Question about Motorola Mobility RAZR V3c Cellular Phone
Screen doesn't turn on.
Hey. So I put my alarm clock to wake me up at 9, and then another alarm for 9:20... So when that time came, and the phone started to ring, I stopped the first alarm and I held the phone so when the second alarm rings I would wake up.. I don't know what happened but I woke up and the phone was under me, and now the screen doesn't turn on. The keypad flashes on and off and on and off but nothing else. I took the battery out and I've left the phone for the whole day and still nothing. This happened yesterday but it started to work again. How can I fix this and why does it do this?
  • 10 Answers
You have a loose connection inside the phone.  See solution
that I posted for others.  Basically, open phone then press with
your fingers the area between camera lens and vol up/down buttons.  In other words you are squeezing the pieces together
to get the ribbon cable inside the phone to reseat.  Let me
know if this works for you please.
Posted on Oct 11, 2007
How do I set the alarm on this model, which I cannot find any where. Grateful & puzzled. Model 7-4806A GE Clock Radio
if I could see a good picture of it perhaps I could assist . most have a slide bar to turn the alarm on then you use the hour or minute buttons to set .
Mar 18, 2016 | Audio Players & Recorders
Accidently activated the alarm clock on Gigaset phone A400/A400A and now I cant work out how to deactivate it. Sorry cant understand manual it doesn't seem very clear to me. I am a 67 year old pensioner so...
Hello
This tells you how to set it, but not how to turn it off, so my guess is that once set, and the alarm goes off, it is then turned off. Or, there is a toggle on it, so press OK to Set, and OK again to Disable. The sequence is
Menu ₪ Alarm Clock ₪ OK ₪ Activation ₪ OK and I reckon OK a second time to switch OFF
Setting the alarm clock
Activating/deactivating the alarm clock
Menu
Alarm Clock
OK
Activation
OK
= activated)
If activated
Enter wake-up time
OK
When the alarm clock rings, press any key to switch it off for 24
hours. If the alarm clock is set, the wake-up icon will appear on the screen and the wake-up time will be displayed instead of the date.Entering/changing the wake-up time
Menu
Alarm Clock
OK
Wakeup time
OK
Enter the wake-up time in hours and minutes, then press
OK
. The alarm clock is automatically activated after the wake-up time is entered/changed.
It is easier to read on Page12 of the manual.
Good luck
Andrew, age 65 (almost)
http://gse.gigaset.com/fileadmin/legacy-assets/A31008-M2201-L101-2-7619_en_UK.pdf
Dec 10, 2017 | Lands Phones
How do I set the alarm so it will activate on weekdays. It only works for Saturday and Sunday. Thanks
Hello
Sure Alarm battery Back-Up System
This SmartSet® Clock Radio includes a Sure Alarm battery back-up circuit that can
wake you up even if the power is 'Off'at the selected wake up time. If your power
is 'Off'at the selected wake up time the clock display will be off and the radio will
not operate, but a separate mini-buzzer will turn 'On'automatically to wake you up,
even if you had selected the "Wake to Radio"option.
The Sure Alarm will sound for 30 seconds and then shut off automatically.
To stop the Sure Alarm buzzer immediately, press the RADIO ON/OFF button.
Pressing the SNOOZE button has no effect during Sure Alarm operation.
Note: In order to maximize the life of the built in lithium battery, please be sure
to set the ALARM 1 and ALARM 2 switches to the "OFF"position if the radio
will be disconnected from the AC outlet for more than a few hours. This will
prevent the Sure Alarm from turning 'On'unnecessarily.
1.) Depress and hold either the ALARM 1 or ALARM 2 setting button.
The display will change from the correct time
to the Alarm 1 or Alarm 2 wake up time.
2.) While holding the ALARM 1 or ALARM 2 setting button, depress either the
SET + or - button to move the display ahead or back to your desired wake up
time.
3.) When the desired wake up time appears on the display, release the SET + or
- buttons.
Note: Be sure that you have set the wake up time correctly by observing
the AM indicator. If the AM indicator is 'On'the wake up time is "AM". If the
AM indicator is 'Off', the wake up time is "PM".
4.) When the desired wake up time (AM or PM) appears on the display, release
the ALARM 1 or ALARM 2 setting buttons
Apr 20, 2011 | Emerson Smartset Clock Radio
Dont know how to set time or alarm
Press and hold the Set Wake button and the press either the fwd or rev button until the desired Wake time is reached. Release the buttons to return to the current time display. To display the wake time, press and release the Set Wake button. To turn off the alarm, press and hold Wake Mode until the alarm icon disappears. (This button lets you choose Wake to Music, Wake to Alarm or Off.)
The owner's manual is available here: http://support.radioshack.com/support_audio/37571.htm .
I hope this helps.
Mar 11, 2011 | RCA RP3711 Clock Radio
Can't turn off the alarm
There are two alarms, and the steps are the same .
Look on the face. On the left of the big numbers are two symbols, a 'bell' and a 'music note'. That's WAKE 1. On the right of the big numbers are two symbols, a bell and music note. That's WAKE 2. If any of these are on, then one (or both) alarms are set to repeat.
Stopping repeat Wake 1 alarm. Click the Wake 1 button (on the top) several times, while looking at the face. Notice the circles that light up. It will switch back and forth between bell and music note each time you press the Wake 1 alarm button.
HOLD DOWN the WAKE 1 button on the top, until both lights are off. The Wake 1 alarm is now off.
Wake 2 alarm: Same steps, but for the green circles on the right side of the face.
Get a piece of paper, write "HOLD DOWN WAKE BUTTON to stop repeating alarm" and tape it to the back of the clock.
Feb 12, 2011 | GE 7-4853 Clock Radio
The correct time is showing but it is just blinking...
Chances are, one or both of your alarm times has not been set. You should be able to stop the flashing just by using the "Wake 1 - Wake 2" switch on top of the radio: move it all the way to the left. If one or both of the alarms is set, the Alarm time indicator on the front (bottom right) will say what the first alarm time is. To see what the second alarm time is, move the 'Wake 1 - Wake 2" switch all the way to the right and use the Forward--Reverse buttons on the front of the clock on the left side. Then move the "Wake 1 - Wake 2" switch all the way back to the left.
The switches on the far right on top of the radio are for choosing an alarm sound or music as what you hear at the alarm time, or or turning off the alarms.
Nov 22, 2010 | RCA RP5430 Clock Radio
May 07, 2010 | GE 7-4853 Clock Radio
Wacky wake up alarm clock instructions
Hold down the "time set" button until the time on the clock flashes. Then use rev or fwd to set the time. Press the "time set" button again once you have the correct time. You can do the same to set the alarm by holding down the "alarm set" button.
Jan 03, 2009 | Watches
Setting the alarm on my clock radio
use the selector switch on the top, switch it to wake 1 or wake 2. set the time that you want that alarm to go off. then push the switch all the way back to the left to deactivate it. then to activate the alarm, use the buttons on top labeled wake 1 or wake 2 to turn the desired alarm on. pushing that button repeatedly will cycle the alarm to either beep, radio, or it will turn that alarm off.
Oct 21, 2008 | RCA RP5440 Clock Radio
Alarm
SLIDE THE SWITCH TO TIME DO NOT PUT ON WAKE 1 OR WAKE 2 THOSE ARE LIKE TWO SEPEATE ALARM TIMES YOU COULD SET PUT ON CANCEL OR JUST TIME.
May 28, 2007 | GE RP4842 Clock Radio
Motorola Mobility RAZR V3c Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
