Question about Apple iPod nano
Bought a second hand 4 gb nano not working
Got it from a friend who said it worked fine did not check it first duh!!, any way i plug it into my pc and it flashes the apple screen then the language menu, my comp. then says did not recognize the device, and it repeats this continually, any suggestions?? any help greatly appreciated
  • 52 Answers
Make sure that you have downloaded the most resent iTunes program to your computer you are using...once you do that then plug your device back in....if it still does it....take it to an Apple store and they will do a couple of test with thier computers there and if it's something they can't fix they will send it off to Apple.
Posted on Feb 11, 2009
Refrigerator not getting cold in Fridge side
No. check this post from right here.
http://www.fixya.com/support/t245665-samsung_rs2556_refrigerator_side_not
Question: was the fridge running when you went to pick it up ?
Was it already on ?
My thinking is that you have the ice build up problem too and that it never thawed. If you unplug it, thawing could take days. Seriously. If you take the inside panel off and get some heat on it
only an hour or so.
You have the exact same model I do, and it works good, just designed poorly. It needs a drain hole on that condensor.
And your fan probably is fine. Do not spend $500.
Apr 06, 2009 | Samsung RS2556 Side by Side Refrigerator
When I charge my iPod Nano it charges fine but instead of turning off or ... it will turn off but in about 2 seconds it goes to the "Charged"
You need a new battery for your iPod. you can view a free instructional video on battery replacement at the first web address posted below. the second one is a cheap site I found for purchasing iPod parts.
http://fixyouripod.weebly.com/
http://www.ifixit.com/
Mar 13, 2009 | Apple iPod nano
Empty Disk
"Root" is the root directory - definitely not something that you want to delete. Go to Apple's website and re-download the firmware, and hopefully it will re-add the missing folder.
Jun 22, 2008 | Apple Ipod Nano Second Gen. Green (4 GB)...
Ipod nano 8 GB
i have a i pod nano 8 gb . i bought a game from i tuns i have it in my library but i can't put it on my i pod
Jan 23, 2008 | Apple Ipod Nano Second Gen. Green (4 GB)...
Ipod nano won't work for us
try pressing the reset button with a toothpick on the nano if this doesnt work then read the manual on how to do a hard reset.
good luck.
smeags.
Dec 31, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
Ipod nano
you need to download itunes from the apple website
Nov 28, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
Ipod Nano Second Generation
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Aug 24, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
Washer
sorry, but you're probably screwed. Once wet, the connections inside start to corrode and then it's junk. Sell it on E-Bay as broken/part/repair. Be honest and let people know that it got wet. The case and a few parts may still be usable. Then take the money you get and buy a used working one off e-bay. you can usually get nanos in good used condition for $80 to $100
Jul 05, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
