Question about Samsung Heating & Cooling
Samsung 1.0 ton(split) AC stops working during 36-37 degree C.
Dear Sir, I had purchased one 1.0 ton (split) AC from Samsung on 12/062008. The name of the dealer is Multitrade, situated at A. T. Road, Bharlumukh, Guwahati. It has 1 year warranty and the compressor has 5 year warranty. After using the AC for 2-3 days I saw a peculiar problem with it. The AC all off a sudden fails to cool the room. Sometimes this thing last for 20-25 mins and sometimes it goes on for more than one hour. During the problem I have noticed that the water does not come out of the drain pipe. Also to note that the temperature of the aluminum pipe that comes out of the outdoor unit is not cold during that particular time. Another thing that I have noticed is that hot air does not come (which normally comes when the AC is functioning properly) out of the outdoor unit when the problem strikes. The air that comes out is of normal temperature although the fan inside the outdoor unit is running. Another important observation is that the indicator in the indoor unit which signals that the outdoor unit is running remains glowing during this period. I have noticed that this problem generally takes place during day time when the temperature is relatively hot. I have already placed my complain with Samsung and they sent their representative the next day, but at that time the AC was working properly. He checked the unit and said that the problem was due to excessive gas in the unit and so he released some gas and said that everything will be ok and went away. But again after a few days I started facing the same problem. Now I am at my witsend about what to do and how to explain the problem to the Samsung people. Because this problem does not occur all the time and so I am not able to show the problem to the Samsung people. Please solve the problem so that I get peace of mind.
I believe you have a high pressure switch on your condenser that is going bad .it is a switch that has two red wires connected to it inside your outside unit
Posted on Feb 11, 2009
I have samsung split ac 1.5 ton 2.5 years old when am switch on the ac the indoor unit is working when it tires to on the out door unit after 3 minute delay suddenly the ac is restarting but the out d
Make sure all of the pressure switches are closed on the low voltage control circuit on the outdoor unit. If any are stuck open, the compressor will not kick on. Or just push the compressor contactor in with an insulated screwdriver to ensure the compressor does actually work.
Dec 28, 2014 | Samsung Heating & Cooling
My orient split a.c shows Ec error in digital display
sir plz answer me my ac orien 1 ton showing EC error on display what is this i can't understand what is this plz reply
Jul 12, 2014 | Heating & Cooling
Out door is not working
Check for communication from indoor to out door.Check power in out door unit. If not, check the following.
Keep cool mode and temp setting minimum 3 degree less than room temp.
Check indoor unit return air sensor. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace air sensor
Check Indoor Pipe Sensor Disconnect from PCB and measure resistance. Pipe sensor = 5kOhm at 25C. If not replace pipe sensor.
Thanks and hope helpful?
Feb 04, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Hi I have 1.5 ton samsung split ac. The problem is to solve the water leakage in the indoor unit. Kindly advise
the water comes from the coil, start there make sure there is no obstruction coming out to your condensate line and make sure its properly pitched.
May 19, 2010 | Samsung AS1293L Air Conditioner
LG split AC LST243H-2 not working at all,failed while on
i want purchase a split ac 1.5 ton our temperature may month 45 to 46 C which brand Ac purchse
Dec 29, 2009 | LG Heating & Cooling
Split ac not cooling the room.ac temparature remains at 27 degree after ac runs for about 4 hours.please solve this
Gas has leaked from inner or outer unit kindly get it checked by service men they will find the leak and charge the gas again normally after some time it gets rusty inside as water is involved and got leak
no problem get it repaired not expensive
pls rate me well !
Regards
Jul 14, 2009 | LG LS092CE Split System Air Conditioner
Samsung 1.5 ton slpit AC.the out door unit is very noisy
Check to see if the noise is coming from the fan, could be bad bearings. Replace the fan motor if that is the case. If the noise is coming from the compressor, the only other place besides the fan, then your compressor has some issues and will probably stop working soon, maybe line up for a replacement before you are left with a hot house.
Jun 11, 2009 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
410 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
