive.
I have seen this issue alot of times. Please make sure you wireless card is turned on. Sometimes the switch is on the front or the sides or you may have to push a function button + a wireless button. Take a look at you owners manual to be sure
Aug 17, 2008 | Gateway Computers & Internet
Problems with wireless and MS Vista
Try these first:
change channels to 1-6-or 11. Make sure you change all of your wireless computers4.gif.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones1.gif and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Oct 17, 2007 | Computers & Internet
Gateway (802.11usb) Wireless Adapter Logo
719 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
